8.0
cs_paramedmem_remapper.h
1 #ifndef __CS_PARAMEDMEM_REMAPPER_HXX__
2 #define __CS_PARAMEDMEM_REMAPPER_HXX__
5  * Parallel interpolation using ParaMEDMEM OverlapDEC
29  * Local headers
32 #include "cs_defs.h"
34 /*----------------------------------------------------------------------------*/
38 typedef struct _cs_paramedmem_remapper_t cs_paramedmem_remapper_t;
53 /*----------------------------------------------------------------------------*/
54
55 cs_paramedmem_remapper_t *
57  const char *sel_criteria,
58  char *file_name,
59  char *mesh_name,
60  cs_real_t center[3],
61  cs_real_t radius);
62
63 /*----------------------------------------------------------------------------*/
71 /*----------------------------------------------------------------------------*/
72
73 cs_paramedmem_remapper_t *
74 cs_paramedmem_remapper_by_name_try(const char *name);
75
76 /*----------------------------------------------------------------------------*/
98
99 cs_real_t *
100 cs_paramedmem_remap_field(cs_paramedmem_remapper_t *r,
101  char *field_name,
102  cs_real_t default_val,
103  int time_choice,
104  double tval);
105
106 /*----------------------------------------------------------------------------*/
118 /*----------------------------------------------------------------------------*/
119
120 cs_real_t *
121 cs_paramedmem_remap_field_one_time(cs_paramedmem_remapper_t *r,
122  char *field_name,
123  cs_real_t default_val,
124  int dt,
125  int it);
126
135
136 void
137 cs_paramedmem_remapper_translate(cs_paramedmem_remapper_t *r,
138  cs_real_t translation[3]);
139
140 /*----------------------------------------------------------------------------*/
149 /*----------------------------------------------------------------------------*/
150
151 void
152 cs_paramedmem_remapper_rotate(cs_paramedmem_remapper_t *r,
153  cs_real_t invariant[3],
154  cs_real_t axis[3],
155  cs_real_t angle);
156
157 /*----------------------------------------------------------------------------*/
161 /*----------------------------------------------------------------------------*/
162
163 void
165
166 /*----------------------------------------------------------------------------*/
167
169
170 #endif /* __CS_PARAMEDMEM_REMAPPER_HXX__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
@ dt
cs_real_t * cs_paramedmem_remap_field_one_time(cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int dt, int it)
Remaps a field from the med file to the local mesh for a given time.
Definition: cs_paramedmem_remapper.cxx:601
cs_paramedmem_remapper_t * cs_paramedmem_remapper_by_name_try(const char *name)
get a remapper by its name
Definition: cs_paramedmem_remapper.cxx:562
cs_real_t * cs_paramedmem_remap_field(cs_paramedmem_remapper_t *r, char *field_name, cs_real_t default_val, int time_choice, double tval)
Interpolate a given field on the local mesh for a given time.
Definition: cs_paramedmem_remapper.cxx:717
void cs_paramedmem_remapper_rotate(cs_paramedmem_remapper_t *r, cs_real_t invariant[3], cs_real_t axis[3], cs_real_t angle)
Rotate the mesh using a center point, axis and angle.
Definition: cs_paramedmem_remapper.cxx:844
void cs_paramedmem_remapper_destroy_all(void)
Destroy all remappers.
Definition: cs_paramedmem_remapper.cxx:876
cs_paramedmem_remapper_t * cs_paramedmem_remapper_create(char *name, const char *sel_criteria, char *file_name, char *mesh_name, cs_real_t center[3], cs_real_t radius)
Creates a new cs_paramedmem_remapper_t instance.
Definition: cs_paramedmem_remapper.cxx:504
void cs_paramedmem_remapper_translate(cs_paramedmem_remapper_t *r, cs_real_t translation[3])
translate the mesh using a given vector
Definition: cs_paramedmem_remapper.cxx:812
