Include dependency graph for cs_parall.h:Go to the source code of this file.
Enumerations | |
| enum | cs_e2n_sum_t { CS_E2N_SUM_SCATTER, CS_E2N_SUM_SCATTER_ATOMIC, CS_E2N_SUM_GATHER, CS_E2N_SUM_STORE_THEN_GATHER } |
| static void | cs_parall_counter (cs_gnum_t cpt[], const int n) |
| Sum values of a counter on all default communicator processes. More... | |
| static void | cs_parall_counter_max (cs_lnum_t cpt[], const int n) |
| Maximum values of a counter on all default communicator processes. More... | |
| static void | cs_parall_sum (int n, cs_datatype_t datatype, void *val) |
| Sum values of a given datatype on all default communicator processes. More... | |
| static void | cs_parall_max (int n, cs_datatype_t datatype, void *val) |
| Maximum values of a given datatype on all default communicator processes. More... | |
| static void | cs_parall_min (int n, cs_datatype_t datatype, void *val) |
| Minimum values of a given datatype on all default communicator processes. More... | |
| static void | cs_parall_bcast (int root_rank, int n, cs_datatype_t datatype, void *val) |
| Broadcast values of a given datatype to all default communicator processes. More... | |
| void | cs_parall_allgather_r (int n_elts, int n_g_elts, cs_real_t array[], cs_real_t g_array[]) |
| Build a global array from each local array in each domain. More... | |
| void | cs_parall_allgather_ordered_r (int n_elts, int n_g_elts, int stride, cs_real_t o_key[], cs_real_t array[], cs_real_t g_array[]) |
| Build an ordered global array from each local array in each domain. More... | |
| void | cs_parall_gather_r (int root_rank, int n_elts, int n_g_elts, const cs_real_t array[], cs_real_t g_array[]) |
| Build a global array on the given root rank from all local arrays. More... | |
| void | cs_parall_gather_ordered_r (int root_rank, int n_elts, int n_g_elts, int stride, cs_real_t o_key[], cs_real_t array[], cs_real_t g_array[]) |
| Build an ordered global array on the given root rank from all local arrays. More... | |
| void | cs_parall_scatter_r (int root_rank, int n_elts, int n_g_elts, const cs_real_t g_array[], cs_real_t array[]) |
| Distribute a global array from a given root rank over all ranks. Each rank receive the part related to its local elements. More... | |
| void | cs_parall_gather_f (int root_rank, int n_elts, int n_g_elts, const float array[], float g_array[]) |
| Build a global array on the given root rank from all local arrays. Function dealing with single-precision arrays. More... | |
| void | cs_parall_scatter_f (int root_rank, int n_elts, int n_g_elts, const float g_array[], float array[]) |
| Distribute a global array from a given root rank over all ranks. Each rank receive the part related to its local elements. Function dealing with single-precision arrays. More... | |
| void | cs_parall_max_loc_vals (int n, cs_real_t *max, cs_real_t max_loc_vals[]) |
| Maximum value of a real and the value of related array on all default communicator processes. More... | |
| void | cs_parall_min_loc_vals (int n, cs_real_t *min, cs_real_t min_loc_vals[]) |
| Minimum value of a real and the value of related array on all default communicator processes. More... | |
| void | cs_parall_min_id_rank_r (cs_lnum_t *elt_id, int *rank_id, cs_real_t val) |
| Given an (id, rank, value) tuple, return the local id and rank corresponding to the global minimum value. More... | |
| size_t | cs_parall_get_min_coll_buf_size (void) |
| Return minimum recommended scatter or gather buffer size. More... | |
| void | cs_parall_set_min_coll_buf_size (size_t buffer_size) |
| Define minimum recommended scatter or gather buffer size. More... | |
| static void | cs_parall_thread_range (cs_lnum_t n, size_t type_size, cs_lnum_t *s_id, cs_lnum_t *e_id) |
| Compute array index bounds for a local thread. When called inside an OpenMP parallel section, this will return the start an past-the-end indexes for the array range assigned to that thread. In other cases, the start index is 1, and the past-the-end index is n;. More... | |
| cs_e2n_sum_t | cs_glob_e2n_sum_type |
| enum cs_e2n_sum_t |
Algorithm classes for indirect sums from a graph's edges to its nodes, such as face-to cell sums.
| void cs_parall_allgather_ordered_r | ( | int | n_elts, |
| int | n_g_elts, | ||
| int | stride, | ||
| cs_real_t | o_key[], | ||
| cs_real_t | array[], | ||
| cs_real_t | g_array[] | ||
Local array elements are ordered based on a given key value (usually some form of coordinate, so the result should be independent of partitioning as long as the definition of the o_key array's defintion is itself independent of the partitioning.
Use of this function may be quite practical, but should be limited to user functions, as it may limit scalability (especially as regards memory usage).
| [in] | n_elts | number of local elements |
| [in] | n_g_elts | number of global elements |
| [in] | stride | number of values per element |
| [in] | o_key | ordering key (coordinate) value per element |
| [in] | array | local array (size: n_elts*stride) |
| [out] | g_array | global array (size: n_g_elts*stride) |
Local arrays are appended in order of owning MPI rank. The size of each local array may be different.
| [in] | n_elts | size of the local array |
| [in] | n_g_elts | size of the global array |
| [in] | array | local array (size: n_elts) |
| [out] | g_array | global array (size: n_g_elts) |
inlinestatic |
| [in] | root_rank | rank from which to broadcast |
| [in] | n | number of values |
| [in] | datatype | matching code_saturne datatype |
| [in,out] | val | values to broadcast; input on root_rank, output on others (size: n) |
inlinestatic |
| [in,out] | cpt | local counter in, global counter out (size: n) |
inlinestatic |
| void cs_parall_gather_f | ( | int | root_rank, |
| int | n_elts, | ||
| const float | array[], | ||
| float | g_array[] | ||
| [in] | root_rank | rank which stores the global array |
| [out] | g_array | global array (size: n_g_elts) only usable by the root rank |
| void cs_parall_gather_ordered_r | ( | int | root_rank, |
| int | n_elts, | ||
| int | stride, | ||
| void cs_parall_gather_r | ( | int | root_rank, |
| int | n_elts, | ||
| const cs_real_t | array[], | ||
| size_t cs_parall_get_min_coll_buf_size | ( | void | ) |
This is used by some internal part to block or scatter/gather algorithms, so as to allow I/O buffer size tuning.
inlinestatic |
| [in,out] | val | local value input, global value output (array) |
| [in,out] | val | local maximum in, global maximum out (size: n) |
| [in] | n | size of the related array |
| [in,out] | max | local max in, global max out |
| [in,out] | max_loc_vals | array values at location of local max in, and at location of global max out |
inlinestatic |
| [in,out] | val | local minimum in, global minimum out (size: n) |
| [in,out] | elt_id | element id for which the value is the smallest (local in, global out) |
| [in,out] | rank_id | rank id for which the value is the smallest (local in, global out) |
| [in] | val | associated local minimum value |
| [in,out] | minx | local max in, global max out |
| [in,out] | min_loc_vals | array values at location of local max in, and at location of global max out |
| [in,out] | min | local min in, global min out |
| [in,out] | min_loc_vals | array values at location of local min in, and at location of global min out |
| void cs_parall_scatter_f | ( | int | root_rank, |
| int | n_elts, | ||
| const float | g_array[], | ||
| float | array[] | ||
Use of this function may be quite practical, but should be limited to specific usage, as it may limit scalability (especially as regards memory usage).
| [in] | g_array | global array (size: n_g_elts) only usable by the root rank |
| [out] | array | local array (size: n_elts) |
| void cs_parall_scatter_r | ( | int | root_rank, |
| int | n_elts, | ||
| const cs_real_t | g_array[], | ||
| cs_real_t | array[] | ||
| void cs_parall_set_min_coll_buf_size | ( | size_t | buffer_size | ) |
| [in] | buffer_size | minimum recommended part to block or gather buffer size (in bytes) |
inlinestatic |
| [in,out] | val | local sum in, global sum out (size: n) |
inlinestatic |
| [in] | n | size of array |
| [in] | type_size | element type size (or multiple) |
| [in,out] | s_id | start index for the current thread |
| [in,out] | e_id | past-the-end index for the current thread |
| cs_e2n_sum_t cs_glob_e2n_sum_type |
