7.3
cs_cdofb_predco.h File Reference
#include "cs_cdo_connect.h"
#include "cs_equation.h"
#include "cs_navsto_coupling.h"
#include "cs_navsto_param.h"
#include "cs_source_term.h"
#include "cs_time_step.h"
+ Include dependency graph for cs_cdofb_predco.h:
cs_real_tcs_cdofb_predco_get_face_pressure (void *context)
 Retrieve the values of the pressure at faces. More...
void cs_cdofb_predco_init_common (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
void * cs_cdofb_predco_init_scheme_context (const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nsc_input)
 Initialize a cs_cdofb_predco_t structure. More...
void * cs_cdofb_predco_free_scheme_context (void *scheme_context)
 Destroy a cs_cdofb_predco_t structure. More...
void cs_cdofb_predco_set_sles (const cs_navsto_param_t *nsp, void *context)
 Start setting-up the Navier-Stokes equations when an AC algorithm is used to couple the system. No mesh information is available at this stage. More...
void cs_cdofb_predco_compute_implicit (const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
 Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a Artificial Compressibility approach and an Euler time scheme. More...
◆ cs_cdofb_predco_compute_implicit()
void cs_cdofb_predco_compute_implicit ( const cs_mesh_t mesh,
const cs_navsto_param_t nsp,
void *  scheme_context
[in,out]scheme_contextpointer to a structure cast on-the-fly
◆ cs_cdofb_predco_free_scheme_context()
void* cs_cdofb_predco_free_scheme_context ( void *  scheme_context)
[in]scheme_contextpointer to a scheme context structure to free
a NULL pointer
◆ cs_cdofb_predco_get_face_pressure()
cs_real_t* cs_cdofb_predco_get_face_pressure ( void *  context)
[in]contextpointer to a scheme context structure
a pointer to the pressure values
◆ cs_cdofb_predco_init_common()
void cs_cdofb_predco_init_common ( const cs_cdo_quantities_t quant,
const cs_time_step_t time_step
◆ cs_cdofb_predco_init_scheme_context()
void* cs_cdofb_predco_init_scheme_context ( const cs_navsto_param_t nsp,
cs_adv_field_t adv_field,
cs_real_t mflux,
cs_real_t mflux_pre,
cs_boundary_type_t fb_type,
void *  nsc_input
[in]mfluxcurrent values of the mass flux across primal faces
[in]mflux_preprevious values of the mass flux across primal faces
[in]fb_typetype of boundary for each boundary face
[in]nsc_inputpointer to a cs_navsto_projection_t structure
a pointer to a new allocated cs_cdofb_predco_t structure
◆ cs_cdofb_predco_set_sles()
void cs_cdofb_predco_set_sles ( const cs_navsto_param_t nsp,
void *  context
[in,out]contextpointer to a context structure cast on-the-fly
