| integer(c_int), pointer, save | ieos |
| | indicator of equation of state mapping cs_cf_model_t::ieos More...
| integer(c_int), pointer, save | ithvar |
| | thermodynamic variables indicator for initialization mapping cs_cf_model_t::ithvar More...
| integer, dimension(:), allocatable | ifbet |
| | imposed thermal flux indicator at the boundary (some boundary contributions of the total energy eq. have to be cancelled) More...
| integer, dimension(:), allocatable | icvfli |
| | boundary convection flux indicator of a Rusanov or an analytical flux (some boundary contributions of the momentum eq. have to be cancelled) More...
| real(c_double), pointer, save | psginf |
| | Stiffened gas limit pressure (Pa) for single phase model Equal to zero in perfect gas mapping cs_cf_model_t::psginf. More...
| real(c_double), pointer, save | gammasg |
| | Stiffened gas polytropic coefficient (dimensionless) for single phase model mapping cs_cf_model_t::gammasg. More...
| integer, save | ienerg |
| | specific total energy for compressible algorithm More...
| integer, save | itempk |
| | temperature deduced from the specific total energy More...
| int | ieos |
| int | ithvar |
| double | psginf |
| double | gammasg |
\ defgroup compressible Compressible models options
◆ gammasg [1/2]
stiffened gas polytropic coefficient (dimensionless) for single phase model
◆ gammasg [2/2]
| real(c_double), pointer, save gammasg |
◆ icvfli
| integer, dimension(:), allocatable icvfli |
◆ ienerg
◆ ieos [1/2]
| integer(c_int), pointer, save ieos |
◆ ieos [2/2]
- CS_EOS_IDEAL_GAS: ideal gas with a constant adiabatic coefficient
- CS_EOS_STIFFENED_GAS: stiffened gas
- CS_EOS_GAS_MIX: mix of ideal gas
- CS_EOS_HOMOGENEOUS_TWO_PHASE: two-phase homogeneous model only, each phase follows a stiffened gas law.
◆ ifbet
| integer, dimension(:), allocatable ifbet |
◆ itempk
◆ ithvar [1/2]
| integer(c_int), pointer, save ithvar |
◆ ithvar [2/2]
indicator for thermodynamic variables initialization
◆ psginf [1/2]
stiffened gas limit pressure (zero in perfect gas) for single phase model in Pa
◆ psginf [2/2]
| real(c_double), pointer, save psginf |
