◆ cs_1d_wall_thermal_check()
void cs_1d_wall_thermal_check |
int |
iappel, |
int |
isuit1 |
Data checking for the 1D thermal wall module.
- Parameters
[in] | iappel | Call number:
- 1: first call during the initialization (called once) Checking the number of cells nfpt1d and isuit1.
- 2: second call during the initialization (called once) Checking ifpt1d, nppt1d, eppt1d and rgpt1d arrays.
- 3: called at each time step Checking iclt1d, xlmbt1, rcpt1d and dtpt1d arrays.
[in] | isuit1 | Rereading of the restart file:
- 0: No rereading (meshing and wall temperature reinitialization)
- 1: Rereading of the restart file for the 1-Dimension thermal module
- isuite: Rereading only if the computational fluid dynamic is a continuation of the computation.
