Include dependency graph for cs_hgn_thermo.h:Go to the source code of this file.
| cs_real_t | cs_hgn_thermo_saturation_temp (cs_real_t pr) |
| Computation of the temperature at saturation with respect to the pressure. More... | |
| void | cs_hgn_thermo_pt (cs_real_t alpha, cs_real_t y, cs_real_t z, cs_real_t e, cs_real_t v, cs_real_t *ptp, cs_real_t *ppr) |
| Computation mixture pressure and temperature from volume, mass, energy fractions, as well as specific energy and specific volume. More... | |
| cs_real_t | cs_hgn_thermo_c2 (cs_real_t alpha, cs_real_t y, cs_real_t z, cs_real_t P, cs_real_t v) |
| Computation of the square of the sound speed in the mixture. More... | |
| cs_real_t | cs_hgn_thermo_ie (cs_real_t alpha, cs_real_t y, cs_real_t z, cs_real_t pr, cs_real_t v) |
| Computation of the specific internal energy with respect to the volume ( | |
| void | cs_hgn_thermo_eq (cs_real_t e, cs_real_t v, cs_real_t *palpha_eq, cs_real_t *py_eq, cs_real_t *pz_eq) |
| Computation of the equilibrium fractions. More... | |
The sound speed may be computed through the Hessian matrices of the specific phasic entropies in the plane (
stands for specific volume, and
for specific energy. The sound speed is here estimated using the plane (
stands for specific entropy. We use the definition
. This relation is computed by a finite difference.
| [in] | alpha | volume fraction |
| [in] | y | mass fraction |
| [in] | z | energy fraction |
| [in] | P | pressure |
| [in] | v | specific volume |
| void cs_hgn_thermo_eq | ( | cs_real_t | e, |
| cs_real_t | v, | ||
| cs_real_t * | palpha_eq, | ||
| cs_real_t * | py_eq, | ||
| cs_real_t * | pz_eq | ||
The equilibrium fractions correspond to the definition of the mixture for which one gets the pressure, temperature and chemical potential equilibrium.
They are computed by using a Dichotomy algorithm on the function characterizing the equilibrium (two forms available).
The search for the equilibrium point is done in plane (P,T). Dichotomy is performed on the pressure along the saturation curve.
| [in] | e | specific internal energy |
| [out] | palpha_eq | pointer to equilibrium volume fraction |
| [out] | py_eq | pointer to equilibrium mass fraction |
| [out] | pz_eq | pointer to equilibrium energy fraction |
), mass (
) and energy (
) fractions, as well as the pressure and the specific volume
It uses a quasi-Newton method to solve:
| [in] | alpha | the volume fraction |
| [in] | y | the mass fraction |
| [in] | z | the energy fraction |
| [in] | pr | the pressure |
| [in] | v | the specific volume |
| void cs_hgn_thermo_pt | ( | cs_real_t | alpha, |
| cs_real_t | y, | ||
| cs_real_t | z, | ||
| cs_real_t | e, | ||
| cs_real_t | v, | ||
| cs_real_t * | ptp, | ||
| cs_real_t * | ppr | ||
Following relations are used, that rely on phasic pressures and temperatures:
| [in] | e | specific energy |
| [out] | ptp | pointer to mixture temperature |
| [out] | ppr | pointer to mixture pressure |
Compute the temperature at saturation
. It corresponds to the temperature for which the pressure, temperature and chemical potential are equal in both phases. It reduces to solve the equality of the phasic chemical potential:
This equality is solved using a Newton method.
| [in] | pr | pressure |
This equality is solved using a secant method.
