Update the density
with the
density with the state law and a thermodynamic pressure
estimated from the integral over the total fluid domain of the mass conservation equation.
More...
subroutine | pthrbm (nvar, ncesmp, nfbpcd, ncmast, dt, smacel, spcond, svcond) |
◆ pthrbm()
subroutine pthrbm |
integer |
nvar, |
integer |
ncesmp, |
integer |
nfbpcd, |
integer |
ncmast, |
double precision, dimension(ncelet) |
dt, |
double precision, dimension(ncesmp,nvar) |
smacel, |
double precision, dimension(nfbpcd,nvar) |
spcond, |
double precision, dimension(ncelet,nvar) |
svcond |
- Parameters
[in] | nvar | total number of variables |
[in] | ncesmp | number of cells with mass source term |
[in] | nfbpcd | number of faces with condensation source terms |
[in] | ncmast | number of cells with condensation source terms |
[in] | dt | time step (per cell) |
[in] | smacel | variable value associated to the mass source term (for ivar=ipr, smacel is the mass flux ) |
[in] | spcond | variable value associated to the condensation source term (for ivar=ipr, spcond is the flow rate ) |
[in] | svcond | variable value associated to the condensation source term (for ivar=ipr, svcond is the flow rate ) |
