#include "cs_boundary.h"
#include "cs_zone.h"
| void  | uiclim (const int *nozppm, int *iqimp, int *icalke, int *ientat, int *ientcp, int *inmoxy, int *ientox, int *ientfu, int *ientgf, int *ientgb, int *iprofm, int *iautom, int *itypfb, int *izfppp, double *qimp, double *qimpat, double *qimpcp, double *dh, double *xintur, double *timpat, double *timpcp, double *tkent, double *fment, double *distch) |
| void  | uiclve (const int *nozppm) |
| void  | cs_gui_boundary_conditions_define (cs_boundary_t *bdy) |
|   | Define boundary conditions based on setup file.  More...
| void  | cs_gui_boundary_conditions_free_memory (void) |
|   | Free GUI boundary condition structures.  More...
| cs_gui_boundary_meg_context_t *  | cs_gui_boundary_add_meg_context (const cs_zone_t *zone, const char *name, const char *condition, int dim) |
|   | Add new MEG-based cs_dof_func_t context info.  More...
| void  | cs_gui_boundary_conditions_dof_func_meg (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval) |
|   | cs_dof_func_t function to compute a boundary profiles using a MEG generated function.  More...
◆ cs_gui_boundary_add_meg_context()
- Parameters
    | [in] | zone | pointer to associated zone  |
    | [in] | name | name of associated field or array  |
    | [in] | condition | associated condition type  |
    | [in] | dim | associated dimension |
- Returns
 - : pointer to cs_dof_func_t context info
◆ cs_gui_boundary_conditions_define()
- Parameters
    | [in,out] | bdy | boundaries structure to update (if NULL, default to cs_glob_domain->boundaries)  |
◆ cs_gui_boundary_conditions_dof_func_meg()
          | void cs_gui_boundary_conditions_dof_func_meg  |
          cs_lnum_t  |
          n_elts,  |
          const cs_lnum_t *  |
          elt_ids,  |
          bool  |
          dense_output,  |
          void *  |
          input,  |
          cs_real_t *  |
          retval  |
For the calling function, elt_ids is optional. If not NULL, array(s) should be accessed with an indirection. The same indirection can be applied to fill retval if dense_output is set to false. In the current case, retval is allocated to mesh->n_b_faces
- Parameters
    | [in] | n_elts | number of elements to consider  |
    | [in] | elt_ids | list of elements ids  |
    | [in] | dense_output | perform an indirection in retval or not  |
    | [in] | input | NULL or pointer to a structure cast on-the-fly  |
    | [in,out] | retval | resulting value(s). Must be allocated. |
- Parameters
◆ cs_gui_boundary_conditions_free_memory()
          | void cs_gui_boundary_conditions_free_memory  |
          void  |
◆ uiclim()
          | void uiclim  |
          const int *  |
          nozppm,  |
          int *  |
          iqimp,  |
          int *  |
          icalke,  |
          int *  |
          ientat,  |
          int *  |
          ientcp,  |
          int *  |
          inmoxy,  |
          int *  |
          ientox,  |
          int *  |
          ientfu,  |
          int *  |
          ientgf,  |
          int *  |
          ientgb,  |
          int *  |
          iprofm,  |
          int *  |
          iautom,  |
          int *  |
          itypfb,  |
          int *  |
          izfppp,  |
          double *  |
          qimp,  |
          double *  |
          qimpat,  |
          double *  |
          qimpcp,  |
          double *  |
          dh,  |
          double *  |
          xintur,  |
          double *  |
          timpat,  |
          double *  |
          timpcp,  |
          double *  |
          tkent,  |
          double *  |
          fment,  |
          double *  |
          distch  |
◆ uiclve()
          | void uiclve  |
          const int *  |
          nozppm | ) |
