7.3
cs_lagr_event.h File Reference
#include "cs_lagr_particle.h"
#include "assert.h"
+ Include dependency graph for cs_lagr_event.h:
Data Structures
struct  cs_lagr_event_attribute_map_t
struct  cs_lagr_event_set_t
Macros
#define CS_EVENT_INFLOW   (1 << 0)
#define CS_EVENT_OUTFLOW   (1 << 1)
#define CS_EVENT_REBOUND   (1 << 2)
#define CS_EVENT_DEPOSITION   (1 << 3)
#define CS_EVENT_RESUSPENSION   (1 << 4)
#define CS_EVENT_ROLL_OFF   (1 << 5)
#define CS_EVENT_ROLL_ON   (1 << 6)
#define CS_EVENT_FOULING   (1 << 7)
Enumerations
enum  cs_lagr_event_attribute_t {
  CS_LAGR_E_FLAG = CS_LAGR_N_ATTRIBUTES, CS_LAGR_E_CELL_ID, CS_LAGR_E_FACE_ID, CS_LAGR_E_VELOCITY,
  CS_LAGR_N_E_ATTRIBUTES
void cs_lagr_event_initialize (void)
 Define event map based on defined options. More...
void cs_lagr_event_finalize (void)
 Destroy event set map if it exists. More...
const cs_lagr_event_attribute_map_tcs_lagr_event_get_attr_map (void)
 Return const pointer to the main event attribute map structure. More...
const char * cs_lagr_event_get_attr_name (cs_lagr_event_attribute_t attr)
 Return name associated with a given attribute. More...
cs_lagr_event_set_tcs_lagr_event_set_create (void)
void cs_lagr_event_set_destroy (cs_lagr_event_set_t **events)
void cs_lagr_event_get_attr_info (const cs_lagr_event_set_t *events, cs_lagr_event_attribute_t attr, size_t *extents, size_t *size, ptrdiff_t *displ, cs_datatype_t *datatype, int *count)
 Get data extents for a given event attribute. More...
void cs_lagr_event_attr_in_range (int attr)
 Check if an event attribute is in a valid range. More...
static void * cs_lagr_events_attr (cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr)
 Get pointer to a current attribute of a given event in a set. More...
static const void * cs_lagr_events_attr_const (const cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr)
 Get const pointer to current attribute data of a given event in a set. More...
static cs_lnum_t cs_lagr_events_get_lnum (const cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr)
 Get attribute value of type cs_lnum_t of a given event in a set. More...
static void cs_lagr_events_set_lnum (cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr, cs_lnum_t value)
 Set attribute value of type cs_lnum_t of a given event in a set. More...
static cs_real_t cs_lagr_events_get_real (const cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr)
 Get attribute value of type cs_real_t of a given event in a set. More...
static void cs_lagr_events_set_real (cs_lagr_event_set_t *event_set, cs_lnum_t event_id, cs_lagr_event_attribute_t attr, cs_real_t value)
 Set attribute value of type cs_real_t of a given event in a set. More...
void cs_lagr_event_set_resize (cs_lagr_event_set_t *event_set, cs_lnum_t min_size)
void cs_lagr_event_set_dump (const cs_lagr_event_set_t *events)
 Dump a cs_lagr_event_set_t structure. More...
void cs_lagr_event_init_from_particle (cs_lagr_event_set_t *events, cs_lagr_particle_set_t *particles, cs_lnum_t event_id, cs_lnum_t particle_id)
cs_lagr_event_set_tcs_lagr_event_set_boundary_interaction (void)
◆ CS_EVENT_DEPOSITION
deposistion event
◆ CS_EVENT_FOULING
fouling
◆ CS_EVENT_INFLOW
Flags specifying general event attributes
inflow event
◆ CS_EVENT_OUTFLOW
outflow event
◆ CS_EVENT_REBOUND
rebound on wall
◆ CS_EVENT_RESUSPENSION
resuspension event
◆ CS_EVENT_ROLL_OFF
roll off
◆ CS_EVENT_ROLL_ON
roll on
◆ cs_lagr_event_attribute_t
Prefedined event attributes
Enumerator
CS_LAGR_E_FLAG
local flag
CS_LAGR_E_CELL_ID
local cell id
CS_LAGR_E_FACE_ID
local face id (-1 if not on boundary)
CS_LAGR_E_VELOCITY
velocity following event
◆ cs_lagr_event_attr_in_range()
void cs_lagr_event_attr_in_range ( int  attr)
If this is not the case, a fatal error is provoked.
[in]attrevent attribute
◆ cs_lagr_event_finalize()
void cs_lagr_event_finalize ( void  )
◆ cs_lagr_event_get_attr_info()
void cs_lagr_event_get_attr_info ( const cs_lagr_event_set_t events,
size_t *  extents,
size_t *  size,
ptrdiff_t *  displ,
cs_datatype_t datatype,
int *  count
For attributes not currently present, the displacement and data size should be -1 and 0 respectively.
[in]eventsassociated event set
[out]extentssize (in bytes) of event structure, or NULL
[out]sizesize (in bytes) of attribute in event structure, or NULL
[out]displdisplacement (in bytes) in event structure, or NULL
[out]datatypedatatype of associated attribute, or NULL
[out]countnumber of type values associated with attribute, or NULL
◆ cs_lagr_event_get_attr_map()
const cs_lagr_event_attribute_map_t* cs_lagr_event_get_attr_map ( void  )
pointer to current event attribute map, or NULL
pointer to current particle event attrbute map, or NULL
◆ cs_lagr_event_get_attr_name()
const char* cs_lagr_event_get_attr_name ( cs_lagr_event_attribute_t  attr)
◆ cs_lagr_event_init_from_particle()
void cs_lagr_event_init_from_particle ( cs_lagr_event_set_t events,
cs_lagr_particle_set_t particles,
cs_lnum_t  event_id,
◆ cs_lagr_event_initialize()
void cs_lagr_event_initialize ( void  )
This function should only be called after cs_lagr_particle_attr_initialize, as it may use elements from the main particle attributes map.
◆ cs_lagr_event_set_boundary_interaction()
cs_lagr_event_set_t* cs_lagr_event_set_boundary_interaction ( void  )
Return a cs_lagr_event_set_t structure for particle/boundary interactions.
The event set is created if not present yet.
This event set is automatically freed and destroyed at the end of the computation.
pointer to event set
◆ cs_lagr_event_set_create()
cs_lagr_event_set_t* cs_lagr_event_set_create ( void  )
Create a cs_lagr_event_set_t structure.
◆ cs_lagr_event_set_destroy()
void cs_lagr_event_set_destroy ( cs_lagr_event_set_t **  events)
Destroy a cs_lagr_event_set_t structure.
[in,out]eventspointer to pointer to event set to destroy
◆ cs_lagr_event_set_dump()
void cs_lagr_event_set_dump ( const cs_lagr_event_set_t events)
[in]eventscs_lagr_event_t structure to dump
[in]eventscs_lagr_event_set_t structure to dump
◆ cs_lagr_event_set_resize()
void cs_lagr_event_set_resize ( cs_lagr_event_set_t event_set,
cs_lnum_t  min_size
◆ cs_lagr_events_attr()
static void* cs_lagr_events_attr ( cs_lagr_event_set_t event_set,
cs_lnum_t  event_id,
inlinestatic
[in]event_setpointer to event set
[in]event_idevent id
[in]attrrequested attribute id
◆ cs_lagr_events_attr_const()
static const void* cs_lagr_events_attr_const ( const cs_lagr_event_set_t event_set,
cs_lnum_t  event_id,
inlinestatic
◆ cs_lagr_events_get_lnum()
static cs_lnum_t cs_lagr_events_get_lnum ( const cs_lagr_event_set_t event_set,
cs_lnum_t  event_id,
inlinestatic
attribute value
◆ cs_lagr_events_get_real()
static cs_real_t cs_lagr_events_get_real ( const cs_lagr_event_set_t event_set,
cs_lnum_t  event_id,
inlinestatic
attribute value
◆ cs_lagr_events_set_lnum()
static void cs_lagr_events_set_lnum ( cs_lagr_event_set_t event_set,
cs_lnum_t  event_id,
cs_lnum_t  value
inlinestatic
[in,out]event_setpointer to event set
[in]valuevalue to assign
◆ cs_lagr_events_set_real()
static void cs_lagr_events_set_real ( cs_lagr_event_set_t event_set,
cs_lnum_t  event_id,
cs_real_t  value
inlinestatic
