◆ bft_mem_usage_end()
| void bft_mem_usage_end |
void |
End memory usage count depending on system.
◆ bft_mem_usage_init()
| void bft_mem_usage_init |
void |
Initialize memory usage count depending on system.
This functions checks if it has already been called, so it is safe to call more than once (though it is not thread-safe). Only the first call is effective.
◆ bft_mem_usage_initialized()
| int bft_mem_usage_initialized |
void |
Indicates if bft_mem_usage_...() functions are initialized.
- Returns
- 1 if bft_mem_usage_init has been called, 0 otherwise.
◆ bft_mem_usage_max_pr_size()
| size_t bft_mem_usage_max_pr_size |
void |
◆ bft_mem_usage_max_vm_size()
| size_t bft_mem_usage_max_vm_size |
void |
◆ bft_mem_usage_n_calls()
| void bft_mem_usage_n_calls |
size_t |
count[3] | ) |
◆ bft_mem_usage_pr_size()
| size_t bft_mem_usage_pr_size |
void |
Return current process memory use (in kB) depending on system.
If the information is not available (depending on availability of non-portable function calls), 0 is returned.
◆ bft_mem_usage_shared_lib_size()
| size_t bft_mem_usage_shared_lib_size |
void |
