| void | cs_array_real_copy_sublist (cs_lnum_t n_elts, int stride, const cs_lnum_t elt_ids[], int mode, const cs_real_t ref[], cs_real_t dest[]) |
| | Copy an array ("ref") into another array ("dest") on possibly only a part of the array(s). Array with stride > 1 are assumed to be interlaced. The sublist of element on which working is defined by "elt_ids" (of size "n_elts"). The way to apply the sublist is set with the parameter "mode" as follows: More...
| void | cs_array_real_copy (cs_lnum_t n_elts, cs_lnum_t dim, const cs_real_t src[], cs_real_t dest[restrict]) |
| | Copy real values from an array to another of the same dimensions. More...
| void | cs_array_real_set_scalar (cs_lnum_t n_elts, cs_real_t ref_val, cs_real_t a[]) |
| | Assign a constant scalar value to an array. More...
| void | cs_array_real_set_scalar_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t ref_val, cs_real_t a[]) |
| | Assign a constant scalar value to an array on a selected subset of elements. If elt_ids = NULL, then one recovers the function cs_array_real_set_scalar. More...
| void | cs_array_real_set_vector (cs_lnum_t n_elts, const cs_real_t ref_val[3], cs_real_t *a) |
| | Assign a constant vector to an array of stride 3 which is interlaced. More...
| void | cs_array_real_set_vector_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_val[3], cs_real_t a[]) |
| | Assign a constant vector to an interlaced array (of stride 3) on a selected subset of elements. If elt_ids = NULL, then one recovers the function cs_array_real_set_vector. More...
| void | cs_array_real_set_symm_tensor (cs_lnum_t n_elts, const cs_real_t ref_val[6], cs_real_t *a) |
| | Assign a constant vector of size 6 (optimized way to define a symmetric tensor) to an array (of stride 6) which is interlaced. More...
| void | cs_array_real_set_symm_tensor_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_val[6], cs_real_t *a) |
| | Assign a constant vector of size 6 (optimized way to define a symmetric tensor) to an interlaced array (of stride 6) on a selected subset of elements. If elt_ids = NULL, then one recovers the function cs_array_real_set_symm_tensor. More...
| void | cs_array_real_set_tensor (cs_lnum_t n_elts, const cs_real_t ref_tens[3][3], cs_real_t *a) |
| | Assign a constant 3x3 tensor to an array (of stride 9) which is interlaced. More...
| void | cs_array_real_set_tensor_on_subset (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], const cs_real_t ref_tens[3][3], cs_real_t *a) |
| | Assign a constant 3x3 tensor to an interlaced array (of stride 9) on a subset of elements. If elt_ids = NULL, then one recovers the function cs_array_real_set_tensor. More...
| void | cs_array_real_fill_zero (cs_lnum_t size, cs_real_t a[]) |
| | Assign zero to all elements of an array. More...
| void | cs_array_set_value_real (cs_lnum_t n_elts, cs_lnum_t dim, cs_real_t v, cs_real_t a[]) |
| | Assign a constant value to an array (deprecated function). More...
Array handling utilities.
- Only the "ref" array if mode = 0 (CS_ARRAY_IN_SUBLIST)
- Only the "dest" array if mode = 1 (CS_ARRAY_OUT_SUBLIST)
- Both "ref" and "dest" arrays if mode = 2 (CS_ARRAY_INOUT_SUBLIST)
It elt_ids = NULL or mode < 0 (CS_ARRAY_NO_SUBLIST), then the behavior is as cs_array_real_copy
One assumes that all arrays are allocated with a correct size.
- Parameters
| [in] | n_elts | number of elements in the array |
| [in] | stride | number of values for each element |
| [in] | mode | type of indirection to apply |
| [in] | elt_ids | sub list of element ids to consider |
| [in] | ref | reference values to copy |
| [in,out] | dest | array storing values after applying the indirection |
