Introduction
This page provides examples of code snippets that may be used to define physical variable laws.
- Warning
It is forbidden to modify turbulent viscosity visct here (a specific subroutine is dedicated to that: usvist)
- icp = 1 must have been specified in usipsu if we wish to define a variable specific heat cpro_cp (otherwise: memory overwrite).
- the kivisl field integer key (diffusivity_id) must have been specified in usipsu if we wish to define a variable viscosity
viscls.
- Warning
- : if the scalar is the temperature, its associated diffusivity actually corresponds to its conductivity (Lambda) in W/(m K)
The types of boundary faces at the previous time step are available (except at the first time step, where arrays itypfb and itrifb have not been initialized yet)
It is recommended to keep only the minimum necessary in this file (i.e. remove all unused example code)
Accessing physical properties
Base physical properties (rho, viscl, cp, ...) may be accessed as in the following snippet (see Variables and structures reference (C and Fortran) for additional information).
cs_user_physical_properties and are not to be modified here.
Molecular viscosity varying with temperature
The values of the molecular viscosity are provided as a function of the temperature. All variables are evaluated at the cell centers.
for (
cs_lnum_t c_id = 0; c_id < n_cells; c_id++) {
cpro_viscl[c_id] = xvart*(xvart*(varam*xvart+varbm)+varcm)+vardm;
Molecular volumetric viscosity varying with temperature
The values of the molecular volumetric viscosity are provided as a function of the temperature. All variables are evaluated at the cell centers.
if (cpro_viscv == NULL)
"%s: cpro_viscv not available.", __func__);
for (
cs_lnum_t c_id =0; c_id < n_cells; c_id++) {
cpro_viscv[c_id] = xvart*(xvart*(varam*xvart+varbm)+varcm)+vardm;
Isobaric specific heat varying with temperature
The values of the isobaric specific heat values are provided as a function of the temperature. All variables are evaluated at the cell centers.
if ((cpro_cp == NULL) || (cpro_cv == NULL))
"%s: cpro_cp or cpro_cv not available.", __func__);
for (
cpro_cp[c_id] = varac*xvart + varbc;
Molecular thermal conductivity varying with temperature
The values of the molecular thermal conductivity are provided as a function of the temperature. All variables are evaluated at the cell centers.
if (cpro_vtmpk == NULL)
"%s: cpro_vtmpk not available.", __func__);
for (
cpro_vtmpk[c_id] = (xvart*(xvart*(varal*xvart+varbl)+varcl)+vardl);
Molecular diffusivity of user-defined scalars varying with temperature
The molecular diffusivity can be set for all the user-defined scalars except:
- temperature and enthalpy (already dealt with above: for these variables, the 'diffusivity' is the thermal conductivity)
- variances of the fluctuations of another scalar variable (the diffusivity is assumed to be equal to that of the associated scalar) The values of the molecular diffusivity are provided as a function of the temperature. All variables are evaluated at the cell centers.
continue;
int sc_id = -1;
if (sc_id < 0)
continue;
if (variance_id > -1 || diffusivity_id < 0)
continue;
for (
cpro_vscal[c_id] = (xvart*(xvart*(varal*xvart+varbl)+varcl)+vardl);
