◆ CS_CUDA_CHECK
| #define CS_CUDA_CHECK |
a | ) |
Value: { \
cudaError_t ret_code =
a; \
if (cudaSuccess != ret_code) { \
bft_error(__FILE__, __LINE__, 0, "[CUDA error] %d: %s\n running: %s", \
ret_code, ::cudaGetErrorString(ret_code), #
a); \
double precision, save a
Definition: cs_fuel_incl.f90:148
◆ CS_CUDA_CHECK_CALL
| #define CS_CUDA_CHECK_CALL |
a, |
file_name, |
line_num |
Value: { \
a; \
bft_error(file_name, line_num, 0, "[CUDA error] %d: %s\n running: %s", \
a); \
◆ CS_CUDA_WARP_SIZE
| #define CS_CUDA_WARP_SIZE 32 |
◆ cs_cuda_grid_size()
| static unsigned int cs_cuda_grid_size |
cs_lnum_t |
n, |
unsigned int |
block_size |
inlinestatic |
Compute grid size for given array and block sizes.
This assumes each thread on a given block handles a single array element. For kernels in which each thread handles multiple elements, a grid size divided by that multiple is sufficient.
- Parameters
| [in] | n | size of arrays |
| [in] | block_size | block size for kernels |
- Returns
- grid size for kernels
◆ cs_glob_cuda_device_id
| int cs_glob_cuda_device_id |
extern |
◆ cs_glob_cuda_max_block_size
| int cs_glob_cuda_max_block_size |
extern |
◆ cs_glob_cuda_max_blocks
| int cs_glob_cuda_max_blocks |
extern |
◆ cs_glob_cuda_max_threads_per_block
| int cs_glob_cuda_max_threads_per_block |
extern |
◆ cs_glob_cuda_n_mp
