7.3
cs_user_physical_properties.f90 File Reference
Definition of physical variable laws. More...
Functions/Subroutines
subroutine usphyv (nvar, nscal, mbrom, dt)
subroutine usvist (nvar, nscal, ncepdp, ncesmp, icepdc, icetsm, itypsm, dt, ckupdc, smacel)
 Modify turbulent viscosity. More...
See of 1-D thermal conduction Equation for examples.
◆ usphyv()
subroutine usphyv ( integer  nvar,
integer  nscal,
integer  mbrom,
double precision, dimension(ncelet)  dt
Warning
It is forbidden to modify turbulent viscosity visct here (a specific subroutine is dedicated to that: usvist)
  • icp = 0 must have been specified in usipsu if we wish to define a variable specific heat cpro_cp (otherwise: memory overwrite).
  • the kivisl field integer key (diffusivity_id) must have been specified in usipsu if we wish to define a variable viscosity viscls.
Remarks
  • This routine is called at the beginning of each time step Thus, AT THE FIRST TIME STEP (non-restart case), the only values initialized before this call are those defined
  • We may define here variation laws for cell properties, for:
    • density: rom kg/m3
    • density at boundary faces: romb kg/m3)
    • molecular viscosity: cpro_viscl kg/(m s)
    • specific heat: cpro_cp J/(kg degrees)
    • diffusivities associated with scalars: cpro_vscalt kg/(m s)
Warning: if the scalar is the temperature, cpro_vscalt corresponds to its conductivity (Lambda) in W/(m K)
The types of boundary faces at the previous time step are available (except at the first time step, where arrays itypfb and itrifb have not been initialized yet)
It is recommended to keep only the minimum necessary in this file (i.e. remove all unused example code)
Cells identification
Cells may be identified using the getcel subroutine. The syntax of this subroutine is described in the cs_user_boundary_conditions subroutine, but a more thorough description can be found in the user guide.
[in]nvartotal number of variables
[in]nscaltotal number of scalars
[in]mbromindicator of filling of romb array
[in]dttime step (per cell)
◆ usvist()
subroutine usvist ( integer  nvar,
integer  nscal,
integer  ncepdp,
integer  ncesmp,
integer, dimension(ncepdp)  icepdc,
integer, dimension(ncesmp)  icetsm,
integer, dimension(ncesmp,nvar)  itypsm,
double precision, dimension(ncelet)  dt,
double precision, dimension(6,ncepdp)  ckupdc,
double precision, dimension(ncesmp,nvar)  smacel
This subroutine is called at beginning of each time step after the computation of the turbulent viscosity (physical quantities have already been computed in usphyv).
Turbulent viscosity $ \mu_T $ (kg/(m s)) can be modified.
A modification of the turbulent viscosity can lead to very significant differences between solutions and even give wrong results.
This subroutine is therefore reserved to expert users.
[in]ncepdpnumber of cells with head loss
[in]ncesmpnumber of cells with mass source term
[in]icepdchead loss cell numbering
[in]icetsmnumbering of cells with mass source term
[in]itypsmkind of mass source for each variable
[in]ckupdcwork array for head loss terms
[in]smacelvalues of variables related to mass source term. If ivar=ipr, smacel=mass flux
