8.0
cs_assert.h File Reference
+ Include dependency graph for cs_assert.h:
Macros
#define cs_assert(expr)
 Abort the program if the given assertion is false. More...
Assertion usable in all build types.
◆ cs_assert
#define cs_assert (   expr)
Value:
if (!(expr)) bft_error(__FILE__, __LINE__, 0, \
"Assertion failed in function %s: %s", \
__func__, # expr)
Definition: bft_error.c:193
Contrary to the standard C assert macro, this is always defined, so the standard C assert macro should be use for debug build-only checking, whereas this macros should be used mainly for less expensive argument or precondition checks that should be present in all build types.
[in]exprexpression to verify
