7.3
cs_cdofb_priv.h
1 #ifndef __CS_CDOFB_PRIV_H__
2 #define __CS_CDOFB_PRIV_H__
5  * Definition of cs_cdofb_scaleq_t and cs_cdofb_vecteq structures
29  * Local headers
32 #include "cs_cdo_advection.h"
33 #include "cs_equation_bc.h"
34 #include "cs_equation_builder.h"
35 #include "cs_hodge.h"
36
38
42  * Macro definitions
46  * Type definitions
48
49 /* Algebraic system for CDO face-based discretization */
50
51 struct _cs_cdofb_t {
52
53  /* Ids related to the variable field and to the boundary flux field */
54
57
58  /* System size (n_faces + n_cells) */
59
62
63  /* Solution of the algebraic system DoF unknowns (x) + BCs */
64
65  cs_real_t *face_values; /* At the last iteration */
66  cs_real_t *face_values_pre; /* At the previous iteration */
67
68  /* Members related to the static condensation */
69
70  cs_real_t *rc_tilda; /* Acc^-1 * RHS_cell */
71  cs_real_t *acf_tilda; /* Acc^-1 * Acf
72  Cell-faces lower-left block of the full matrix
73  Access to the values thanks to the c2f
74  connectivity */
75
76  /* Array storing the value arising from the contribution of all source
77  terms (only allocated to n_cells) */
78
80
81  /* Pointer of function to build the diffusion term */
82
88
89  /* Pointer of functions to define the advection term:
90  * advection_open is called first, then advection_main which calls
91  * advection_scheme and after the build step, advection_close is called last
92  */
93
98
100
101  /* If one needs to build a local hodge op. for time and reaction */
102
106
107 };
108
109 typedef struct _cs_cdofb_t cs_cdofb_priv_t;
110
111 /*============================================================================
112  * Public function prototypes
113  *============================================================================*/
114
115 /*----------------------------------------------------------------------------*/
124 /*----------------------------------------------------------------------------*/
125
126 void
129  cs_cdofb_priv_t *eqc);
130
131 /*----------------------------------------------------------------------------*/
132
134
135 #endif /* __CS_CDOFB_PRIV_H__ */
cs_cdo_enforce_bc_t * enforce_dirichlet
Definition: cs_cdofb_priv.h:85
cs_lnum_t n_faces
Definition: cs_cdofb_priv.h:60
void() cs_cdofb_adv_close_hook_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Operation done after the matrix related to the advection term has been defined.
Definition: cs_cdo_advection.h:136
void() cs_cdofb_adv_build_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb)
Build the cellwise advection operator for CDO-Fb schemes The local matrix related to this operator is...
Definition: cs_cdo_advection.h:116
cs_real_t * rc_tilda
Definition: cs_cdofb_priv.h:70
cs_hodge_t ** diffusion_hodge
Definition: cs_cdofb_priv.h:83
void() cs_cdo_enforce_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Enforcement of a boundary condition (Dirichlet, Robin, sliding...)
Definition: cs_equation_bc.h:89
int var_field_id
Definition: cs_cdofb_priv.h:55
cs_hodge_compute_t * get_mass_matrix
Definition: cs_cdofb_priv.h:105
Definition: cs_defs.h:512
cs_cdofb_adv_scheme_t * advection_scheme
Definition: cs_cdofb_priv.h:97
cs_hodge_compute_t * get_stiffness_matrix
Definition: cs_cdofb_priv.h:84
cs_hodge_param_t mass_hodgep
Definition: cs_cdofb_priv.h:103
Definition: cs_hodge.h:186
cs_cdofb_adv_close_hook_t * advection_close
Definition: cs_cdofb_priv.h:96
cs_hodge_t ** mass_hodge
Definition: cs_cdofb_priv.h:104
Definition: cs_defs.h:322
int bflux_field_id
Definition: cs_cdofb_priv.h:56
cs_cdo_enforce_bc_t * enforce_sliding
Definition: cs_cdofb_priv.h:87
cs_real_t * face_values_pre
Definition: cs_cdofb_priv.h:66
void * advection_input
Definition: cs_cdofb_priv.h:99
cs_real_t * source_terms
Definition: cs_cdofb_priv.h:79
cs_lnum_t n_dofs
Definition: cs_cdofb_priv.h:61
cs_real_t * acf_tilda
Definition: cs_cdofb_priv.h:71
cs_cdo_enforce_bc_t * enforce_robin_bc
Definition: cs_cdofb_priv.h:86
void() cs_cdofb_adv_open_hook_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, void *input, cs_cell_builder_t *cb)
Perform preprocessing such as the computation of the advection flux at the expected location in order...
Definition: cs_cdo_advection.h:71
Definition: cs_defs.h:316
Definition: cs_defs.h:513
void() cs_cdofb_adv_scheme_t(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Define the local convection operator in CDO-Fb schemes. Case of an operator that should be assemble i...
Definition: cs_cdo_advection.h:92
cs_cdofb_adv_open_hook_t * advection_open
Definition: cs_cdofb_priv.h:94
Definition: cs_cdofb_priv.h:51
bool() cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a discrete Hodge operator or a related operator (such as the stiffmess matrix) for a given cell...
Definition: cs_hodge.h:221
void cs_cdofb_set_advection_function(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, cs_cdofb_priv_t *eqc)
Set the advection-related parameters in the context structure of CDO face-based schemes.
Definition: cs_cdofb_priv.c:90
Definition: cs_cdofb_priv.h:65
Structure storing all metadata/parameters related to the usage of a discrete Hodge operator...
Definition: cs_hodge.h:154
cs_cdofb_adv_build_t * advection_main
Definition: cs_cdofb_priv.h:95
