cs_paramedmem_coupling_t * | cs_paramedmem_coupling_by_id (int cpl_id) |
Retrieve coupling struct pointer by id. More... | |
cs_paramedmem_coupling_t * | cs_paramedmem_coupling_by_name (const char *name) |
Retrieve coupling struct pointer by name. More... | |
cs_paramedmem_coupling_t * | cs_paramedmem_coupling_create (const char *app1_name, const char *app2_name, const char *cpl_name) |
Create a new ParaMEDMEM coupling. More... | |
cs_paramedmem_coupling_t * | cs_paramedmem_coupling_create_uncoupled (const char *cpl_name) |
Create a new ParaMEDMEM handler structure with no actual coupling. More... | |
void | cs_paramedmem_coupling_destroy (cs_paramedmem_coupling_t *c) |
Destroy a given ParaMEDMEM coupling structure. More... | |
void | cs_paramedmem_coupling_all_finalize (void) |
Destroy all coupling structures. More... | |
void | cs_paramedmem_add_mesh_from_criteria (cs_paramedmem_coupling_t *c, const char *sel_crit, int elt_dim) |
Define coupled mesh based on a selection criteria. More... | |
void | cs_paramedmem_add_mesh_from_zone (cs_paramedmem_coupling_t *c, const cs_zone_t *zone) |
Define coupled mesh based on a cs_zone_t pointer. More... | |
void | cs_paramedmem_add_mesh_from_ids (cs_paramedmem_coupling_t *c, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int elt_dim) |
int | cs_paramedmem_get_number_of_couplings (void) |
Get number of defined couplings. More... | |
cs_lnum_t | cs_paramedmem_mesh_get_n_elts (const cs_paramedmem_coupling_t *coupling) |
Get number of elements of coupled mesh. More... | |
const cs_lnum_t * | cs_paramedmem_mesh_get_elt_list (const cs_paramedmem_coupling_t *coupling) |
Get indirection list for elements in coupled mesh. More... | |
cs_lnum_t | cs_paramedmem_mesh_get_n_vertices (const cs_paramedmem_coupling_t *coupling) |
Get number of vertices of coupled mesh. More... | |
const cs_lnum_t * | cs_paramedmem_mesh_get_vertex_list (const cs_paramedmem_coupling_t *coupling) |
Get indirection list for vertices in coupled mesh. More... | |
int | cs_paramedmem_def_coupled_field (cs_paramedmem_coupling_t *c, const char *name, int dim, cs_medcpl_field_nature_t field_nature, cs_medcpl_space_discr_t space_discr, cs_medcpl_time_discr_t time_discr) |
Define a coupled field. More... | |
int | cs_paramedmem_def_coupled_field_from_cs_field (cs_paramedmem_coupling_t *c, cs_field_t *f, cs_medcpl_field_nature_t fn, cs_medcpl_time_discr_t td) |
Define a coupled field based on a cs_field_t pointer. More... | |
void | cs_paramedmem_field_export (cs_paramedmem_coupling_t *c, const char *name, const double values[]) |
Assign values based on parent mesh location to associated ParaFIELD objects. More... | |
void | cs_paramedmem_field_export_l (cs_paramedmem_coupling_t *c, const char *name, const double values[]) |
Assign values based on mesh location corresponding to coupled elements (and associated ParaMESH) to associated ParaFIELD objects. More... | |
void | cs_paramedmem_field_import (cs_paramedmem_coupling_t *c, const char *name, double values[]) |
Copy values from associated ParaFIELD object to array defined parent mesh location. More... | |
void | cs_paramedmem_field_import_l (cs_paramedmem_coupling_t *c, const char *name, double values[]) |
Copy values from associated ParaFIELD structure to array defined on mesh location corresponding to coupled elements (and associated ParaMESH). More... | |
void | cs_paramedmem_sync_dec (cs_paramedmem_coupling_t *c) |
Sync the coupling's InterpKernelDEC. More... | |
void | cs_paramedmem_send_data (cs_paramedmem_coupling_t *c) |
Send values of field attached to DEC. More... | |
void | cs_paramedmem_recv_data (cs_paramedmem_coupling_t *c) |
Recieve values of field attached to DEC. More... | |
void | cs_paramedmem_attach_field_by_id (cs_paramedmem_coupling_t *c, int field_id) |
Attach a field to InterpKernelDEC for send operation using its index. More... | |
void | cs_paramedmem_attach_field_by_name (cs_paramedmem_coupling_t *c, const char *name) |
Attach a field to InterpKernelDEC for send operation using its name. More... | |
void | cs_paramedmem_send_field_vals (cs_paramedmem_coupling_t *c, const char *name, const double *vals) |
Send values of a field. If vals pointer is non-null, values are updated before send. More... | |
void | cs_paramedmem_recv_field_vals (cs_paramedmem_coupling_t *c, const char *name, double *vals) |
Recieve values of a field. More... | |
void | cs_paramedmem_coupling_all_init (void) |
initialize couplings based on user functions More... | |
void | cs_paramedmem_coupling_define_mesh_fields (void) |
initialize coupled mesh and fields based on user functions More... | |
void | cs_paramedmem_coupling_log_setup (void) |
Log ParaMEDMEM coupling setup information. More... | |
void cs_paramedmem_add_mesh_from_criteria | ( | cs_paramedmem_coupling_t * | c, |
const char * | sel_crit, | ||
int | elt_dim | ||
[in] | c | pointer to cs_paramedmem_coupling_t struct |
[in] | sel_crit | geometrical selection criteria (string) |
[in] | elt_dim | dimension of coupled elements |
void cs_paramedmem_add_mesh_from_ids | ( | cs_paramedmem_coupling_t * | c, |
cs_lnum_t | n_elts, | ||
const cs_lnum_t | elt_ids[], | ||
int | elt_dim | ||
[in] | n_elts | local number of elements |
[in] | elt_ids | list of local elements |
[in] | elt_dim | dimension of elements (2: faces, 3: cells) |
void cs_paramedmem_add_mesh_from_zone | ( | cs_paramedmem_coupling_t * | c, |
const cs_zone_t * | zone | ||
void cs_paramedmem_attach_field_by_id | ( | cs_paramedmem_coupling_t * | c, |
int | field_id | ||
[in] | c | pointer to cs_paramedmem_coupling_t structure |
[in] | field_id | index of field in storing vector |
void cs_paramedmem_attach_field_by_name | ( | cs_paramedmem_coupling_t * | c, |
const char * | name | ||
[in] | name | name of field (string) |
void cs_paramedmem_coupling_all_finalize | ( | void | ) |
void cs_paramedmem_coupling_all_init | ( | void | ) |
cs_paramedmem_coupling_t* cs_paramedmem_coupling_by_id | ( | int | cpl_id | ) |
[in] | cpl_id | index of the sought coupling |
cs_paramedmem_coupling_t* cs_paramedmem_coupling_by_name | ( | const char * | name | ) |
[in] | name | name of the coupling |
cs_paramedmem_coupling_t* cs_paramedmem_coupling_create | ( | const char * | app1_name, |
const char * | app2_name, | ||
const char * | cpl_name | ||
[in] | app1_name | Name of app n°1 or NULL if calling app is app1 |
[in] | app2_name | Name of app n°2 or NULL if calling app is app2 |
[in] | cpl_name | Name of the coupling. If NULL an automatic name is generated. |
cs_paramedmem_coupling_t* cs_paramedmem_coupling_create_uncoupled | ( | const char * | cpl_name | ) |
This can be useful for a "dry run" when setting up a coupling, so as to first debug local commands before actually running in coupled mode.
In this case, data "received" matches the initialized values.
void cs_paramedmem_coupling_define_mesh_fields | ( | void | ) |
void cs_paramedmem_coupling_destroy | ( | cs_paramedmem_coupling_t * | c | ) |
void cs_paramedmem_coupling_log_setup | ( | void | ) |
int cs_paramedmem_def_coupled_field | ( | cs_paramedmem_coupling_t * | c, |
const char * | name, | ||
int | dim, | ||
cs_medcpl_field_nature_t | field_nature, | ||
cs_medcpl_space_discr_t | space_discr, | ||
cs_medcpl_time_discr_t | time_discr | ||
[in] | name | name of field |
[in] | dim | field dimension |
[in] | field_nature | field nature flag |
[in] | space_discr | field space discretisation (nodes or cells) |
[in] | time_discr | field coupling time discretisation |
int cs_paramedmem_def_coupled_field_from_cs_field | ( | cs_paramedmem_coupling_t * | c, |
cs_field_t * | f, | ||
cs_medcpl_field_nature_t | fn, | ||
cs_medcpl_time_discr_t | td | ||
[in] | f | pointer to cs_field_t struct |
[in] | fn | field nature flag |
void cs_paramedmem_field_export | ( | cs_paramedmem_coupling_t * | c, |
const double | values[] | ||
[in] | values | array of values to write (defined on parent mesh location) |
void cs_paramedmem_field_export_l | ( | cs_paramedmem_coupling_t * | c, |
If the whole mesh is coupled, the behavior is the sames as that of cs_paramedmem_field_export.
[in] | values | array of values to write (defined on selected mesh subset) |
void cs_paramedmem_field_import | ( | cs_paramedmem_coupling_t * | c, |
[in] | values | array in which values will be stored |
void cs_paramedmem_field_import_l | ( | cs_paramedmem_coupling_t * | c, |
If the whole mesh is coupled, the behavior is the sames as that of cs_paramedmem_field_import.
int cs_paramedmem_get_number_of_couplings | ( | void | ) |
const cs_lnum_t* cs_paramedmem_mesh_get_elt_list | ( | const cs_paramedmem_coupling_t * | coupling | ) |
[in] | coupling | pointer to cs_paramedmem_coupling_t struct |
cs_lnum_t cs_paramedmem_mesh_get_n_elts | ( | const cs_paramedmem_coupling_t * | coupling | ) |
cs_lnum_t cs_paramedmem_mesh_get_n_vertices | ( | const cs_paramedmem_coupling_t * | coupling | ) |
const cs_lnum_t* cs_paramedmem_mesh_get_vertex_list | ( | const cs_paramedmem_coupling_t * | coupling | ) |
void cs_paramedmem_recv_data | ( | cs_paramedmem_coupling_t * | c | ) |
void cs_paramedmem_recv_field_vals | ( | cs_paramedmem_coupling_t * | c, |
double * | vals | ||
[in] | vals | array of values to read |
void cs_paramedmem_send_data | ( | cs_paramedmem_coupling_t * | c | ) |
void cs_paramedmem_send_field_vals | ( | cs_paramedmem_coupling_t * | c, |
const double * | vals | ||
[in] | vals | array of values to write |
void cs_paramedmem_sync_dec | ( | cs_paramedmem_coupling_t * | c | ) |
