1 #ifndef __CS_CDO_ASSEMBLY_H__
2 #define __CS_CDO_ASSEMBLY_H__
182 #if defined(HAVE_MPI)
197 cs_cdo_assembly_matrix_mpit(
const cs_sdm_t *m,
217 cs_cdo_assembly_matrix_mpis(
const cs_sdm_t *m,
309 #if defined(HAVE_MPI)
324 cs_cdo_assembly_matrix_sys_mpis(
const cs_sdm_t *m,
373 #if defined(HAVE_MPI)
389 cs_cdo_assembly_eblock33_matrix_mpis(
const cs_sdm_t *m,
410 cs_cdo_assembly_eblock33_matrix_mpit(
const cs_sdm_t *m,
459 #if defined(HAVE_MPI)
475 cs_cdo_assembly_block33_matrix_mpis(
const cs_sdm_t *m,
496 cs_cdo_assembly_block33_matrix_mpit(
const cs_sdm_t *m,
545 #if defined(HAVE_MPI)
561 cs_cdo_assembly_eblock_matrix_mpis(
const cs_sdm_t *m,
582 cs_cdo_assembly_eblock_matrix_mpit(
const cs_sdm_t *m,
void cs_cdo_assembly_matrix_e33_generic(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Assemble a cellwise matrix into the global matrix. Rely on the generic cs_matrix_assembler_values_add...
Definition: cs_cdo_assembly.c:1515
void cs_cdo_assembly_set_shift(cs_cdo_assembly_t *asb, cs_lnum_t l_row_shift, cs_lnum_t l_col_shift)
Set the current shift values to consider during the assembly stage.
Definition: cs_cdo_assembly.c:1301
struct _cs_cdo_assembly_t cs_cdo_assembly_t
Definition: cs_cdo_assembly.h:52
void cs_cdo_assembly_matrix_seqs(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Assemble a cellwise matrix into the global matrix Scalar-valued case. Sequential and without openMP (...
Definition: cs_cdo_assembly.c:1751
cs_cdo_assembly_t * cs_cdo_assembly_get(int t_id)
Get a pointer to a cs_cdo_assembly_t structure related to a given thread.
Definition: cs_cdo_assembly.c:1221
void cs_cdo_assembly_matrix_sys_seqt(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Assemble a cellwise (no-block) matrix into the global matrix corresponding to a system of coupled equ...
Definition: cs_cdo_assembly.c:1867
void cs_cdo_assembly_matrix_sys_seqs(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Definition: cs_cdo_assembly.c:1799
void cs_cdo_assembly_eblock33_matrix_seqt(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Assemble a cellwise matrix into the global matrix. Case of a block 3x3 entries. Expand each row....
Definition: cs_cdo_assembly.c:2098
void cs_cdo_assembly_block33_matrix_seqt(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Definition: cs_cdo_assembly.c:2409
void cs_cdo_assembly_eblock_matrix_seqs(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Assemble a cellwise matrix into the global matrix Case of a block NxN entries. Expand each row....
Definition: cs_cdo_assembly.c:2663
void cs_cdo_assembly_init(int ddim, int edim, int n_cw_dofs)
Allocate cs_cdo_assembly_t structure (shared among schemes). Each thread has its own copy this struct...
Definition: cs_cdo_assembly.c:1242
void cs_cdo_assembly_block33_matrix_seqs(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Definition: cs_cdo_assembly.c:2333
void cs_cdo_assembly_matrix_seqt(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Assemble a cellwise matrix into the global matrix. Scalar-valued case. Sequential and with openMP thr...
Definition: cs_cdo_assembly.c:1699
void cs_cdo_assembly_eblock33_matrix_seqs(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Assemble a cellwise matrix into the global matrix Case of a block 3x3 entries. Expand each row....
Definition: cs_cdo_assembly.c:2028
void() cs_cdo_assembly_func_t(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *eqa, cs_matrix_assembler_values_t *mav)
Assemble a cellwise matrix into the global matrix Block or no block versions are handled.
Definition: cs_cdo_assembly.h:72
void cs_cdo_assembly_eblock_matrix_seqt(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Assemble a cellwise system into the global algebraic system. Case of a block NxN entries....
Definition: cs_cdo_assembly.c:2746
void cs_cdo_assembly_matrix_scal_generic(const cs_sdm_t *m, const cs_lnum_t *dof_ids, const cs_range_set_t *rset, cs_cdo_assembly_t *asb, cs_matrix_assembler_values_t *mav)
Definition: cs_cdo_assembly.c:1329
void cs_cdo_assembly_finalize(void)
Free matrix-related structures used during the simulation. Display overall statistic about the assemb...
Definition: cs_cdo_assembly.c:1278
Definition: cs_defs.h:509
Definition: cs_defs.h:313
Definition: cs_range_set.h:57
