| void | cs_log_iteration_destroy_all (void) |
| | Free arrays possible used by logging of array statistics. More...
| void | cs_log_iteration (void) |
| | Log field and other array statistics for the current time step. More...
| void | cs_log_iteration_add_array (const char *name, const char *category, const cs_mesh_location_type_t loc_id, bool is_intensive, int dim, const cs_real_t val[]) |
| | Add or update array not saved as permanent field to iteration log. More...
| void | cs_log_iteration_clipping (const char *name, int dim, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[]) |
| | Add or update clipping info for a given array. More...
| void | cs_log_iteration_clipping_field (int f_id, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[], cs_lnum_t n_clip_min_comp[], cs_lnum_t n_clip_max_comp[]) |
| | Add or update clipping info for a field. More...
| void | cs_log_iteration_prepare (void) |
| | Initialize structures used for logging for new iteration. More...
| void | cs_log_iteration_l2residual (void) |
| | Log L2 time residual for variable fields. More...
◆ cs_log_iteration()
| void cs_log_iteration |
void |
◆ cs_log_iteration_add_array()
| void cs_log_iteration_add_array |
const char * |
name, |
const char * |
category, |
const cs_mesh_location_type_t |
loc_id, |
bool |
is_intensive, |
int |
dim, |
const cs_real_t |
val[] |
- Parameters
| [in] | name | array name |
| [in] | category | category name |
| [in] | loc_id | associated mesh location id |
| [in] | is_intensive | are the matching values intensive ? |
| [in] | dim | associated dimension (interleaved) |
| [in] | val | associated values |
◆ cs_log_iteration_clipping()
- Parameters
| [in] | name | field or array name |
| [in] | dim | associated dimension |
| [in] | n_clip_min | number of local clippings to minimum value |
| [in] | n_clip_max | number of local clippings to maximum value |
| [in] | min_pre_clip | minimum values prior to clipping |
| [in] | max_pre_clip | maximum values prior to clipping |
◆ cs_log_iteration_clipping_field()
- Parameters
| [in] | f_id | associated field id |
| [in] | n_clip_min_comp | number of clip min by component |
| [in] | n_clip_max_comp | number of clip max by component |
◆ cs_log_iteration_destroy_all()
| void cs_log_iteration_destroy_all |
void |
◆ cs_log_iteration_l2residual()
| void cs_log_iteration_l2residual |
void |
◆ cs_log_iteration_prepare()
| void cs_log_iteration_prepare |
void |
