7.3
fvm_nodal_extrude.h
1 #ifndef __FVM_NODAL_EXTRUDE_H__
2 #define __FVM_NODAL_EXTRUDE_H__
5  * Extrusion of a nodal representation associated with a mesh
30 #include "cs_defs.h"
33  * Local headers
36 #include "fvm_defs.h"
37 #include "fvm_nodal.h"
38
44  * Public function prototypes
46
47 /*----------------------------------------------------------------------------
48  * Extrude nodal mesh.
49  *
50  * Vertex and element parent numbering is removed if present.
51
52  * Note: layout of new elements in memory is such that the definitions
53  * of all elements extruded from a same ancestor are contiguous.
54  * that is, {e_1, e_2, ..., e_n} leads to
55  * {e_1_layer_1, ..., e_1_layer_m, e_2_layer_1, ... e_n_layer_m}
56  *
57  * parameters:
58  * this_nodal <-> pointer to structure that should be extruded
59  * n_layers <-> number of extruded layers
60  * extrusion_vectors <-> length and direction of extrusion for each vertex;
61  * size: mesh_spatial_dim . n_vertices
62  * distribution <-> optional distribution of resulting vertices
63  * along each extrusion vector (size: n_layers + 1)
64  * with values ranging from 0 to 1, or NULL for
65  * a regular distribution.
66  *----------------------------------------------------------------------------*/
67
68 void
69 fvm_nodal_extrude(fvm_nodal_t *this_nodal,
70  const cs_lnum_t n_layers,
71  const cs_coord_t extrusion_vectors[],
72  const cs_coord_t distribution[]);
73
75
77
78 #endif /* __FVM_NODAL_EXTRUDE_H__ */
Definition: cs_defs.h:512
double cs_coord_t
Definition: cs_defs.h:320
Definition: cs_defs.h:316
void fvm_nodal_extrude(fvm_nodal_t *this_nodal, const cs_lnum_t n_layers, const cs_coord_t extrusion_vectors[], const cs_coord_t distribution[])
Definition: fvm_nodal_extrude.c:221
Definition: cs_defs.h:513
