8.0
cs_measures_util.h File Reference
+ Include dependency graph for cs_measures_util.h:
Data Structures
struct  cs_measures_set_t
struct  cs_interpol_grid_t
void cs_interpol_field_on_grid_deprecated (cs_interpol_grid_t *ig, const cs_real_t *values_to_interpol, cs_real_t *interpoled_values)
void cs_interpol_field_on_grid (cs_interpol_grid_t *ig, const cs_real_t *values_to_interpol, cs_real_t *interpoled_values)
cs_interpol_grid_tcs_interpol_grid_create (const char *name)
void cs_interpol_grid_init (cs_interpol_grid_t *ig, const cs_lnum_t nb_points, const cs_real_t *coords)
cs_measures_set_tcs_measures_set_create (const char *name, int type_flag, int dim, bool interleaved)
void cs_measures_set_map_values (cs_measures_set_t *ms, const cs_lnum_t nb_measures, const int *is_cressman, const int *is_interpol, const cs_real_t *measures_coords, const cs_real_t *measures, const cs_real_t *influence_radius)
void cs_measures_set_add_values (cs_measures_set_t *ms, const cs_lnum_t nb_measures, const int *is_cressman, const int *is_interpol, const cs_real_t *measures_coords, const cs_real_t *measures, const cs_real_t *influence_radius)
void cs_cressman_interpol (cs_measures_set_t *ms, cs_real_t *interpolated_values, int id_type)
cs_measures_set_tcs_measures_set_by_id (int id)
cs_interpol_grid_tcs_interpol_grid_by_id (int id)
cs_measures_set_tcs_measures_set_by_name (const char *name)
cs_interpol_grid_tcs_interpol_grid_by_name (const char *name)
void cs_measures_sets_destroy (void)
void cs_interpol_grids_destroy (void)
void mestcr (const char *name, const int *idim, const int *ilved, int *imeset)
void gridcr (const char *name, int *igrid)
void mesmap (const int *imeset, const int *inbmes, const cs_real_t *meset, const cs_real_t *coords, const int *cressm, const int *interp, const cs_real_t *infrad)
void grimap (const int *igrid, const int *inpts, const cs_real_t *coords)
void mesadd (const int *imeset, const int *inbmes, const cs_real_t *meset, const cs_real_t *coords, const int *cressm, const int *interp, const cs_real_t *infrad)
void mscrss (const int *imeset, const int *type, cs_real_t *pldval)
void gripol (const int *igrid, const cs_real_t *inval, cs_real_t *pldval)
void mestde (void)
void grides (void)
◆ cs_cressman_interpol()
void cs_cressman_interpol ( cs_measures_set_t ms,
cs_real_t interpolated_values,
int  id_type
◆ cs_interpol_field_on_grid()
void cs_interpol_field_on_grid ( cs_interpol_grid_t ig,
const cs_real_t values_to_interpol,
cs_real_t interpoled_values
◆ cs_interpol_field_on_grid_deprecated()
void cs_interpol_field_on_grid_deprecated ( cs_interpol_grid_t ig,
◆ cs_interpol_grid_by_id()
cs_interpol_grid_t* cs_interpol_grid_by_id ( int  id)
◆ cs_interpol_grid_by_name()
cs_interpol_grid_t* cs_interpol_grid_by_name ( const char *  name)
◆ cs_interpol_grid_create()
cs_interpol_grid_t* cs_interpol_grid_create ( const char *  name)
◆ cs_interpol_grid_init()
void cs_interpol_grid_init ( cs_interpol_grid_t ig,
const cs_real_t coords
◆ cs_interpol_grids_destroy()
void cs_interpol_grids_destroy ( void  )
◆ cs_measures_set_add_values()
void cs_measures_set_add_values ( cs_measures_set_t ms,
const int *  is_cressman,
const int *  is_interpol,
const cs_real_t measures_coords,
const cs_real_t measures,
const cs_real_t influence_radius
◆ cs_measures_set_by_id()
cs_measures_set_t* cs_measures_set_by_id ( int  id)
◆ cs_measures_set_by_name()
cs_measures_set_t* cs_measures_set_by_name ( const char *  name)
◆ cs_measures_set_create()
cs_measures_set_t* cs_measures_set_create ( const char *  name,
int  type_flag,
int  dim,
bool  interleaved
◆ cs_measures_set_map_values()
void cs_measures_set_map_values ( cs_measures_set_t ms,
◆ cs_measures_sets_destroy()
void cs_measures_sets_destroy ( void  )
◆ gridcr()
void gridcr ( const char *  name,
int *  igrid
◆ grides()
void grides ( void  )
◆ grimap()
void grimap ( const int *  igrid,
const int *  inpts,
◆ gripol()
void gripol ( const int *  igrid,
const cs_real_t inval,
cs_real_t pldval
◆ mesadd()
void mesadd ( const int *  imeset,
const int *  inbmes,
const cs_real_t meset,
const cs_real_t coords,
const int *  cressm,
const int *  interp,
const cs_real_t infrad
◆ mesmap()
void mesmap ( const int *  imeset,
const int *  inbmes,
const int *  cressm,
const int *  interp,
◆ mestcr()
void mestcr ( const char *  name,
const int *  idim,
const int *  ilved,
int *  imeset
◆ mestde()
void mestde ( void  )
◆ mscrss()
void mscrss ( const int *  imeset,
const int *  type,
cs_real_t pldval
