8.0
cs_lagr_agglo.h
1 #ifndef __CS_LAGR_AGGLO_H__
2 #define __CS_LAGR_AGGLO_H__
5  * Agglomeration modeling.
30 #include "cs_defs.h"
37  * Local headers
45  * Public function prototypes
48 /*----------------------------------------------------------------------------*/
59 /*----------------------------------------------------------------------------*/
60
61 void
63  cs_lnum_2_t arr2[],
64  cs_lnum_t n1,
65  cs_lnum_t n2,
66  cs_lnum_2_t arr3[]);
67
68 /*----------------------------------------------------------------------------*/
103
104 cs_lnum_t
106  cs_real_t dt,
107  cs_real_t minimum_particle_diam,
108  cs_lnum_t start_particle,
109  cs_lnum_t end_particle);
110
111 /*----------------------------------------------------------------------------*/
112
114
115 #endif /* __CS_LAGR_AGGLO_H__*/
Definition: cs_defs.h:509
Definition: cs_defs.h:319
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:325
Definition: cs_defs.h:313
@ dt
void cs_lagr_agglo_merge_arrays(cs_lnum_2_t arr1[], cs_lnum_2_t arr2[], cs_lnum_t n1, cs_lnum_t n2, cs_lnum_2_t arr3[])
Merge two sorted arrays in a third sorted array.
Definition: cs_lagr_agglo.c:309
cs_lnum_t cs_lagr_agglomeration(cs_lnum_t cell_id, cs_real_t dt, cs_real_t minimum_particle_diam, cs_lnum_t start_particle, cs_lnum_t end_particle)
Agglomeration algorithm based on algorithms used in rare gas modelling.
Definition: cs_lagr_agglo.c:386
