static cs_real_t * | cs_cdofb_ac_get_face_velocity (bool previous) |
| Retrieve the values of the velocity on the faces. More...
void | cs_cdofb_ac_init_common (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step) |
| Set shared pointers from the main domain members. More...
void * | cs_cdofb_ac_init_scheme_context (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nsc_input) |
| Initialize a cs_cdofb_ac_t structure. More...
void * | cs_cdofb_ac_free_scheme_context (void *scheme_context) |
| Destroy a cs_cdofb_ac_t structure. More...
void | cs_cdofb_ac_set_sles (const cs_navsto_param_t *nsp, void *context) |
| Start setting-up the Navier-Stokes equations when an AC algorithm is used to couple the system. No mesh information is available at this stage. More...
void | cs_cdofb_ac_compute_implicit (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context) |
| Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a Artificial Compressibility approach and an implicit Euler time scheme. More...
void | cs_cdofb_ac_compute_implicit_nl (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context) |
| Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a Artificial Compressibility approach and an implicit Euler time scheme For Picard - Navier–Stokes problems. More...
◆ cs_cdofb_ac_compute_implicit()
- Parameters
[in] | mesh | pointer to a cs_mesh_t structure |
[in] | nsp | pointer to a cs_navsto_param_t structure |
[in,out] | scheme_context | pointer to a structure cast on-the-fly |
◆ cs_cdofb_ac_compute_implicit_nl()
- Parameters
◆ cs_cdofb_ac_free_scheme_context()
void* cs_cdofb_ac_free_scheme_context |
void * |
scheme_context | ) |
- Parameters
[in] | scheme_context | pointer to a scheme context structure to free |
- Returns
- a NULL pointer
◆ cs_cdofb_ac_get_face_velocity()
static cs_real_t* cs_cdofb_ac_get_face_velocity |
bool |
previous | ) |
inlinestatic |
- Parameters
[in] | previous | retrieve the previous state (true/false) |
- Returns
- a pointer to an array of cs_real_t (size = 3*n_faces)
◆ cs_cdofb_ac_init_common()
- Parameters
◆ cs_cdofb_ac_init_scheme_context()
- Parameters
[in] | adv_field | pointer to cs_adv_field_t structure |
[in] | mflux | current values of the mass flux across primal faces |
[in] | mflux_pre | current values of the mass flux across primal faces |
[in] | fb_type | type of boundary for each boundary face |
[in] | nsc_input | pointer to a cs_navsto_ac_t structure |
- Returns
- a pointer to a new allocated cs_cdofb_ac_t structure
◆ cs_cdofb_ac_set_sles()
- Parameters
[in,out] | context | pointer to a context structure cast on-the-fly |
