8.0
cs_lagr.h
1 #ifndef __CS_LAGR_H__
2 #define __CS_LAGR_H__
5  * Functions and types for the Lagrangian module
30 #include "cs_defs.h"
36 #include "assert.h"
39  * Local headers
42 #include "cs_base.h"
43 #include "cs_field.h"
45 #include "cs_lagr_injection.h"
46
47 /*----------------------------------------------------------------------------*/
48
50
52  * Type definitions
54
55 /*----------------------------------------------------------------------------*/
70 /*----------------------------------------------------------------------------*/
71
72 typedef void
74  int location_id,
75  const void *input,
76  cs_lnum_t n_elts,
77  const cs_lnum_t elt_ids[],
78  cs_real_t profile[]);
79
81 /*--------------------------------------*/
82
83 typedef enum {
84
97
99 /*---------------------------------------*/
100
101 enum {
106 };
107
122 typedef enum {
128
130 /*---------------------------------*/
131
132 typedef enum {
133
136
139
140  /*< Impose spheroids (Jeffery equations for transport) */
142
144
146 /*---------------------------------------*/
147
148 enum {
152 };
153
155 /*----------------------*/
156
157 typedef struct {
158
159  int nusbrd;
162  int ndlaim;
164  int ncharm2;
165  int nlayer;
168
170 /*---------------------*/
171
172 typedef struct {
173
174  int ntersl;
177 } cs_lagr_dim_t;
178
180 /*-----------------------------------------------------*/
181
182 typedef struct {
183
196  int iilagr;
197
198  /* indicates the steady (=1) or unsteady (=0) state of the
199  continuous phase flow
200  in particular, \ref isttio = 1 is needed in order to:
201  calculate steady statistics in the volume or at the boundaries
202  (starting respectively from the iterations
203  \ref cs_lagr_stat_options_t::nstist "nstist")
204  and calculate time-averaged two-way coupling source terms (from the
205  time step \ref nstits).
206  Useful if \ref iilagr = CS_LAGR_ONEWAY_COUPLING
207  or \ref iilagr = CS_LAGR_TWOWAY_COUPLING
208  (if \ref iilagr = CS_LAGR_FROZEN_CONTINUOUS_PHASE,
209  then \ref isttio=1 automatically) */
210  int isttio;
211
217  int isuila;
218
220  int t_order;
221
225
229
235  int ilapoi;
236
253
256
258
260 /*-----------------------------------------------------------*/
261
262 typedef struct {
263
276
283  int modcpl;
284
289  int idistu;
290
295  int idiffl;
296
300
301  int dlvo;
302
306
310
313  int clogging;
314
318  int shape;
319
323
325  int fouling;
326
330
334
336
338
340
342 /*----------------------------------------------*/
343
344 typedef struct {
345
349
353
356
359
362
365
368
371
374
377
380
383
386
389
392
395
398
400
402 /* ---------------------------------------------------------- */
403
404 typedef struct {
405
406  /* activation (=1) or not (=0) of an evolution equation on the particle
407  temperature (in degrees Celsius).
408  Useful if \ref physical_model=1 and if there is a thermal scalar
409  associated with the continuous phase.
410  */
411  int itpvar;
412
413  /* activation (=1) or not (=0) of an evolution equation on the particle
414  diameter. Useful if \ref physical_model = 1.
415  */
416  int idpvar;
417
418  /* activation (=1) or not (=0) of an evolution equation on the particle mass
419  Useful if \ref physical_model = 1
420  */
421  int impvar;
422
423  /* initialization temperature (in degree Celsius) for the particles already
424  present in the calculation domain when an evolution equation on
425  the particle temperature is activated during a calculation
426  (\ref physical_model = 1 and \ref itpvar = 1).
427  Useful if \ref isuila = 1 and \ref itpvar = 0 in the previous calculation.
428  */
430
431  /* initialization value for the specific heat (\f$ J.kg^{-1}.K^{-1} \f$)
432  of the particles already present
433  in the calculation domain when an evolution equation
434  on the particle temperature is activated during a calculation
435  (\ref physical_model = 1 and \ref itpvar = 1).
436  Useful if \ref isuila = 1 and \ref itpvar = 0 in the previous calculation
437  */
439
441
443 /* -------------------------------------- */
444
445 typedef struct {
446
447  /* - 0: no resuspension model
448  - 1: resuspension model */
449  int ireent;
450
451  /* - 0: no head losses calculation for influence of the deposit on the flow
452  - 1: head losses calculation for influence of the deposit on the flow */
453  int iflow;
454
455  /* Parameters of the particle resuspension model*/
461
463
465 /* -------------------------------------- */
466
467 typedef struct {
468
469  /* number of particle classes*/
470  int nbrclas;
471  /* diameter of particles formed by precipitation*/
473  /* density of particles formed by precipitation*/
475  /* number of precipitated particles */
476  int *nbprec;
477  /* */
479  /* number of precipitated particles */
481
483
485 /* ------------------------------------------ */
486
487 typedef struct {
488
493
495
497 /* ------------------------------------------------ */
498
499 typedef struct {
500
502
504
506 /* ------------------------------------------ */
507
508 typedef struct {
509
515
517
519 /* ------------------------------------------ */
520
521 typedef struct {
522
525  cs_real_t (*function_kernel)(cs_lnum_t);
526
528
530 /* ----------------------------------------------- */
531
532 typedef struct {
533
538
540
542 /*----------------------------------*/
543
544 typedef struct {
545
546  /* current step id (for 2nd order scheme) */
547  int nor;
548
549  /* duration of a Lagrangian iteration */
551
552  /* physical time of the Lagrangian simulation */
554
556
558 /*------------------------------------------------------------------*/
559
560 typedef struct {
561
562  int zone_id;
563  int set_id;
574
577
583
588
593  int cluster;
599  cs_real_t velocity[3];
608  cs_real_t orientation[3];
609  cs_real_t radii[3];
610  cs_real_t angular_vel[3];
613  cs_real_t euler[4];
615  cs_real_t shape_param[4];
633
635 /*----------------------------------------------*/
636
637 typedef struct {
638
642  int ltsdyn;
643
648  int ltsmas;
649
650  /* if \ref physical_model = 1 and \ref itpvar = 1, \ref ltsthe
651  activates (=1) or not (=0) the two-way coupling on temperature.
652  if \ref physical_model = 2, \ref ltsthe activates (=1) or not (=0) the
653  two-way coupling on the eulerian variables related to pulverised
654  coal combustion.
655  Useful if \ref iilagr = CS_LAGR_TWOWAY_COUPLING */
656  int ltsthe;
657
660  int itsli;
661
662  /* explicit source term for the turbulent dissipation and the
663  turbulent energy if the \f$k-\varepsilon\f$ turbulence model is used
664  for the continuous phase */
665  int itske;
666
669  int itste;
670
673  int itsti;
674
676  int itsmas;
677
678  /* source term for the light volatile matters */
679  int *itsmv1; //ncharm2
680
681  /* source term for the heavy volatile matters */
682  int *itsmv2; //ncharm2
683
685  int itsco;
686
688  int itsfp4;
689
703  int nstits;
704
706  int npts;
707
710  int ntxerr;
711
714
717
720
722
724 /*----------------------------------------------------*/
725
726 typedef struct {
727
730  int n_zones;
731  int *zone_type;
738  char *elt_type;
746
748 /*---------------------------------------*/
749
750 typedef struct {
751
753
755
757 /*--------------------------------*/
758
759 typedef struct {
760
761  /* Activates (=1) or not (=0) the option of coal particle fouling.
762  It then is necessary to specify the domain boundaries
763  on which fouling may take place. Useful if \ref physical_model = 2*/
764  int iencra;
765
766  /* encrustation data*/
767  int npencr;
768  // TODO cf particles->n_part_fou in cs_lagr_tracking.c
769
770  /* encrustation data*/
771  cs_real_t *enc1; // size: ncharm2
772  /* encrustation data*/
773  cs_real_t *enc2; // size: ncharm2
774
775  /* Limit temperature (in degree Celsius) below which the coal particles do
776  not cause any fouling (if the fouling model is activated).
777  Useful if \ref physical_model = 2 and \ref iencra = 1*/
778  cs_real_t *tprenc; // size: ncharm2
779
780  /* Ash critical viscosity in \f$ kg.m^{-1}.s^{-1} \f$, in the fouling model
781  cf J.D. Watt et T. Fereday (J.Inst.Fuel, Vol.42-p99).
782  Useful if \ref physical_model = 2 and \ref iencra = 1*/
783  cs_real_t *visref; // size: ncharm2
784
785  /* encrustation data */
787
789
791 /*-----------------------------------------*/
792
793 typedef struct {
794
797
801
804
807
810
813
816
818
820 /*-------------------------------*/
821
822 typedef struct {
823
824  int lamvbr;
827
829 /*----------------------------------------------*/
830
831 typedef struct {
832
840  int npstf;
841
848  int npstft;
849
854
858  int iclgst;
859
861  int inbr;
862
864  int inclg;
865
867  int inclgt;
868
870  int iclogt;
871
873  int iclogh;
874
876  int iscovc;
877
878  /* id for mean of particle deposition height */
879  int ihdepm;
880
881  /* id for variance of particle deposition height */
882  int ihdepv;
883
884  /* id for mean diameter of deposited particles */
885  int ihdiam;
886
887  /* id for sum of deposited particle diameters */
888  int ihsum;
889
897
904  char **nombrd;
905
907
909 /*-----------------------------------------------*/
910
911 typedef struct {
912
913  /* Turbulence model */
914  int iturb;
915  int itytur;
916
917  /* cpincl */
918  int ncharb;
919
920  /* ppppar */
921  int ncharm;
922
923  /* radiation */
925
926  /* icp */
927  int icp;
928
929  /* diftl0 */
931
932  /* cmu */
934
935  /* visls0 */
937
938  /* Referenced fields
939  ----------------- */
940
941  /* wall ustar */
943
944  /* Fluid density */
946
947  /* Fluid pressure */
949
950  /* Fluid temparature */
953
954  /* Fluid velocity */
956
957  /* Fluid viscosity */
959
960  /* Fluid viscosity */
962
963  /* Fluid specific heat capacity */
965
966  /* Radiat. */
968
969  /* Combustion */
973
974  /* Turbulence */
975  /* Turbulent intensity */
977
978  /* Turbulent dissipation */
980
981  /* Omega from k-omega SST model*/
983
984  /* Reynolds Stress Tensor */
986
987  /* Total pressure gradient */
989
990  /* velocity gradient */
992
993  /* Lagrangian time field */
995
996  /* Lagrangian time gradient */
998
1000
1002 /*--------------------------------------------*/
1003
1004 typedef struct {
1005
1006  int ih2o; // cpincl
1007  int io2; // cpincl
1008  int ico; // cpincl
1009
1010  int iatc; // ppthch
1011  cs_real_t prefth; // ppthch
1012  cs_real_t trefth; // ppthch
1013
1014  int natom; // = 5;
1015  cs_real_t *wmolat; // dim = natom
1016
1017  int ngazem; // = 20;
1018  cs_real_t *wmole; // ngazem
1019  int *iym1;
1020
1021  int ncharm; // cpincl
1022  cs_real_t *a1ch; // ncharm
1036
1038
1039 /*============================================================================
1040  * Global variables
1041  *============================================================================*/
1042
1046
1050
1053
1056
1059
1060 /* Lagrangian log output every frequency_n time steps */
1061
1062 extern int cs_glob_lagr_log_frequency_n;
1063
1064 /* Statisics on boundaries */
1065
1066 extern cs_real_t *bound_stat;
1067
1073
1076
1084
1087
1091
1092 /* Projection matrices for global to local coordinates on boundary faces */
1094
1095 /*============================================================================
1096  * Public function prototypes
1097  *============================================================================*/
1098
1099 /*----------------------------------------------------------------------------*/
1112 /*----------------------------------------------------------------------------*/
1113
1116  int zone_id,
1117  int set_id);
1118
1119 /*----------------------------------------------------------------------------*/
1125 /*----------------------------------------------------------------------------*/
1126
1127 void
1129
1130 /*----------------------------------------------------------------------------*/
1136 /*----------------------------------------------------------------------------*/
1137
1140
1141 /*----------------------------------------------------------------------------*/
1150 /*----------------------------------------------------------------------------*/
1151
1154
1155 /*----------------------------------------------------------------------------
1156  * Provide access to cs_lagr_particle_counter_t
1157  *
1158  * needed to initialize structure with GUI
1159  *----------------------------------------------------------------------------*/
1160
1163
1164 /*----------------------------------------------------------------------------
1165  * Provide access to cs_lagr_reentrained_model_t
1166  *
1167  * needed to initialize structure with GUI
1168  *----------------------------------------------------------------------------*/
1169
1172
1173 /*----------------------------------------------------------------------------
1174  * Provide access to cs_lagr_precipitation_model_t
1175  *
1176  * needed to initialize structure with GUI
1177  *----------------------------------------------------------------------------*/
1178
1181
1182 /*----------------------------------------------------------------------------
1183  * Provide access to cs_lagr_clogging_model_t
1184  *
1185  * needed to initialize structure with GUI
1186  *----------------------------------------------------------------------------*/
1187
1190
1191 /*----------------------------------------------------------------------------
1192  * Provide access to cs_lagr_shape_model_t
1193  *
1194  * needed to initialize structure with GUI
1195  *----------------------------------------------------------------------------*/
1196
1199
1200 /*----------------------------------------------------------------------------
1201  * Provide access to cs_lagr_agglomeration_model_t
1202  *
1203  * needed to initialize structure with GUI
1204  *----------------------------------------------------------------------------*/
1205
1208
1209 /*----------------------------------------------------------------------------
1210  * Provide access to cs_lagr_consolidation_model_t
1211  *
1212  * needed to initialize structure with GUI
1213  *----------------------------------------------------------------------------*/
1214
1217
1218 /*----------------------------------------------------------------------------
1219  * Provide access to cs_lagr_time_step_t
1220  *
1221  * needed to initialize structure with GUI
1222  *----------------------------------------------------------------------------*/
1223
1225 cs_get_lagr_time_step(void);
1226
1227 /*----------------------------------------------------------------------------
1228  * Provide access to cs_lagr_source_terms_t
1229  *
1230  * needed to initialize structure with GUI
1231  *----------------------------------------------------------------------------*/
1232
1235
1236 /*----------------------------------------------------------------------------
1237  * Provide access to cs_lagr_encrustation_t
1238  *
1239  * needed to initialize structure with GUI
1240  *----------------------------------------------------------------------------*/
1241
1244
1245 /*----------------------------------------------------------------------------
1246  * Provide access to cs_lagr_physico_chemical_t
1247  *
1248  * needed to initialize structure with GUI
1249  *----------------------------------------------------------------------------*/
1250
1253
1254 /*----------------------------------------------------------------------------
1255  * Provide access to cs_lagr_brownian_t
1256  *
1257  * needed to initialize structure with GUI
1258  *----------------------------------------------------------------------------*/
1259
1261 cs_get_lagr_brownian(void);
1262
1263 /*----------------------------------------------------------------------------*/
1269 /*----------------------------------------------------------------------------*/
1270
1273
1274 /*----------------------------------------------------------------------------*/
1280 /*----------------------------------------------------------------------------*/
1281
1284
1285 /*----------------------------------------------------------------------------*/
1293 /*----------------------------------------------------------------------------*/
1294
1297
1298 /*----------------------------------------------------------------------------*/
1302 /*----------------------------------------------------------------------------*/
1303
1304 void
1306
1307 /*----------------------------------------------------------------------------
1308  * Destroy finalize the global cs_lagr_internal_condition_t structure.
1309  *----------------------------------------------------------------------------*/
1310
1311 void
1313
1314 /*----------------------------------------------------------------------------
1315  * Provide access to cs_lagr_boundary_interactions_t
1316  *
1317  * needed to initialize structure with GUI
1318  *----------------------------------------------------------------------------*/
1319
1322
1323 /*----------------------------------------------------------------------------
1324  * Provide access to cs_lagr_extra_module_t
1325  *----------------------------------------------------------------------------*/
1326
1329
1330 /*----------------------------------------------------------------------------
1331  * Prepare for execution of the Lagrangian model.
1332  *
1333  * This should be called before the fist call to cs_lagr_solve_time_step.
1334  *
1335  * parameters:
1336  * dt <-- time step (per cell)
1337  *----------------------------------------------------------------------------*/
1338
1339 void
1341
1342 /*----------------------------------------------------------------------------
1343  * Return pointers to lagrangian arrays
1344  *
1345  * This function is intended for use by Fortran wrappers.
1346  *
1347  * parameters:
1348  * dim_bound_stat --> dimensions for bound_stat pointer
1349  * p_bound_stat --> bound_stat pointer
1350  *----------------------------------------------------------------------------*/
1351
1352 void
1353 cs_lagr_init_c_arrays(int dim_cs_glob_lagr_source_terms[2],
1354  cs_real_t **p_cs_glob_lagr_source_terms);
1355
1356 /*----------------------------------------------------------------------------
1357  * Free lagrangian arrays
1358  *
1359  * This function is intended for use by Fortran wrappers.
1360  *----------------------------------------------------------------------------*/
1361
1362 void
1363 cs_lagr_finalize(void);
1364
1365 /*----------------------------------------------------------------------------*/
1374 /*----------------------------------------------------------------------------*/
1375
1376 void
1377 cs_lagr_add_fields(void);
1378
1379 /*--------------------------------------------------------------------
1380  * Execute one time step of the Lagrangian model.
1381  *
1382  * This is the main function for that model.
1383  *
1384  * parameters:
1385  * itypfb <-- boundary face types
1386  * dt <-- time step (per cell)
1387  *-------------------------------------------------------------------- */
1388
1389 void
1390 cs_lagr_solve_time_step(const int itypfb[],
1391  const cs_real_t *dt);
1392
1393 /*----------------------------------------------------------------------------*/
1394
1396
1397 #endif /* __CS_LAGR_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:332
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:298
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:341
Definition: cs_defs.h:313
@ dt
cs_lagr_encrustation_t * cs_get_lagr_encrustation(void)
Definition: cs_lagr.c:1591
cs_lagr_source_terms_t * cs_glob_lagr_source_terms
void cs_lagr_finalize_internal_cond(void)
Definition: cs_lagr.c:1744
cs_lagr_internal_condition_t * cs_glob_lagr_internal_conditions
cs_lagr_boundary_interactions_t * cs_glob_lagr_boundary_interactions
cs_lagr_consolidation_model_t * cs_glob_lagr_consolidation_model
cs_lagr_consolidation_model_t * cs_get_lagr_consolidation_model(void)
Definition: cs_lagr.c:1555
cs_real_t * bound_stat
cs_lagr_injection_set_t * cs_lagr_get_injection_set(cs_lagr_zone_data_t *zone_data, int zone_id, int set_id)
Provide access to injection set structure.
Definition: cs_lagr.c:1306
cs_lagr_module_shape_t
Definition: cs_lagr.h:132
@ CS_LAGR_SHAPE_SPHEROID_STOC_MODEL
Definition: cs_lagr.h:138
@ CS_LAGR_SHAPE_SPHERE_MODEL
Definition: cs_lagr.h:135
@ CS_LAGR_SHAPE_SPHEROID_JEFFERY_MODEL
Definition: cs_lagr.h:141
void cs_lagr_solve_time_step(const int itypfb[], const cs_real_t *dt)
Definition: cs_lagr.c:1854
cs_lagr_particle_counter_t * cs_lagr_get_particle_counter(void)
Get read/write pointer to global particle counter.
Definition: cs_lagr.c:1406
const cs_lagr_const_dim_t * cs_glob_lagr_const_dim
cs_lagr_model_t * cs_glob_lagr_model
cs_lagr_extra_module_t * cs_glob_lagr_extra_module
cs_lagr_bc_type
Definition: cs_lagr.h:83
@ CS_LAGR_OUTLET
Definition: cs_lagr.h:88
@ CS_LAGR_INLET
Definition: cs_lagr.h:87
@ CS_LAGR_DEPO2
Definition: cs_lagr.h:91
@ CS_LAGR_DEPO1
Definition: cs_lagr.h:90
@ CS_LAGR_BC_USER
Definition: cs_lagr.h:94
@ CS_LAGR_FOULING
Definition: cs_lagr.h:93
@ CS_LAGR_BC_UNDEFINED
Definition: cs_lagr.h:85
@ CS_LAGR_SYM
Definition: cs_lagr.h:86
@ CS_LAGR_DEPO_DLVO
Definition: cs_lagr.h:92
@ CS_LAGR_REBOUND
Definition: cs_lagr.h:89
cs_lagr_encrustation_t * cs_glob_lagr_encrustation
cs_lagr_internal_condition_t * cs_lagr_get_internal_conditions(void)
Return pointer to the main internal conditions structure.
Definition: cs_lagr.c:1631
const cs_lagr_zone_data_t * cs_glob_lagr_boundary_conditions
cs_lagr_agglomeration_model_t * cs_glob_lagr_agglomeration_model
cs_lagr_time_step_t * cs_get_lagr_time_step(void)
Definition: cs_lagr.c:1567
cs_lagr_specific_physics_t * cs_glob_lagr_specific_physics
cs_lagr_fragmentation_model_t * cs_glob_lagr_fragmentation_model
cs_lagr_extra_module_t * cs_get_lagr_extra_module(void)
Definition: cs_lagr.c:1773
cs_lagr_agglomeration_model_t * cs_get_lagr_agglomeration_model(void)
Definition: cs_lagr.c:1543
cs_lagr_reentrained_model_t * cs_glob_lagr_reentrained_model
void cs_lagr_add_fields(void)
Create additional fields needed by the Lagrangien model.
Definition: cs_lagr.c:1233
cs_lagr_zone_data_t * cs_lagr_get_volume_conditions(void)
Return pointer to the main volume conditions structure.
Definition: cs_lagr.c:1689
cs_lagr_physico_chemical_t * cs_glob_lagr_physico_chemical
cs_lagr_clogging_model_t * cs_get_lagr_clogging_model(void)
Definition: cs_lagr.c:1519
cs_lagr_precipitation_model_t * cs_glob_lagr_precipitation_model
cs_lagr_coal_comb_t * cs_glob_lagr_coal_comb
void cs_lagr_solve_initialize(const cs_real_t *dt)
Definition: cs_lagr.c:1788
cs_lagr_brownian_t * cs_get_lagr_brownian(void)
Definition: cs_lagr.c:1615
void cs_lagr_injection_set_default(cs_lagr_injection_set_t *zis)
Initialize injection set data structure fields to defaults.
Definition: cs_lagr.c:1333
@ CS_LAGR_PHYS_COAL
Definition: cs_lagr.h:151
@ CS_LAGR_PHYS_OFF
Definition: cs_lagr.h:149
@ CS_LAGR_PHYS_HEAT
Definition: cs_lagr.h:150
void cs_lagr_init_c_arrays(int dim_cs_glob_lagr_source_terms[2], cs_real_t **p_cs_glob_lagr_source_terms)
Definition: cs_lagr.c:1126
cs_lagr_physico_chemical_t * cs_get_lagr_physico_chemical(void)
Definition: cs_lagr.c:1603
cs_lagr_particle_counter_t * cs_lagr_update_particle_counter(void)
Update global particle counter.
Definition: cs_lagr.c:1423
@ CS_LAGR_IN_IMPOSED_COMPONENTS
Definition: cs_lagr.h:105
@ CS_LAGR_IN_IMPOSED_NORM
Definition: cs_lagr.h:104
@ CS_LAGR_IN_IMPOSED_FLUID_VALUE
Definition: cs_lagr.h:102
cs_lagr_brownian_t * cs_glob_lagr_brownian
const cs_lagr_zone_data_t * cs_glob_lagr_volume_conditions
cs_lagr_source_terms_t * cs_get_lagr_source_terms(void)
Definition: cs_lagr.c:1579
cs_lagr_module_status_t
Definition: cs_lagr.h:122
@ CS_LAGR_OFF
Definition: cs_lagr.h:123
@ CS_LAGR_ONEWAY_COUPLING
Definition: cs_lagr.h:124
@ CS_LAGR_TWOWAY_COUPLING
Definition: cs_lagr.h:125
@ CS_LAGR_FROZEN_CONTINUOUS_PHASE
Definition: cs_lagr.h:126
cs_real_33_t * cs_glob_lagr_b_face_proj
void() cs_lagr_injection_profile_compute_t(int zone_id, int location_id, const void *input, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t profile[])
Function pointer for computation of particle injection profile.
Definition: cs_lagr.h:73
cs_lagr_precipitation_model_t * cs_get_lagr_precipitation_model(void)
Provide access to cs_lagr_precipitation_model_t.
Definition: cs_lagr.c:1507
void cs_lagr_finalize_zone_conditions(void)
Finalize the global boundary and volume condition structures.
Definition: cs_lagr.c:1713
cs_lagr_time_step_t * cs_glob_lagr_time_step
cs_lagr_specific_physics_t * cs_get_lagr_specific_physics(void)
Provide access to cs_lagr_specific_physics_t.
Definition: cs_lagr.c:1480
cs_lagr_zone_data_t * cs_lagr_get_boundary_conditions(void)
Return pointer to the main boundary conditions structure.
Definition: cs_lagr.c:1665
const cs_lagr_particle_counter_t * cs_glob_lagr_particle_counter
cs_lagr_shape_model_t * cs_get_lagr_shape_model(void)
Definition: cs_lagr.c:1531
cs_lagr_reentrained_model_t * cs_get_lagr_reentrained_model(void)
Provide access to cs_lagr_reentrained_model_t.
Definition: cs_lagr.c:1494
cs_lagr_dim_t * cs_glob_lagr_dim
void cs_lagr_finalize(void)
Definition: cs_lagr.c:1158
cs_lagr_boundary_interactions_t * cs_get_lagr_boundary_interactions(void)
Definition: cs_lagr.c:1762
cs_lagr_shape_model_t * cs_glob_lagr_shape_model
cs_lagr_time_scheme_t * cs_glob_lagr_time_scheme
cs_lagr_clogging_model_t * cs_glob_lagr_clogging_model
integer, dimension(:), pointer, save itypfb
boundary condition type at the boundary face ifac (see cs_user_boundary_conditions)
Definition: pointe.f90:100
Definition: cs_field.h:130
Definition: cs_lagr.h:508
cs_real_t base_diameter
Definition: cs_lagr.h:514
cs_real_t scalar_kernel
Definition: cs_lagr.h:513
cs_real_t max_stat_weight
Definition: cs_lagr.h:512
cs_lnum_t n_max_classes
Definition: cs_lagr.h:510
cs_real_t min_stat_weight
Definition: cs_lagr.h:511
Definition: cs_lagr.h:831
int iclogt
Definition: cs_lagr.h:870
int inclg
Definition: cs_lagr.h:864
int has_part_impact_nbr
Definition: cs_lagr.h:853
char ** nombrd
Definition: cs_lagr.h:904
int npstft
Definition: cs_lagr.h:848
int ihdepm
Definition: cs_lagr.h:879
int inclgt
Definition: cs_lagr.h:867
int inbr
Definition: cs_lagr.h:861
int iscovc
Definition: cs_lagr.h:876
int npstf
Definition: cs_lagr.h:840
cs_real_t tstatp
Definition: cs_lagr.h:896
int ihsum
Definition: cs_lagr.h:888
int iclgst
Definition: cs_lagr.h:858
int iclogh
Definition: cs_lagr.h:873
int ihdepv
Definition: cs_lagr.h:882
int ihdiam
Definition: cs_lagr.h:885
Definition: cs_lagr.h:822
int lamvbr
Definition: cs_lagr.h:824
Definition: cs_lagr.h:487
cs_real_t jamlim
Definition: cs_lagr.h:489
cs_real_t diam_mean
Definition: cs_lagr.h:492
cs_real_t mporos
Definition: cs_lagr.h:490
cs_real_t csthpp
Definition: cs_lagr.h:491
Definition: cs_lagr.h:1004
cs_real_t * h02ch
Definition: cs_lagr.h:1023
int iatc
Definition: cs_lagr.h:1010
cs_real_t * xwatch
Definition: cs_lagr.h:1033
cs_real_t * y2ch
Definition: cs_lagr.h:1028
cs_real_t * e1ch
Definition: cs_lagr.h:1024
int ih2o
Definition: cs_lagr.h:1006
int ngazem
Definition: cs_lagr.h:1017
cs_real_t * e2ch
Definition: cs_lagr.h:1026
cs_real_t * a1ch
Definition: cs_lagr.h:1022
cs_real_t * ehetch
Definition: cs_lagr.h:1031
int natom
Definition: cs_lagr.h:1014
cs_real_t prefth
Definition: cs_lagr.h:1011
int * iym1
Definition: cs_lagr.h:1019
cs_real_t * thcdch
Definition: cs_lagr.h:1035
cs_real_t * xashch
Definition: cs_lagr.h:1034
cs_real_t trefth
Definition: cs_lagr.h:1012
cs_real_t * wmole
Definition: cs_lagr.h:1018
int io2
Definition: cs_lagr.h:1007
cs_real_t * rho0ch
Definition: cs_lagr.h:1032
cs_real_t * a2ch
Definition: cs_lagr.h:1025
cs_real_t * cp2ch
Definition: cs_lagr.h:1029
cs_real_t * ahetch
Definition: cs_lagr.h:1030
cs_real_t * wmolat
Definition: cs_lagr.h:1015
int ico
Definition: cs_lagr.h:1008
int ncharm
Definition: cs_lagr.h:1021
cs_real_t * y1ch
Definition: cs_lagr.h:1027
Definition: cs_lagr.h:532
cs_real_t force_consol
Definition: cs_lagr.h:537
cs_real_t slope_consol
Definition: cs_lagr.h:536
cs_lnum_t iconsol
Definition: cs_lagr.h:534
cs_real_t rate_consol
Definition: cs_lagr.h:535
Definition: cs_lagr.h:157
int ndlaim
Definition: cs_lagr.h:162
int ncharm2
Definition: cs_lagr.h:164
int nlayer
Definition: cs_lagr.h:165
int nusbrd
Definition: cs_lagr.h:159
Definition: cs_lagr.h:172
int ntersl
Definition: cs_lagr.h:174
int n_boundary_stats
Definition: cs_lagr.h:175
Definition: cs_lagr.h:759
cs_real_t * visref
Definition: cs_lagr.h:783
cs_real_t dnpenc
Definition: cs_lagr.h:786
int iencra
Definition: cs_lagr.h:764
cs_real_t * tprenc
Definition: cs_lagr.h:778
cs_real_t * enc2
Definition: cs_lagr.h:773
int npencr
Definition: cs_lagr.h:767
cs_real_t * enc1
Definition: cs_lagr.h:771
Definition: cs_lagr.h:911
cs_field_t * scal_t
Definition: cs_lagr.h:951
cs_field_t * vel
Definition: cs_lagr.h:955
int itytur
Definition: cs_lagr.h:915
cs_field_t * cpro_cp
Definition: cs_lagr.h:964
cs_field_t * cvar_omg
Definition: cs_lagr.h:982
cs_real_3_t * grad_lagr_time
Definition: cs_lagr.h:997
cs_field_t * viscl
Definition: cs_lagr.h:958
cs_field_t * x_eau
Definition: cs_lagr.h:971
cs_field_t * luminance
Definition: cs_lagr.h:967
cs_field_t * cvar_ep
Definition: cs_lagr.h:979
cs_field_t * lagr_time
Definition: cs_lagr.h:994
cs_field_t * x_oxyd
Definition: cs_lagr.h:970
int ncharb
Definition: cs_lagr.h:918
cs_field_t * pressure
Definition: cs_lagr.h:948
cs_real_33_t * grad_vel
Definition: cs_lagr.h:991
cs_field_t * temperature
Definition: cs_lagr.h:952
cs_real_t cmu
Definition: cs_lagr.h:933
cs_real_3_t * grad_pr
Definition: cs_lagr.h:988
cs_field_t * cvar_k
Definition: cs_lagr.h:976
cs_field_t * x_m
Definition: cs_lagr.h:972
cs_field_t * ustar
Definition: cs_lagr.h:942
int icp
Definition: cs_lagr.h:927
cs_field_t * cromf
Definition: cs_lagr.h:945
cs_field_t * cpro_viscls
Definition: cs_lagr.h:961
int radiative_model
Definition: cs_lagr.h:924
cs_real_t diftl0
Definition: cs_lagr.h:930
int ncharm
Definition: cs_lagr.h:921
cs_field_t * cvar_rij
Definition: cs_lagr.h:985
cs_real_t visls0
Definition: cs_lagr.h:936
int iturb
Definition: cs_lagr.h:914
Definition: cs_lagr.h:521
Definition: cs_lagr.h:524
Definition: cs_lagr.h:523
Definition: cs_lagr.h:560
cs_real_t diameter_variance
Definition: cs_lagr.h:604
cs_real_t density
Definition: cs_lagr.h:620
int injection_frequency
Definition: cs_lagr.h:569
int temperature_profile
Definition: cs_lagr.h:587
cs_real_t shape
Definition: cs_lagr.h:606
cs_real_t velocity_magnitude
Definition: cs_lagr.h:598
int velocity_profile
Definition: cs_lagr.h:582
cs_real_t cp
Definition: cs_lagr.h:624
cs_lagr_injection_profile_compute_t * injection_profile_func
Definition: cs_lagr.h:573
cs_real_t diameter
Definition: cs_lagr.h:603
cs_gnum_t n_inject
Definition: cs_lagr.h:566
int cluster
Definition: cs_lagr.h:593
int location_id
Definition: cs_lagr.h:564
cs_real_t fouling_index
Definition: cs_lagr.h:622
int coal_number
Definition: cs_lagr.h:589
void * injection_profile_input
Definition: cs_lagr.h:576
cs_real_t flow_rate
Definition: cs_lagr.h:628
int zone_id
Definition: cs_lagr.h:562
int set_id
Definition: cs_lagr.h:563
int aggregat_class_id
Definition: cs_lagr.h:595
cs_real_t emissivity
Definition: cs_lagr.h:630
cs_real_t stat_weight
Definition: cs_lagr.h:626
cs_real_t temperature
Definition: cs_lagr.h:601
cs_real_t aggregat_fractal_dim
Definition: cs_lagr.h:596
Definition: cs_lagr.h:750
int * i_face_zone_id
Definition: cs_lagr.h:752
Definition: cs_lagr.h:262
int dlvo
Definition: cs_lagr.h:301
int n_stat_classes
Definition: cs_lagr.h:335
int deposition
Definition: cs_lagr.h:299
int physical_model
Definition: cs_lagr.h:274
int fragmentation
Definition: cs_lagr.h:333
int roughness
Definition: cs_lagr.h:305
int precipitation
Definition: cs_lagr.h:324
int n_user_variables
Definition: cs_lagr.h:337
int idistu
Definition: cs_lagr.h:289
int shape
Definition: cs_lagr.h:318
int fouling
Definition: cs_lagr.h:325
int n_temperature_layers
Definition: cs_lagr.h:275
int modcpl
Definition: cs_lagr.h:283
int agglomeration
Definition: cs_lagr.h:329
int consolidation
Definition: cs_lagr.h:322
int resuspension
Definition: cs_lagr.h:309
int clogging
Definition: cs_lagr.h:313
int idiffl
Definition: cs_lagr.h:295
Definition: cs_lagr.h:344
cs_gnum_t n_g_cumulative_total
Definition: cs_lagr.h:348
cs_real_t w_exit
Definition: cs_lagr.h:385
cs_gnum_t n_g_new
Definition: cs_lagr.h:358
cs_gnum_t n_g_resuspended
Definition: cs_lagr.h:373
cs_gnum_t n_g_exit
Definition: cs_lagr.h:361
cs_real_t w_fouling
Definition: cs_lagr.h:394
cs_real_t w_total
Definition: cs_lagr.h:379
cs_gnum_t n_g_failed
Definition: cs_lagr.h:376
cs_gnum_t n_g_fouling
Definition: cs_lagr.h:370
cs_gnum_t n_g_total
Definition: cs_lagr.h:355
cs_real_t w_resuspended
Definition: cs_lagr.h:397
cs_real_t w_deposited
Definition: cs_lagr.h:391
cs_gnum_t n_g_merged
Definition: cs_lagr.h:364
cs_gnum_t n_g_cumulative_failed
Definition: cs_lagr.h:352
cs_real_t w_merged
Definition: cs_lagr.h:388
cs_gnum_t n_g_deposited
Definition: cs_lagr.h:367
cs_real_t w_new
Definition: cs_lagr.h:382
Definition: cs_lagr.h:793
cs_real_t cstham
Definition: cs_lagr.h:796
cs_real_t fion
Definition: cs_lagr.h:815
cs_real_t phi_s
Definition: cs_lagr.h:809
cs_real_t lambda_vdw
Definition: cs_lagr.h:800
cs_real_t epseau
Definition: cs_lagr.h:803
cs_real_t phi_p
Definition: cs_lagr.h:806
cs_real_t valen
Definition: cs_lagr.h:812
Definition: cs_lagr.h:467
cs_real_t diameter
Definition: cs_lagr.h:472
int nbrclas
Definition: cs_lagr.h:470
cs_real_t * mp_diss
Definition: cs_lagr.h:480
cs_real_t rho
Definition: cs_lagr.h:474
int * nbprec
Definition: cs_lagr.h:476
cs_real_t * solub
Definition: cs_lagr.h:478
Definition: cs_lagr.h:445
int iflow
Definition: cs_lagr.h:453
cs_real_t denasp
Definition: cs_lagr.h:457
int ireent
Definition: cs_lagr.h:449
cs_real_t rayasp
Definition: cs_lagr.h:459
cs_real_t modyeq
Definition: cs_lagr.h:458
cs_real_t rayasg
Definition: cs_lagr.h:460
cs_real_t espasg
Definition: cs_lagr.h:456
Definition: cs_lagr.h:499
cs_real_t param_chmb
Definition: cs_lagr.h:501
Definition: cs_lagr.h:637
int npts
Definition: cs_lagr.h:706
int itsmas
Definition: cs_lagr.h:676
int itsfp4
Definition: cs_lagr.h:688
int ltsmas
Definition: cs_lagr.h:648
int * itsmv1
Definition: cs_lagr.h:679
cs_real_t vmax
Definition: cs_lagr.h:713
cs_real_t tmamax
Definition: cs_lagr.h:716
int itsli
Definition: cs_lagr.h:660
cs_real_t * st_val
Definition: cs_lagr.h:719
int itsti
Definition: cs_lagr.h:673
int ltsthe
Definition: cs_lagr.h:656
int itsco
Definition: cs_lagr.h:685
int ntxerr
Definition: cs_lagr.h:710
int itste
Definition: cs_lagr.h:669
int * itsmv2
Definition: cs_lagr.h:682
int ltsdyn
Definition: cs_lagr.h:642
int nstits
Definition: cs_lagr.h:703
int itske
Definition: cs_lagr.h:665
Definition: cs_lagr.h:404
int itpvar
Definition: cs_lagr.h:411
cs_real_t tpart
Definition: cs_lagr.h:429
cs_real_t cppart
Definition: cs_lagr.h:438
int idpvar
Definition: cs_lagr.h:416
int impvar
Definition: cs_lagr.h:421
Definition: cs_lagr.h:182
int interpol_field
Definition: cs_lagr.h:228
int isttio
Definition: cs_lagr.h:210
int ilapoi
Definition: cs_lagr.h:235
int extended_t_scheme
Definition: cs_lagr.h:224
int isuila
Definition: cs_lagr.h:217
cs_real_t added_mass_const
Definition: cs_lagr.h:255
int t_order
Definition: cs_lagr.h:220
int iilagr
Definition: cs_lagr.h:196
int iadded_mass
Definition: cs_lagr.h:252
Definition: cs_lagr.h:544
cs_real_t dtp
Definition: cs_lagr.h:550
cs_real_t ttclag
Definition: cs_lagr.h:553
int nor
Definition: cs_lagr.h:547
Definition: cs_lagr.h:726
int n_zones
Definition: cs_lagr.h:730
cs_lagr_injection_set_t ** injection_set
Definition: cs_lagr.h:735
char * elt_type
Definition: cs_lagr.h:738
int * zone_type
Definition: cs_lagr.h:731
int location_id
Definition: cs_lagr.h:728
int * n_injection_sets
Definition: cs_lagr.h:733
cs_real_t * particle_flow_rate
Definition: cs_lagr.h:741
