| type | var_cal_opt |
| type | solving_info |
| type | gwf_soilwater_partition |
| type | gas_mix_species_prop |
| interface | beta_limiter_building |
| interface | boundary_conditions_mapped_set |
| | Set mapped boundary conditions for a given field and mapping locator. More...
| interface | cs_f_field_set_key_struct_var_cal_opt |
| interface | cs_f_field_get_key_struct_var_cal_opt |
| interface | equation_param_from_vcopt |
| interface | cs_fan_n_fans |
| | Return the number of fans. More...
| interface | cs_log_default_activate |
| interface | cs_log_default_is_active |
| interface | log_iteration |
| interface | cs_log_iteration_prepare |
| interface | log_l2residual |
| interface | cs_turb_model_init |
| interface | cs_set_type_order_turbulence_model |
| interface | cs_f_scalar_clipping |
| interface | cs_intprf |
| interface | cs_intprz |
| interface | les_filter |
| | Compute filters for dynamic models. More...
| interface | les_balance_create |
| | Create the LES balance structure. More...
| interface | les_balance_finalize |
| | Destroy the LES balance structure. More...
| interface | les_balance_write_restart |
| | Write the LES balance restart file. More...
| interface | les_balance_update_gradients |
| | Compute additional time averages for LES balance. More...
| interface | les_balance_compute |
| | Compute the LES balance. More...
| interface | cs_map_name_to_id_destroy |
| | Destroy name to id map structure. More...
| interface | parameters_read_restart_info |
| | Read restart metadata. More...
| interface | restart_destroy |
| | Destroy structure associated with a restart file (and close the file). More...
| interface | restart_check_base_location |
| | Check the locations associated with a restart file. More...
| interface | restart_read_field_info |
| | Read field metadata from checkpoint. More...
| interface | restart_write_field_info |
| | Write field metadata to checkpoint. More...
| interface | restart_read_bc_coeffs |
| | Read boundary condition coefficients for all fields from checkpoint. More...
| interface | restart_write_bc_coeffs |
| | Write boundary condition coefficients for all fields to checkpoint. More...
| interface | restart_write_fields |
| | Loop over all fields and save them in the restart file which id is passed in argument if it matches their "restart_file" key value. More...
| interface | restart_read_fields |
| | Loop over all fields and read them in the restart file which id is passed in argument if it matches their "restart_file" key value. More...
| interface | restart_clean_multiwriters_history |
| | Remove all previous dumps of checkpoint files which are not to be saved. More...
| interface | cs_syr_coupling_n_couplings |
| interface | cs_time_moment_n_moments |
| | Return the number of temporal moments. More...
| interface | cs_time_moment_is_active |
| | Return if moment is active (1) or not (0). More...
| interface | time_moment_update_all |
| | Update temporal moments. More...
| interface | time_moment_log_iteration |
| | Log temporal moments initialization. More...
| interface | time_moment_field_id |
| | Get field id associated with a given moment. More...
| interface | time_moment_restart_read |
| | Read temporal moments checkpoint information. More...
| interface | time_moment_restart_write |
| | Checkpoint temporal moments. More...
| interface | timer_stats_increment_time_step |
| | Increment time step for timer statistics. More...
| interface | timer_stats_set_plot |
| | Enable or disable plotting for a timer statistic. More...
| interface | timer_stats_start |
| | Start a timer for a given statistic. More...
| interface | timer_stats_stop |
| | Stop a timer for a given statistic. More...
| interface | timer_stats_switch |
| | Start a timer for a given statistic, stopping previous timers of the same type which are not a parent, and starting inactive parent timers if necessary. More...
| interface | turbulence_bc_ke_hyd_diam |
| | Calculation of , and from a diameter and the reference velocity for a circular duct flow with smooth wall (use for inlet boundary conditions). More...
| interface | turbulence_bc_ke_turb_intensity |
| | Calculation of and from a diameter , a turbulent intensity and the reference velocity for a circular duct flow with smooth wall (for inlet boundary conditions). More...
| interface | turbulence_bc_rij_transform |
| | Compute matrix used in the computation of the Reynolds stress tensor boundary conditions. More...
| interface | turbulence_bc_inlet_hyd_diam |
| | Set inlet boundary condition values for turbulence variables based on a diameter and the reference velocity for a circular duct flow with smooth wall. More...
| interface | turbulence_bc_inlet_turb_intensity |
| | Set inlet boundary condition values for turbulence variables based on a diameter , a turbulent intensity and the reference velocity for a circular duct flow with smooth wall. More...
| interface | turbulence_bc_inlet_k_eps |
| | Set inlet boundary condition values for turbulence variables based on given k and epsilon values. More...
| interface | turbulence_bc_set_uninit_inlet_k_eps |
| | Set inlet boundary condition values for turbulence variables based on given k and epsilon values only if not initialized already. More...
| interface | cs_immersed_boundary_wall_functions |
| | Compute boundary contributions for all immersed boundaries. More...
| interface | yg2xye |
| | Compute molar and mass fractions of elementary species Ye, Xe (fuel, O2, CO2, H2O, N2) from global species Yg (fuel, oxidant, products) More...
| interface | user_parameters |
| | General user parameters. More...
| interface | user_porosity |
| subroutine | balance_by_zone (sel_crit, name) |
| | Compute balance on a given zone for a given scalar. More...
| subroutine | intprf (nprofz, nproft, profz, proft, profv, xz, temps, var) |
| | Temporal and z-axis interpolation for meteorological profiles. More...
| subroutine | intprz (nprofz, profz, profv, xz, iz1, iz2, var) |
| | z-axis interpolation for meteorological profiles More...
| subroutine | pressure_drop_by_zone (sel_crit) |
| | Compute pressure drop for a given zone. More...
| subroutine | promav (isym, ibsize, iesize, f_id, dam, xam, vx, vy) |
| subroutine | surface_balance (sel_crit, name, normal) |
| | Compute surface scalar balance for a given surface area. More...
| subroutine | boundary_conditions_error (bc_type) |
| | Handle boundary condition definition errors and associated output. More...
| type(c_ptr) function | boundary_conditions_map (location_type, n_location_elts, n_faces, location_elts, faces, coord_shift, coord_stride, tolerance) |
| | Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later interpolation. More...
| subroutine | field_set_key_struct_var_cal_opt (f_id, k_value) |
| | Assign a var_cal_opt for a cs_var_cal_opt_t key to a field. More...
| subroutine | field_set_key_struct_solving_info (f_id, k_value) |
| | Assign a solving_info for a cs_solving_info_t key to a field. More...
| subroutine | field_set_key_struct_gwf_soilwater_partition (f_id, k_value) |
| | Assign a gwf_soilwater_partition for a cs_gwf_soilwater_partition_t key to a field. More...
| subroutine | field_set_key_struct_gas_mix_species_prop (f_id, k_value) |
| | Assign a gas_mix_species_prop for a cs_gas_mix_species_prop_t key to a field. More...
| subroutine | field_get_key_struct_var_cal_opt (f_id, k_value) |
| | Return a pointer to the var_cal_opt structure for cs_var_cal_opt key associated with a field. More...
| subroutine | field_get_key_struct_solving_info (f_id, k_value) |
| | Return a pointer to the solving_info structure for cs_solving_info_t key associated with a field. More...
| subroutine | field_get_key_struct_gwf_soilwater_partition (f_id, k_value) |
| | Return a pointer to the gwf_soilwater_partition structure for cs_gwf_soilwater_partition_t key associated with a field. More...
| subroutine | field_get_key_struct_gas_mix_species_prop (f_id, k_value) |
| | Return a pointer to the gas_mix_species_prop structure for cs_gas_mix_species_prop_t key associated with a field. More...
| subroutine | gradient_s (f_id, imrgra, inc, nswrgp, imligp, iwarnp, epsrgp, climgp, pvar, coefap, coefbp, grad) |
| | Compute cell gradient. More...
| subroutine | gradient_weighted_s (f_id, imrgra, inc, nswrgp, imligp, hyd_p_flag, iwarnp, epsrgp, climgp, f_ext, pvar, c_weight, coefap, coefbp, grad) |
| | Compute cell gradient of a scalar with weighting. More...
| subroutine | locator_destroy (this_locator) |
| | Destruction of a locator structure. More...
| subroutine | log_iteration_add_array (name, category, location, is_intensive, dim, val) |
| | Add array not saved as permanent field to logging of fields. More...
| subroutine | log_iteration_clipping (name, dim, n_clip_min, n_clip_max, min_pre_clip, max_pre_clip) |
| subroutine | log_iteration_clipping_field (f_id, n_clip_min, n_clip_max, min_pre_clip, max_pre_clip, n_clip_min_comp, n_clip_max_comp) |
| subroutine | restart_create (name, path, mode, r) |
| | Initialize a restart file. More...
| subroutine | restart_read_variables (r, old_field_map, t_id_flag) |
| | Read variables from checkpoint. More...
| subroutine | restart_write_variables (r, t_id_flag) |
| | Write variables to checkpoint. More...
| subroutine | restart_read_section_int_t (r, sec_name, location_id, n_loc_vals, val, ierror) |
| | Read a section of integers from a restart file. More...
| subroutine | restart_read_int_t_compat (r, sec_name, old_name, location_id, n_loc_vals, val, ierror) |
| | Read a section of integers from a restart file, when that section may have used a different name in a previous version. More...
| subroutine | restart_write_section_int_t (r, sec_name, location_id, n_loc_vals, val) |
| | Write a section of integers to a checkpoint file. More...
| subroutine | restart_read_section_real_t (r, sec_name, location_id, n_loc_vals, val, ierror) |
| | Read a section of doubles from a restart file. More...
| subroutine | restart_read_real_t_compat (r, sec_name, old_name, location_id, n_loc_vals, val, ierror) |
| | Read a section of double precision reals from a restart file, when that section may have used a different name in a previous version. More...
| subroutine | restart_read_real_3_t_compat (r, sec_name, old_name_x, old_name_y, old_name_z, location_id, val, ierror) |
| | Read a vector of double precision reals of dimension (3,*) from a restart file, when that section may have used a different name and been non-interleaved in a previous version. More...
| subroutine | restart_write_section_real_t (r, sec_name, location_id, n_loc_vals, val) |
| | write a section of doubles to a checkpoint file. More...
| subroutine | restart_read_field_vals (r, f_id, t_id, ierror) |
| | Read field values from checkpoint. More...
| subroutine | restart_write_field_vals (r, f_id, t_id) |
| | Write field values to checkpoint. More...
| subroutine | restart_read_linked_fields (r, old_field_map, key, n_w) |
| | Read fields depending on others from checkpoint. More...
| subroutine | restart_write_linked_fields (r, key, n_w) |
| | Write fields depending on others to checkpoint. More...
| subroutine | sles_solve_native (f_id, name, isym, ibsize, iesize, dam, xam, epsilp, rnorm, niter, residue, rhs, vx) |
| | Call sparse linear equation solver using native matrix arrays. More...
| subroutine | sles_free_native (f_id, name) |
| | Free sparse linear equation solver setup using native matrix arrays. More...
| subroutine | sles_push (f_id, name) |
| | Temporarily replace field id with name for matching calls to sles_solve_native. More...
| subroutine | sles_pop (f_id) |
| | Revert to normal behavior of field id for matching calls to sles_solve_native. More...
| integer function | timer_stats_create (parent_name, name, label) |
| | Create a timer statistics structure. More...
| integer function | timer_stats_id_by_name (name) |
| | Return the id of a defined statistic based on its name. More...
| subroutine | variable_field_create (name, label, location_id, dim, id) |
| | Add field defining a general solved variable, with default options. More...
| subroutine | variable_cdo_field_create (name, label, location_id, dim, has_previous, id) |
| | Add a CDO field defining a general solved variable, with default options. More...
| integer function | volume_zone_n_type_zones (type_flag) |
| | Return the number of volume zones associated with a given type flag. More...
| integer function | volume_zone_n_type_cells (type_flag) |
| | Return the number of volume zone cells associated with a given type flag. More...
| subroutine | volume_zone_select_type_cells (type_flag, cell_list) |
| | Return the list of volume zone cells associated with a given type flag. More...
| subroutine | field_get_coupled_faces (f_id, cpl_faces) |
| | Return pointer to coupling face indicator for a field. More...
| double precision function | notebook_parameter_value_by_name (name) |
| | Return notebook parameter value. More...
| integer function | cell_is_active (iel) |
| | Indicate of a cell is active fo the current variable. More...
| subroutine | atmo_set_meteo_file_name (name) |
| | Sets the meteo file name. More...
| subroutine | atmo_set_chem_conc_file_name (name) |
| | Sets the chemistry concentration file name. More...
| subroutine | atmo_set_aero_conc_file_name (name) |
| | Sets the aerosol concentration file name. More...
| subroutine | atmo_chemistry_set_spack_file_name (name) |
| | Sets the file name used to initialize SPACK. More...
| subroutine | atmo_chemistry_set_aerosol_file_name (name) |
| | Sets the file name used to initialize the aerosol shared library. More...
| subroutine | clpsca (iscal) |
| | brief Clipping scalar field. More...
