| integer, dimension(nozppm), save | iqimp |
| | imposed flow zone indicator in a way which is similar to the process described in the framework of the EBU module, the user chooses for every inlet face to impose the mass flow or not (iqimp(izone)=1 or 0). If the mass flow is imposed, the user must set the air mass flow value qimpat(izone), its direction in rcodcl(ifac,iu), rcodcl(ifac,iv) and rcodcl(ifac,iw) and the incoming air temperature timpat(izone) in Kelvin. If the velocity is imposed, he has to set rcodcl(ifac,iu), rcodcl(ifac,iv), and rcodcl(ifac,iw). More...
| integer, dimension(nozppm), save | icalke |
| | condition type turbulence indicator More...
| double precision, dimension(nozppm), save | xintur |
| | turbulent intensity (k=1.5(uref*xintur)**2) More...
| double precision, dimension(nozppm), save | dh |
| | hydraulic diameter More...
| integer, save | nozapm |
| | index of maximum reached boundary zone More...
| integer, save | nzfppp |
| | number of boundary zones on current process More...
| integer, dimension(nbzppm), save | ilzppp |
| | list of boundary zones index More...
| integer, dimension(nozppm), save iqimp |
