Module for code/code coupling. More...
Modules | |
| module | cplsat |
| integer, save | nbrcpl |
| number of couplings code_saturne / code_saturne More... | |
| integer, save | ifaccp |
| indicator coupling face / face only More... | |
| integer | nbcpmx |
| maximum permissible number of coupling More... | |
| integer, dimension(nbcpmx), save | iturcp |
| turbulence model of the remote instance More... | |
| integer, dimension(nbcpmx), save | imajcp |
| indicator to update location of the coupling More... | |
| integer, dimension(nbcpmx), save | icormx |
| indicator of calulation in relative reference frame More... | |
| integer, dimension(nbcpmx), save | nvarcp |
| number of variables to send/receive More... | |
| integer, dimension(nbcpmx), save | nvarto |
| size of exchange tables More... | |
| double precision, save | ttpmob |
| Absolute time value after the mesh starts to rotate (if it does), for previous calculation. More... | |
| double precision, save | ttcmob |
| Current absolute time after the mesh starts to rotate (if it does). In case of restart, this is equal to ttpmob + additional computed time. More... | |
