#include "cs_cdo_connect.h"#include "cs_cdo_local.h"#include "cs_cdo_quantities.h"#include "cs_param_cdo.h"#include "cs_property.h"#include "cs_sdm.h"
Include dependency graph for cs_hodge.h:Go to the source code of this file.
| struct | cs_hodge_param_t |
| Structure storing all metadata/parameters related to the usage of a discrete Hodge operator. More... | |
| struct | cs_hodge_t |
| Structure associated to a discrete Hodge operator *. More... | |
| typedef bool() | cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a discrete Hodge operator or a related operator (such as the stiffmess matrix) for a given cell. The discrete Hodge operator is stored in hodge->matrix whereas the associated operator is stored in cb->loc One checks if something has to be computed. One skips the computation if the value of the associated property is equal to zero. More... | |
Enumerations | |
| enum | cs_hodge_type_t { CS_HODGE_TYPE_VPCD, CS_HODGE_TYPE_EPFD, CS_HODGE_TYPE_FPED, CS_HODGE_TYPE_EDFP, CS_HODGE_TYPE_CPVD, CS_HODGE_TYPE_FB, CS_HODGE_TYPE_VC, CS_HODGE_N_TYPES } |
| Type of discrete Hodge operators. More... | |
| enum | cs_hodge_algo_t { CS_HODGE_ALGO_VORONOI, CS_HODGE_ALGO_WBS, CS_HODGE_ALGO_COST, CS_HODGE_ALGO_OCS2, CS_HODGE_ALGO_BUBBLE, CS_HODGE_ALGO_AUTO, CS_HODGE_N_ALGOS } |
| Type of algorithm to build a discrete Hodge operator. More... | |
| static bool | cs_hodge_param_is_similar (const cs_hodge_param_t h1_info, const cs_hodge_param_t h2_info) |
| Check if two sets of parameters related to how build a discrete Hodge operator are similar. More... | |
| cs_hodge_t * | cs_hodge_create (const cs_cdo_connect_t *connect, const cs_property_t *property, const cs_hodge_param_t *hp, bool need_tensor, bool need_eigen) |
| Create and initialize a pointer to a cs_hodge_t structure. More... | |
| cs_hodge_t ** | cs_hodge_init_context (const cs_cdo_connect_t *connect, const cs_property_t *property, const cs_hodge_param_t *hp, bool need_tensor, bool need_eigen) |
| Create and initialize an array of pointers to a cs_hodge_t structures. This array is of size the number of OpenMP threads. Only the one associated to the current thread is set. More... | |
| void | cs_hodge_free (cs_hodge_t **p_hodge) |
| Free a cs_hodge_t structure. More... | |
| void | cs_hodge_free_context (cs_hodge_t ***p_hodges) |
| Free a set of cs_hodge_t structures. More... | |
| cs_hodge_compute_t * | cs_hodge_get_func (const char *calling_func, const cs_hodge_param_t hp) |
| Retrieve a function pointer to compute a discrete Hodge operator. More... | |
| cs_hodge_algo_t | cs_hodge_set_mass_algo (const char *eqname, cs_hodge_algo_t reac_algo, cs_hodge_algo_t time_algo, cs_hodge_algo_t srct_algo) |
| Check the consistency of the settings between terms related to a mass matrix and define the common algorithm to use. If a term should not be considered, set the algorithm to CS_HODGE_N_ALGOS. More... | |
| void | cs_hodge_param_log (const char *prefix, const cs_property_t *property, const cs_hodge_param_t hp) |
| Output the settings related to a cs_hodge_param_t structure. More... | |
| void | cs_hodge_copy_parameters (const cs_hodge_param_t *h_ref, cs_hodge_param_t *h_cpy) |
| Copy the set of parameters associated to a discrete Hodge operator to another one. More... | |
| void | cs_hodge_set_property_value (const cs_lnum_t c_id, const cs_real_t t_eval, const cs_flag_t c_flag, cs_hodge_t *hodge) |
| Set the property value (scalar- or tensor-valued) related to a discrete Hodge operator inside a cell and if needed other related quantities. More... | |
| void | cs_hodge_set_property_value_cw (const cs_cell_mesh_t *cm, const cs_real_t t_eval, const cs_flag_t c_flag, cs_hodge_t *hodge) |
| Set the property value (scalar- or tensor-valued) related to a discrete Hodge operator inside a cell and if needed ohter related quantities. Cell-wise variant (usage of cs_cell_mesh_t structure) More... | |
| bool | cs_hodge_fb_cost_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO face-based schemes. More... | |
| bool | cs_hodge_fb_bubble_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. with the usage of bubble stabilization. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO face-based schemes. More... | |
| bool | cs_hodge_fb_voro_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO face-based schemes. More... | |
| bool | cs_hodge_vb_cost_get_iso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and an isotropic property. More... | |
| bool | cs_hodge_vb_cost_get_aniso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and an anistropic property. More... | |
| bool | cs_hodge_vb_bubble_get_iso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic Bubble algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and isotropic material property. More... | |
| bool | cs_hodge_vb_bubble_get_aniso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic Bubble algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes and anisotropic material property. More... | |
| bool | cs_hodge_vb_ocs2_get_aniso_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the Orthogonal Consistent/Sub-Stabilization decomposition (OCS2) with a subdivision of pvol_{e,c}. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case Vb schemes and an anisotropic material property. More... | |
| bool | cs_hodge_vb_cost_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes. More... | |
| bool | cs_hodge_vb_voro_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc and the related discrete hodge operator in hodge->matrix Case of CDO vertex-based schemes. More... | |
| bool | cs_hodge_vb_wbs_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic WBS algo. WBS means for Whitney Barycentric Subdivision (WBS) algo. The computed matrix is stored in cb->loc. More... | |
| bool | cs_hodge_vcb_get_stiffness (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local stiffness matrix using the generic WBS algo. WBS means Whitney Barycentric Subdivision (WBS) algo. The computed matrix is stored in cb->loc. More... | |
| bool | cs_hodge_fb_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator on a given cell which is equivalent of a mass matrix. It relies on a CO+ST algo. and is specific to CDO-Fb schemes. The discrete Hodge operator is stored in hodge->matrix. More... | |
| bool | cs_hodge_vcb_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the Voronoi algo. This leads to a diagonal operator. This function is specific for vertex+cell-based schemes The discrete Hodge operator is stored in hodge->matrix. More... | |
| bool | cs_hodge_vcb_wbs_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the WBS algo. This function is specific for vertex+cell-based schemes The discrete Hodge operator is stored in hodge->matrix. More... | |
| bool | cs_hodge_vpcd_wbs_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using WBS algo. Hodge op. from primal vertices to dual cells. This function is specific for vertex-based schemes The discrete Hodge operator is stored in hodge->matrix. More... | |
| bool | cs_hodge_vpcd_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal vertices to dual cells. This function is specific for vertex-based schemes The discrete Hodge operator is stored in hodge->matrix. More... | |
| bool | cs_hodge_epfd_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal edges to dual faces. The discrete Hodge operator is stored in hodge->matrix This function is specific for vertex-based schemes. More... | |
| bool | cs_hodge_epfd_cost_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal edges to dual faces. The discrete Hodge operator is stored in hodge->matrix This function is specific for vertex-based schemes. More... | |
| bool | cs_hodge_epfd_bubble_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. with a bubble stabilization. The discrete Hodge operator is stored in hodge->matrix Hodge op. from primal edges to dual faces. This function is specific for vertex-based schemes. More... | |
| bool | cs_hodge_epfd_ocs2_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the Orthogonal Consistent/Sub-Stabilization decomposition (OCS2) with a subdivision of pvol_{e,c}. The discrete Hodge operator is stored in hodge->matrix Hodge op. from primal edges to dual faces. This function is specific for vertex-based schemes. More... | |
| bool | cs_hodge_fped_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal faces to dual edges. The discrete Hodge operator is stored in hodge->matrix This function is related to cell-based schemes. More... | |
| bool | cs_hodge_fped_cost_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal faces to dual edges. The discrete Hodge operator is stored in hodge->matrix This function is related to cell-based schemes. More... | |
| bool | cs_hodge_fped_bubble_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the Bubble algo. Hodge op. from primal faces to dual edges. The discrete Hodge operator is stored in hodge->matrix This function is related to cell-based schemes. More... | |
| bool | cs_hodge_edfp_voro_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from dual edges to primal faces. The discrete Hodge operator is stored in hodge->matrix This function is related to face-based schemes. More... | |
| bool | cs_hodge_edfp_cost_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the COST algo. Hodge op. from dual edges to primal faces. This function is related to face-based schemes. More... | |
| bool | cs_hodge_edfp_bubble_get (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| Build a local Hodge operator for a given cell using the Bubble algo. Hodge op. from dual edges to primal faces. The discrete Hodge operator is stored in hodge->matrix This function is related to face-based schemes. More... | |
| bool | cs_hodge_edfp_cost_get_opt (const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| void | cs_hodge_matvec (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_hodge_param_t hodgep, const cs_property_t *pty, const cs_real_t in_vals[], cs_real_t t_eval, cs_real_t result[]) |
| Compute cellwise a discrete hodge operator and multiple it with a vector. More... | |
| void | cs_hodge_circulation_from_flux (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, const cs_hodge_param_t hodgep, const cs_property_t *pty, const cs_real_t flux[], cs_real_t circul[]) |
| Compute cellwise a discrete hodge operator in order to define a circulation array from a flux array. More... | |
| void | cs_hodge_compute_wbs_surfacic (const cs_face_mesh_t *fm, cs_sdm_t *hf) |
| Compute the hodge operator related to a face (i.e. a mass matrix with unity property) using a Whitney Barycentric Subdivision (WBS) algorithm. More... | |
| typedef bool() cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb) |
| [in] | cm | pointer to a cs_cell_mesh_t struct. |
| [in,out] | hodge | pointer to a cs_hodge_t structure |
| enum cs_hodge_algo_t |
| Enumerator | |
| CS_HODGE_ALGO_VORONOI | This algorithm assumes that an orthogonality condition holds between geometrical entities (e.g. the face normal/dual edge or the primal edge/dual face normal). This algorithm leads to a diagonal discrete Hodge operator (and is related to a two-point flux approximation). Be aware that using this technique on a non-orthogonal mesh leads to a consistency error which does not decrease when refining the mesh. |
| CS_HODGE_ALGO_WBS | WBS means "Whitney Barycentric Subdivision". This algorithm relies on a subdivision into tetrahedra of each polyhedral cell and then applies algorithms on this subdivision shape functions close to what exists in the Finite Element litterature |
| CS_HODGE_ALGO_COST | Orthogonal decomposition between the consistency (CO) and the stabilization (ST) parts. Several discretizations share this way to build discrete Hodge operators like SUSHI, DGA and GCR (these discretizations only differ from the scaling coefficient in front of the stabilization term) |
| CS_HODGE_ALGO_OCS2 | This algorithm is close to CS_HODGE_ALGO_COST but relies on a subdivision of each polyhedral cell corresponding to the refinement considered in CS_HODGE_ALGO_COST for the building of the stabilization term |
| CS_HODGE_ALGO_BUBBLE | This algorithm also relies on an orthogonal decomposition between the consistency (CO) and the stabilization (ST) parts but the stabilization part relies on a bubble function (similar to what can be found in the Finite Element literature) |
| CS_HODGE_ALGO_AUTO | Automatic switch between the above-mentioned algorithms (not used for the moment). |
| CS_HODGE_N_ALGOS | |
| enum cs_hodge_type_t |
| void cs_hodge_circulation_from_flux | ( | const cs_cdo_connect_t * | connect, |
| cs_real_t | t_eval, | ||
| const cs_hodge_param_t | hodgep, | ||
| const cs_property_t * | pty, | ||
| const cs_real_t | flux[], | ||
| cs_real_t | circul[] | ||
| [in] | hodgep | cs_hodge_param_t structure |
| [in] | pty | pointer to a cs_property_t structure or NULL |
| [in] | flux | vector to multiply with the discrete Hodge op. |
| [in,out] | circul | array storing the resulting matrix-vector product |
| void cs_hodge_compute_wbs_surfacic | ( | const cs_face_mesh_t * | fm, |
| cs_sdm_t * | hf | ||
| [in] | fm | pointer to a cs_face_mesh_t structure |
| [in,out] | hf | pointer to a cs_sdm_t structure to define |
| void cs_hodge_copy_parameters | ( | const cs_hodge_param_t * | h_ref, |
| cs_hodge_param_t * | h_cpy | ||
| [in] | h_ref | reference set of parameters |
| [in,out] | h_cpy | set of parameters to update |
| cs_hodge_t* cs_hodge_create | ( | const cs_cdo_connect_t * | connect, |
| const cs_property_t * | property, | ||
| const cs_hodge_param_t * | hp, | ||
| bool | need_tensor, | ||
| bool | need_eigen | ||
| [in] | connect | pointer to cs_cdo_connect_t structure |
| [in] | property | pointer to a property structure |
| [in] | hp | pointer to a cs_hodge_param_t structure |
| [in] | need_tensor | true if one needs a tensor otherwise false |
| [in] | need_eigen | true if one needs to compute eigen valuese |
| bool cs_hodge_edfp_bubble_get | ( | const cs_cell_mesh_t * | cm, |
| cs_hodge_t * | hodge, | ||
| bool cs_hodge_edfp_cost_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_edfp_cost_get_opt | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_edfp_voro_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_epfd_bubble_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_epfd_cost_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_epfd_ocs2_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_epfd_voro_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fb_bubble_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fb_cost_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fb_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fb_voro_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fped_bubble_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fped_cost_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_fped_voro_get | ( | const cs_cell_mesh_t * | cm, |
| void cs_hodge_free | ( | cs_hodge_t ** | p_hodge | ) |
| [in,out] | p_hodge | double pointer to a cs_hodge_t structure |
| void cs_hodge_free_context | ( | cs_hodge_t *** | p_hodges | ) |
| [in,out] | p_hodges | triple pointer to cs_hodge_t structures |
| cs_hodge_compute_t* cs_hodge_get_func | ( | const char * | calling_func, |
| const cs_hodge_param_t | hp | ||
| [in] | calling_func | name of the calling function |
| [in] | hp | a cs_hodge_param_t structure |
| cs_hodge_t** cs_hodge_init_context | ( | const cs_cdo_connect_t * | connect, |
| void cs_hodge_matvec | ( | const cs_cdo_connect_t * | connect, |
| const cs_real_t | in_vals[], | ||
| cs_real_t | result[] | ||
| [in] | in_vals | vector to multiply with the discrete Hodge op. |
| [in,out] | result | array storing the resulting matrix-vector product |
inlinestatic |
| [in] | h1_info | pointer to a first cs_hodge_param_t structure |
| [in] | h2_info | pointer to a second cs_hodge_param_t structure |
| void cs_hodge_param_log | ( | const char * | prefix, |
| [in] | prefix | optional string |
| [in] | property | optional pointer to a property structure |
| cs_hodge_algo_t cs_hodge_set_mass_algo | ( | const char * | eqname, |
| cs_hodge_algo_t | reac_algo, | ||
| cs_hodge_algo_t | time_algo, | ||
| cs_hodge_algo_t | srct_algo | ||
| [in] | eqname | name of the equation to check |
| [in] | reac_algo | optional algo. used for the reaction term |
| [in] | time_algo | optional algo. used for the unsteady term |
| [in] | srct_algo | optional algo. used for the source term |
| void cs_hodge_set_property_value | ( | const cs_lnum_t | c_id, |
| const cs_flag_t | c_flag, | ||
| cs_hodge_t * | hodge | ||
| [in] | c_id | id of the cell to deal with |
| [in] | c_flag | flag related to this cell |
| void cs_hodge_set_property_value_cw | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_bubble_get_aniso_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_bubble_get_iso_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_cost_get_aniso_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_cost_get_iso_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_cost_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_ocs2_get_aniso_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_voro_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vb_wbs_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vcb_get_stiffness | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vcb_voro_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vcb_wbs_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vpcd_voro_get | ( | const cs_cell_mesh_t * | cm, |
| bool cs_hodge_vpcd_wbs_get | ( | const cs_cell_mesh_t * | cm, |
