7.3
cs_flag.h File Reference
+ Include dependency graph for cs_flag.h:
Macros
Flags specifying the type of cell
#define CS_FLAG_BOUNDARY_CELL_BY_FACE   (1 << 0)
 (= 1) boundary cell with at least one border face More...
#define CS_FLAG_BOUNDARY_CELL_BY_VERTEX   (1 << 1)
 (= 2) boundary cell with at least one border vertex More...
#define CS_FLAG_BOUNDARY_CELL_BY_EDGE   (1 << 2)
 (= 4) boundary cell with at least one border edge More...
#define CS_FLAG_SOLID_CELL   (1 << 3)
 (= 8) cell attached to a solid zone during the calculation More...
Flags specifying the type of update to perform
#define CS_FLAG_CURRENT_TO_PREVIOUS   (1 << 0)
 (value = 1) perform a previous to current operation on fields during the update step More...
#define CS_FLAG_INITIALIZATION   (1 << 1)
 (value = 2) This is the first time that the update is called so it is also an initialization step More...
Flag related to the way a CDO system is built
#define CS_FLAG_SYS_MASS_MATRIX   (1 << 0)
#define CS_FLAG_SYS_SYM   (1 << 1)
#define CS_FLAG_SYS_TIME_DIAG   (1 << 2)
#define CS_FLAG_SYS_REAC_DIAG   (1 << 3)
#define CS_FLAG_SYS_SOURCES_HLOC   (1 << 4)
#define CS_FLAG_SYS_VECTOR   (1 << 5)
Flags use to identify the nature/status of an object
Apply this flag on a variable, a property or an advection field
#define CS_FLAG_STATE_UNIFORM   (1 << 0)
#define CS_FLAG_STATE_CELLWISE   (1 << 1)
#define CS_FLAG_STATE_FACEWISE   (1 << 2)
#define CS_FLAG_STATE_STEADY   (1 << 3)
#define CS_FLAG_STATE_POTENTIAL   (1 << 4)
#define CS_FLAG_STATE_CIRCULATION   (1 << 5)
#define CS_FLAG_STATE_FLUX   (1 << 6)
#define CS_FLAG_STATE_DENSITY   (1 << 7)
Flags use to identify metadata for a quantity
where is located this quantity and how to access to its values
#define CS_FLAG_FULL_LOC   (1 << 0)
#define CS_FLAG_SCALAR   (1 << 1)
#define CS_FLAG_VECTOR   (1 << 2)
#define CS_FLAG_TENSOR   (1 << 3)
#define CS_FLAG_VERTEX   (1 << 4)
#define CS_FLAG_EDGE   (1 << 5)
#define CS_FLAG_FACE   (1 << 6)
#define CS_FLAG_CELL   (1 << 7)
#define CS_FLAG_PRIMAL   (1 << 8)
#define CS_FLAG_DUAL   (1 << 9)
#define CS_FLAG_BORDER   (1 << 10)
#define CS_FLAG_BY_CELL   (1 << 11)
#define CS_FLAG_BY_FACE   (1 << 12)
Flags use to identify the type of equations requested.
There exists one flag for each type of space discretization. If this flag is activated, then at least one equation or system of this kind is discretized with this space discretization scheme.
#define CS_FLAG_SCHEME_SCALAR   (1 << 0)
#define CS_FLAG_SCHEME_VECTOR   (1 << 1)
#define CS_FLAG_SCHEME_NAVSTO   (1 << 2)
#define CS_FLAG_SCHEME_POLY0   (1 << 3)
#define CS_FLAG_SCHEME_POLY1   (1 << 4)
#define CS_FLAG_SCHEME_POLY2   (1 << 5)
Typedefs
typedef unsigned char cs_mask_t
typedef unsigned int cs_eflag_t
Enumerations
enum  cs_flag_comp_bits_t {
  CS_FLAG_COMP_PV = 1 << 0, CS_FLAG_COMP_PVQ = 1 << 1, CS_FLAG_COMP_PE = 1 << 2, CS_FLAG_COMP_PEQ = 1 << 3,
  CS_FLAG_COMP_DFQ = 1 << 4, CS_FLAG_COMP_PF = 1 << 5, CS_FLAG_COMP_PFQ = 1 << 6, CS_FLAG_COMP_DEQ = 1 << 7,
  CS_FLAG_COMP_EV = 1 << 8, CS_FLAG_COMP_FE = 1 << 9, CS_FLAG_COMP_FEQ = 1 << 10, CS_FLAG_COMP_FV = 1 << 11,
  CS_FLAG_COMP_EF = 1 << 12, CS_FLAG_COMP_SEF = 1 << 13, CS_FLAG_COMP_HFQ = 1 << 14, CS_FLAG_COMP_FES = 1 << 15,
  CS_FLAG_COMP_PFC = 1 << 16, CS_FLAG_COMP_PEC = 1 << 17, CS_FLAG_COMP_DIAM = 1 << 18
enum  cs_flag_location_t {
  CS_FLAG_LOCATION_PRIMAL_VTX = CS_FLAG_PRIMAL | CS_FLAG_VERTEX, CS_FLAG_LOCATION_PRIMAL_EDGE = CS_FLAG_PRIMAL | CS_FLAG_EDGE, CS_FLAG_LOCATION_PRIMAL_FACE = CS_FLAG_PRIMAL | CS_FLAG_FACE, CS_FLAG_LOCATION_PRIMAL_CELL = CS_FLAG_PRIMAL | CS_FLAG_CELL,
  CS_FLAG_LOCATION_DUAL_VTX = CS_FLAG_DUAL | CS_FLAG_VERTEX, CS_FLAG_LOCATION_DUAL_EDGE = CS_FLAG_DUAL | CS_FLAG_EDGE, CS_FLAG_LOCATION_DUAL_FACE = CS_FLAG_DUAL | CS_FLAG_FACE, CS_FLAG_LOCATION_DUAL_CELL = CS_FLAG_DUAL | CS_FLAG_CELL,
  CS_FLAG_N_LOCATIONS
static bool cs_flag_test (cs_flag_t flag_to_check, cs_flag_t reference)
 Check if a two flag share the same pattern Return true if the flag to check has at least the pattern of the reference flag. More...
static bool cs_flag_at_least (cs_flag_t flag_to_check, int n_masks, cs_flag_t masks[])
 Check if a flag has in common at least one of the given masks Return true if the test is satisfied. More...
static bool cs_eflag_test (cs_eflag_t flag_to_check, cs_eflag_t reference)
 Check if a two compute flag share the same pattern Return true if the computed flag to check has at least the pattern of the reference compute flag. Case of extended flags. More...
const char * cs_flag_str_location (cs_flag_t loc)
 Retrieve the label associated to a location flag. More...
const cs_flag_t cs_flag_primal_vtx
const cs_flag_t cs_flag_primal_edge
const cs_flag_t cs_flag_primal_face
const cs_flag_t cs_flag_primal_cell
const cs_flag_t cs_flag_vertex
const cs_flag_t cs_flag_cell
const cs_flag_t cs_flag_boundary_face
const cs_flag_t cs_flag_dual_vtx
const cs_flag_t cs_flag_dual_face
const cs_flag_t cs_flag_dual_cell
const cs_flag_t cs_flag_dual_cell_byc
const cs_flag_t cs_flag_dual_face_byc
const cs_flag_t cs_flag_dual_closure_byf
const cs_eflag_t cs_flag_need_v
const cs_eflag_t cs_flag_need_e
const cs_eflag_t cs_flag_need_f
const cs_eflag_t cs_flag_need_fe
const cs_eflag_t cs_flag_need_ef
const cs_eflag_t cs_flag_need_peq
const cs_eflag_t cs_flag_need_dfq
const cs_eflag_t cs_flag_need_pfq
const cs_eflag_t cs_flag_need_deq
const cs_eflag_t cs_flag_need_pfc
◆ CS_FLAG_BORDER
1024: located on the boundary
◆ CS_FLAG_BOUNDARY_CELL_BY_EDGE
◆ CS_FLAG_BOUNDARY_CELL_BY_FACE
◆ CS_FLAG_BOUNDARY_CELL_BY_VERTEX
◆ CS_FLAG_BY_CELL
2048: by cell (c2e, c2f, c2v)
◆ CS_FLAG_BY_FACE
4096: by face (bf2v)
◆ CS_FLAG_CELL
128: on cells
◆ CS_FLAG_CURRENT_TO_PREVIOUS
◆ CS_FLAG_DUAL
512: on dual mesh
◆ CS_FLAG_EDGE
32: on edges
◆ CS_FLAG_FACE
64: on faces
◆ CS_FLAG_FULL_LOC
1: defined on the whole location
◆ CS_FLAG_INITIALIZATION
◆ CS_FLAG_PRIMAL
256: on primal mesh
◆ CS_FLAG_SCALAR
2: scalar-valued (stride = 1)
◆ CS_FLAG_SCHEME_NAVSTO
4: Navier-Stokes system
◆ CS_FLAG_SCHEME_POLY0
8: lowest-order scheme
◆ CS_FLAG_SCHEME_POLY1
16: Linear gradient approx.
◆ CS_FLAG_SCHEME_POLY2
32: Quadratic gradient approx.
◆ CS_FLAG_SCHEME_SCALAR
1: scheme for scalar eq.
◆ CS_FLAG_SCHEME_VECTOR
2: scheme for a vector eq.
◆ CS_FLAG_SOLID_CELL
◆ CS_FLAG_STATE_CELLWISE
2: cellwise uniform
◆ CS_FLAG_STATE_CIRCULATION
32: circulation
◆ CS_FLAG_STATE_DENSITY
128: density
◆ CS_FLAG_STATE_FACEWISE
4: uniform on each face
◆ CS_FLAG_STATE_FLUX
64: flux
◆ CS_FLAG_STATE_POTENTIAL
16: potential
◆ CS_FLAG_STATE_STEADY
8: steady
◆ CS_FLAG_STATE_UNIFORM
1: uniform (in space)
◆ CS_FLAG_SYS_MASS_MATRIX
1: build a mass matrix
◆ CS_FLAG_SYS_REAC_DIAG
8: lump the reaction term
◆ CS_FLAG_SYS_SOURCES_HLOC
16: Hodge op. for source terms
◆ CS_FLAG_SYS_SYM
2: system matrix is symmetric
◆ CS_FLAG_SYS_TIME_DIAG
4: lump the time term
◆ CS_FLAG_SYS_VECTOR
32: vector-valued variable
◆ CS_FLAG_TENSOR
8: tensor-valued (stride = 9)
◆ CS_FLAG_VECTOR
4: vector-valued (stride = 3)
◆ CS_FLAG_VERTEX
16: on vertices
Typedef Documentation
◆ cs_eflag_t
◆ cs_mask_t
◆ cs_flag_comp_bits_t
Enumerator
CS_FLAG_COMP_PV
CS_FLAG_COMP_PVQ
CS_FLAG_COMP_PE
CS_FLAG_COMP_PEQ
CS_FLAG_COMP_DFQ
CS_FLAG_COMP_PF
CS_FLAG_COMP_PFQ
CS_FLAG_COMP_DEQ
CS_FLAG_COMP_EV
CS_FLAG_COMP_FE
CS_FLAG_COMP_FEQ
CS_FLAG_COMP_FV
CS_FLAG_COMP_EF
CS_FLAG_COMP_SEF
CS_FLAG_COMP_HFQ
CS_FLAG_COMP_FES
CS_FLAG_COMP_PFC
CS_FLAG_COMP_PEC
CS_FLAG_COMP_DIAM
◆ cs_flag_location_t
Enumerator
CS_FLAG_N_LOCATIONS
◆ cs_eflag_test()
static bool cs_eflag_test ( cs_eflag_t  flag_to_check,
inlinestatic
[in]flag_to_checkflag corresponding to the location to check
[in]referenceflag corresponding to the referenced support
true or false
◆ cs_flag_at_least()
static bool cs_flag_at_least ( cs_flag_t  flag_to_check,
int  n_masks,
cs_flag_t  masks[]
inlinestatic
[in]n_masksnumber of masks to check
[in]masksarray of masks
true or false
◆ cs_flag_str_location()
const char* cs_flag_str_location ( cs_flag_t  loc)
a string
◆ cs_flag_test()
static bool cs_flag_test ( cs_flag_t  flag_to_check,
cs_flag_t  reference
inlinestatic
true or false
◆ cs_flag_boundary_face
◆ cs_flag_cell
◆ cs_flag_dual_cell
◆ cs_flag_dual_cell_byc
◆ cs_flag_dual_closure_byf
◆ cs_flag_dual_face
◆ cs_flag_dual_face_byc
◆ cs_flag_dual_vtx
◆ cs_flag_need_deq
◆ cs_flag_need_dfq
◆ cs_flag_need_e
◆ cs_flag_need_ef
◆ cs_flag_need_f
◆ cs_flag_need_fe
◆ cs_flag_need_peq
◆ cs_flag_need_pfc
◆ cs_flag_need_pfq
◆ cs_flag_need_v
◆ cs_flag_primal_cell
◆ cs_flag_primal_edge
◆ cs_flag_primal_face
◆ cs_flag_primal_vtx
◆ cs_flag_vertex
