1 #ifndef __CS_CDOVB_VECTEQ_H__
2 #define __CS_CDOVB_VECTEQ_H__
void cs_cdovb_vecteq_solve_steady_state(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build and solve the linear system arising from a vector steady-state convection/diffusion/reaction eq...
Definition: cs_cdovb_vecteq.c:1345
bool cs_cdovb_vecteq_is_initialized(void)
Check if the generic structures for building a CDO-Vb scheme are allocated.
Definition: cs_cdovb_vecteq.c:703
void cs_cdovb_vecteq_finalize_sharing(void)
Free work buffer and general structure related to CDO vertex-based schemes.
Definition: cs_cdovb_vecteq.c:803
void cs_cdovb_vecteq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions....
Definition: cs_cdovb_vecteq.c:1227
void cs_cdovb_vecteq_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffer and general structures related to CDO vector-valued vertex-based schemes Set sha...
Definition: cs_cdovb_vecteq.c:724
cs_real_t * cs_cdovb_vecteq_get_vertex_values(void *context, bool previous)
Retrieve an array of values at mesh vertices for the variable field associated to the given context T...
Definition: cs_cdovb_vecteq.c:1613
void cs_cdovb_vecteq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Definition: cs_cdovb_vecteq.c:786
void * cs_cdovb_vecteq_free_context(void *builder)
Destroy a cs_cdovb_vecteq_t structure.
Definition: cs_cdovb_vecteq.c:1190
void * cs_cdovb_vecteq_init_context(const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_cdovb_vecteq_t structure storing data useful for building and managing such a scheme.
Definition: cs_cdovb_vecteq.c:839
void cs_cdovb_vecteq_update_field(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values if required (...
Definition: cs_cdovb_vecteq.c:1575
void cs_cdovb_vecteq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdovb_vecteq.c:1717
cs_real_t * cs_cdovb_vecteq_get_cell_values(void *context, bool previous)
Compute an array of values at mesh cells by interpolating the variable field associated to the given ...
Definition: cs_cdovb_vecteq.c:1645
void cs_cdovb_vecteq_current_to_previous(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Operate a current to previous operation for the field associated to this equation and potentially for...
Definition: cs_cdovb_vecteq.c:1693
Definition: cs_defs.h:509
Definition: cs_defs.h:319
double precision, dimension(:,:), allocatable solu
Definition: atincl.f90:321
Definition: cs_cdo_quantities.h:137
Definition: cs_cdo_local.h:60
time step descriptor
Definition: cs_time_step.h:64
