2 #ifndef __CS_LES_INFLOW_H__ 3 #define __CS_LES_INFLOW_H__ cs_real_3_t * energy
Definition: cs_les_inflow.h:81
int cs_les_synthetic_eddy_get_n_restart_structures(void)
Return number of structures used for volume SEM when restarting from another turbulence model...
Definition: cs_les_inflow.c:2157
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:337
int volume_mode
Definition: cs_les_inflow.h:78
cs_les_inflow_type_t
Definition: cs_les_inflow.h:56
void cs_les_rescale_fluctuations(cs_lnum_t n_points, const cs_real_6_t statistics[], cs_real_3_t fluctuations[])
Rescale fluctuations by statistics following the Lund method.
Definition: cs_les_inflow.c:2089
void cs_les_inflow_add_inlet(cs_les_inflow_type_t type, bool volume_mode, const cs_zone_t *zone, int n_entities, int verbosity, const cs_real_t *vel_r, cs_real_t k_r, cs_real_t eps_r)
Add an inlet definition for synthetic turbulence inflow generation.
Definition: cs_les_inflow.c:902
void cs_les_inflow_set_restart(bool allow_read, bool allow_write)
Define behavior of the LES inflow module in case of restart.
Definition: cs_les_inflow.c:2198
Definition: cs_defs.h:512
void cs_user_les_inflow_update(const cs_zone_t *zone, cs_real_t vel_r[3], cs_real_t *k_r, cs_real_t *eps_r)
Update of the characteristics of a given synthetic turbulence inlet.
Definition: cs_user_les_inflow.c:97
void cs_user_les_inflow_define(void)
Define parameters of synthetic turbulence at LES inflow.
Definition: cs_user_les_inflow.c:79
Definition: cs_defs.h:322
real(c_double), pointer, save ttcabs
Current absolute time.
Definition: optcal.f90:301
void cs_user_les_inflow_advanced(const cs_zone_t *zone, cs_real_3_t vel_l[], cs_real_6_t rij_l[], cs_real_t eps_l[])
Definition of mean velocity, Reynolds stresses and dissipation rate for each boundary face of the giv...
Definition: cs_user_les_inflow.c:138
void cs_les_inflow_initialize(void)
Creation of structures for the LES inflows.
Definition: cs_les_inflow.c:736
Definition: cs_les_inflow.h:59
Definition: cs_les_inflow.h:58
int n_structures
Definition: cs_les_inflow.h:77
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
Definition: cs_les_inflow.h:75
void cs_les_synthetic_eddy_restart_write(void)
Definition: cs_les_inflow.c:1410
Definition: cs_defs.h:316
cs_real_3_t * position
Definition: cs_les_inflow.h:80
void cs_les_synthetic_eddy_restart_read(void)
Definition: cs_les_inflow.c:1061
struct _cs_inlet_t cs_inlet_t
Definition: cs_les_inflow.h:73
Definition: cs_les_inflow.h:61
Definition: cs_defs.h:513
void cs_les_inflow_get_restart(bool *allow_read, bool *allow_write)
Query behavior of the LES inflow module in case of restart.
Definition: cs_les_inflow.c:2174
void cs_les_synthetic_eddy_method(cs_lnum_t n_points, const cs_lnum_t elt_ids[], const cs_real_3_t point_coordinates[], const cs_real_t *point_weight, int initialize, int verbosity, cs_inflow_sem_t *inflow, cs_real_t t_cur, const cs_real_3_t vel_m_l[], const cs_real_6_t rij_l[], const cs_real_t eps_l[], cs_real_3_t fluctuations[])
Generation of synthetic turbulence via the Synthetic Eddy Method (SEM).
Definition: cs_les_inflow.c:1623
#define CS_PROCF(x, y)
Definition: cs_defs.h:526
void cs_les_synthetic_eddy_set_n_restart_structures(int n_structures)
Set number of structures used for volume SEM when restarting from another turbulence model...
Definition: cs_les_inflow.c:2142
void cs_les_inflow_finalize(void)
Finalize turbulent inflow generation API.
Definition: cs_les_inflow.c:752
void synthe(const cs_real_t *const ttcabs, const cs_real_t dt[], cs_real_t rcodcl[])
Definition: cs_les_inflow.c:482
Definition: cs_les_inflow.h:60
