This subroutine performs the solving of epsilon in
RANS turbulence model.
More...
| subroutine | reseps (nvar, ncesmp, icetsm, itypsm, dt, gradv, produc, gradro, smacel, viscf, viscb, smbr, rovsdt) |
◆ reseps()
| subroutine reseps |
integer |
nvar, |
integer |
ncesmp, |
integer, dimension(ncesmp) |
icetsm, |
integer, dimension(ncesmp,nvar) |
itypsm, |
double precision, dimension(ncelet) |
dt, |
double precision, dimension(3, 3, ncelet) |
gradv, |
double precision, dimension(6,ncelet) |
produc, |
double precision, dimension(3,ncelet) |
gradro, |
double precision, dimension(ncesmp,nvar) |
smacel, |
double precision, dimension(nfac) |
viscf, |
double precision, dimension(nfabor) |
viscb, |
smbr, |
rovsdt |
- Parameters
| [in] | icepdc | index of cells with head loss |
| [in] | itypsm | type of mass source term for each variable |
| [in] | gradv | work array for the term grad of velocity only for iturb=31 |
| [in] | produc | work array for production (without rho volume) only for iturb=30 |
| [in] | gradro | work array for |
| [in] | ckupdc | work array for the head loss |
| [in] | smacel | value associated to each variable in the mass source terms or mass rate |
| [in] | viscf | visc*surface/dist at internal faces |
| [in] | viscb | visc*surface/dist at edge faces |
| [in] | smbr | working array |
| [in] | rovsdt | working array |
