Data Types | |
| interface | beta_limiter_building |
| interface | boundary_conditions_mapped_set |
| Set mapped boundary conditions for a given field and mapping locator. More... | |
| interface | cs_f_field_get_key_struct_var_cal_opt |
| interface | cs_f_field_set_key_struct_var_cal_opt |
| interface | cs_fan_n_fans |
| Return the number of fans. More... | |
| interface | cs_intprf |
| interface | cs_intprz |
| interface | cs_log_default_activate |
| interface | cs_log_default_is_active |
| interface | cs_map_name_to_id_destroy |
| Destroy name to id map structure. More... | |
| interface | cs_set_type_order_turbulence_model |
| interface | cs_syr_coupling_n_couplings |
| interface | cs_time_moment_is_active |
| Return if moment is active (1) or not (0). More... | |
| interface | cs_time_moment_n_moments |
| Return the number of temporal moments. More... | |
| interface | cs_turb_model_init |
| interface | equation_param_from_vcopt |
| type | gas_mix_species_prop |
| type | gwf_soilwater_partition |
| interface | les_balance_compute |
| Compute the LES balance. More... | |
| interface | les_balance_create |
| Create the LES balance structure. More... | |
| interface | les_balance_finalize |
| Destroy the LES balance structure. More... | |
| interface | les_balance_update_gradients |
| Compute additional time averages for LES balance. More... | |
| interface | les_balance_write_restart |
| Write the LES balance restart file. More... | |
| interface | les_filter |
| Compute filters for dynamic models. More... | |
| interface | log_iteration |
| interface | log_l2residual |
| interface | parameters_read_restart_info |
| Read restart metadata. More... | |
| interface | restart_check_base_location |
| Check the locations associated with a restart file. More... | |
| interface | restart_clean_multiwriters_history |
| Remove all previous dumps of checkpoint files which are not to be saved. More... | |
| interface | restart_destroy |
| Destroy structure associated with a restart file (and close the file). More... | |
| interface | restart_read_bc_coeffs |
| Read boundary condition coefficients for all fields from checkpoint. More... | |
| interface | restart_read_field_info |
| Read field metadata from checkpoint. More... | |
| interface | restart_read_fields |
| Loop over all fields and read them in the restart file which id is passed in argument if it matches their "restart_file" key value. More... | |
| interface | restart_write_bc_coeffs |
| Write boundary condition coefficients for all fields to checkpoint. More... | |
| interface | restart_write_field_info |
| Write field metadata to checkpoint. More... | |
| interface | restart_write_fields |
| Loop over all fields and save them in the restart file which id is passed in argument if it matches their "restart_file" key value. More... | |
| type | solving_info |
| interface | time_moment_field_id |
| Get field id associated with a given moment. More... | |
| interface | time_moment_log_iteration |
| Log temporal moments initialization. More... | |
| interface | time_moment_restart_read |
| Read temporal moments checkpoint information. More... | |
| interface | time_moment_restart_write |
| Checkpoint temporal moments. More... | |
| interface | time_moment_update_all |
| Update temporal moments. More... | |
| interface | timer_stats_increment_time_step |
| Increment time step for timer statistics. More... | |
| interface | timer_stats_set_plot |
| Enable or disable plotting for a timer statistic. More... | |
| interface | timer_stats_start |
| Start a timer for a given statistic. More... | |
| interface | timer_stats_stop |
| Stop a timer for a given statistic. More... | |
| interface | timer_stats_switch |
| Start a timer for a given statistic, stopping previous timers of the same type which are not a parent, and starting inactive parent timers if necessary. More... | |
| interface | turbulence_bc_inlet_hyd_diam |
Set inlet boundary condition values for turbulence variables based on a diameter and the reference velocity for a circular duct flow with smooth wall. More... | |
| interface | turbulence_bc_inlet_k_eps |
| Set inlet boundary condition values for turbulence variables based on given k and epsilon values. More... | |
| interface | turbulence_bc_inlet_turb_intensity |
Set inlet boundary condition values for turbulence variables based on a diameter , a turbulent intensity and the reference velocity for a circular duct flow with smooth wall. More... | |
| interface | turbulence_bc_ke_hyd_diam |
Calculation of , and from a diameter and the reference velocity for a circular duct flow with smooth wall (use for inlet boundary conditions). More... | |
| interface | turbulence_bc_ke_turb_intensity |
Calculation of and from a diameter , a turbulent intensity and the reference velocity for a circular duct flow with smooth wall (for inlet boundary conditions). More... | |
| interface | turbulence_bc_rij_transform |
Compute matrix used in the computation of the Reynolds stress tensor boundary conditions. More... | |
| interface | turbulence_bc_set_uninit_inlet_k_eps |
| Set inlet boundary condition values for turbulence variables based on given k and epsilon values only if not initialized already. More... | |
| interface | user_parameters |
| General user parameters. More... | |
| interface | user_porosity |
| type | var_cal_opt |
| interface | yg2xye |
| Compute molar and mass fractions of elementary species Ye, Xe (fuel, O2, CO2, H2O, N2) from global species Yg (fuel, oxidant, products) More... | |
Functions/Subroutines | |
| subroutine | balance_by_zone (sel_crit, name) |
| Compute balance on a given zone for a given scalar. More... | |
| subroutine | intprf (nprofz, nproft, profz, proft, profv, xz, temps, var) |
| Temporal and z-axis interpolation for meteorological profiles. More... | |
| subroutine | intprz (nprofz, profz, profv, xz, iz1, iz2, var) |
| z-axis interpolation for meteorological profiles More... | |
| subroutine | pressure_drop_by_zone (sel_crit) |
| Compute pressure drop for a given zone. More... | |
| subroutine | promav (isym, ibsize, iesize, f_id, dam, xam, vx, vy) |
| subroutine | surface_balance (sel_crit, name, normal) |
| Compute surface scalar balance for a given surface area. More... | |
| subroutine | boundary_conditions_error (bc_type) |
| Handle boundary condition definition errors and associated output. More... | |
| type(c_ptr) function | boundary_conditions_map (location_type, n_location_elts, n_faces, location_elts, faces, coord_shift, coord_stride, tolerance) |
| Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later interpolation. More... | |
| subroutine | field_set_key_struct_var_cal_opt (f_id, k_value) |
| Assign a var_cal_opt for a cs_var_cal_opt_t key to a field. More... | |
| subroutine | field_set_key_struct_solving_info (f_id, k_value) |
| Assign a solving_info for a cs_solving_info_t key to a field. More... | |
| subroutine | field_set_key_struct_gwf_soilwater_partition (f_id, k_value) |
| Assign a gwf_soilwater_partition for a cs_gwf_soilwater_partition_t key to a field. More... | |
| subroutine | field_set_key_struct_gas_mix_species_prop (f_id, k_value) |
| Assign a gas_mix_species_prop for a cs_gas_mix_species_prop_t key to a field. More... | |
| subroutine | field_get_key_struct_var_cal_opt (f_id, k_value) |
| Return a pointer to the var_cal_opt structure for cs_var_cal_opt key associated with a field. More... | |
| subroutine | field_get_key_struct_solving_info (f_id, k_value) |
| Return a pointer to the solving_info structure for cs_solving_info_t key associated with a field. More... | |
| subroutine | field_get_key_struct_gwf_soilwater_partition (f_id, k_value) |
| Return a pointer to the gwf_soilwater_partition structure for cs_gwf_soilwater_partition_t key associated with a field. More... | |
| subroutine | field_get_key_struct_gas_mix_species_prop (f_id, k_value) |
| Return a pointer to the gas_mix_species_prop structure for cs_gas_mix_species_prop_t key associated with a field. More... | |
| subroutine | gradient_s (f_id, imrgra, inc, recompute_cocg, nswrgp, imligp, iwarnp, epsrgp, climgp, pvar, coefap, coefbp, grad) |
| Compute cell gradient. More... | |
| subroutine | gradient_weighted_s (f_id, imrgra, inc, recompute_cocg, nswrgp, imligp, hyd_p_flag, iwarnp, epsrgp, climgp, f_ext, pvar, c_weight, coefap, coefbp, grad) |
| Compute cell gradient of a scalar with weighting. More... | |
| subroutine | locator_destroy (this_locator) |
| Destruction of a locator structure. More... | |
| subroutine | log_iteration_add_array (name, category, location, is_intensive, dim, val) |
| Add array not saved as permanent field to logging of fields. More... | |
| subroutine | log_iteration_clipping (name, dim, n_clip_min, n_clip_max, min_pre_clip, max_pre_clip) |
| subroutine | log_iteration_clipping_field (f_id, n_clip_min, n_clip_max, min_pre_clip, max_pre_clip, n_clip_min_comp, n_clip_max_comp) |
| subroutine | restart_create (name, path, mode, r) |
| Initialize a restart file. More... | |
| subroutine | restart_read_variables (r, old_field_map, t_id_flag) |
| Read variables from checkpoint. More... | |
| subroutine | restart_write_variables (r, t_id_flag) |
| Write variables to checkpoint. More... | |
| subroutine | restart_read_section_int_t (r, sec_name, location_id, n_loc_vals, val, ierror) |
| Read a section of integers from a restart file. More... | |
| subroutine | restart_read_int_t_compat (r, sec_name, old_name, location_id, n_loc_vals, val, ierror) |
| Read a section of integers from a restart file, when that section may have used a different name in a previous version. More... | |
| subroutine | restart_write_section_int_t (r, sec_name, location_id, n_loc_vals, val) |
| Write a section of integers to a checkpoint file. More... | |
| subroutine | restart_read_section_real_t (r, sec_name, location_id, n_loc_vals, val, ierror) |
| Read a section of doubles from a restart file. More... | |
| subroutine | restart_read_real_t_compat (r, sec_name, old_name, location_id, n_loc_vals, val, ierror) |
| Read a section of double precision reals from a restart file, when that section may have used a different name in a previous version. More... | |
| subroutine | restart_read_real_3_t_compat (r, sec_name, old_name_x, old_name_y, old_name_z, location_id, val, ierror) |
| Read a vector of double precision reals of dimension (3,*) from a restart file, when that section may have used a different name and been non-interleaved in a previous version. More... | |
| subroutine | restart_write_section_real_t (r, sec_name, location_id, n_loc_vals, val) |
| write a section of doubles to a checkpoint file. More... | |
| subroutine | restart_read_field_vals (r, f_id, t_id, ierror) |
| Read field values from checkpoint. More... | |
| subroutine | restart_write_field_vals (r, f_id, t_id) |
| Write field values to checkpoint. More... | |
| subroutine | restart_read_linked_fields (r, old_field_map, key, n_w) |
| Read fields depending on others from checkpoint. More... | |
| subroutine | restart_write_linked_fields (r, key, n_w) |
| Write fields depending on others to checkpoint. More... | |
| subroutine | sles_solve_native (f_id, name, isym, ibsize, iesize, dam, xam, epsilp, rnorm, niter, residue, rhs, vx) |
| Call sparse linear equation solver using native matrix arrays. More... | |
| subroutine | sles_free_native (f_id, name) |
| Free sparse linear equation solver setup using native matrix arrays. More... | |
| subroutine | sles_push (f_id, name) |
| Temporarily replace field id with name for matching calls to sles_solve_native. More... | |
| subroutine | sles_pop (f_id) |
| Revert to normal behavior of field id for matching calls to sles_solve_native. More... | |
| integer function | timer_stats_create (parent_name, name, label) |
| Create a timer statistics structure. More... | |
| integer function | timer_stats_id_by_name (name) |
| Return the id of a defined statistic based on its name. More... | |
| subroutine | variable_field_create (name, label, location_id, dim, id) |
| Add field defining a general solved variable, with default options. More... | |
| subroutine | variable_cdo_field_create (name, label, location_id, dim, has_previous, id) |
| Add a CDO field defining a general solved variable, with default options. More... | |
| integer function | volume_zone_n_type_zones (type_flag) |
| Return the number of volume zones associated with a given type flag. More... | |
| integer function | volume_zone_n_type_cells (type_flag) |
| Return the number of volume zone cells associated with a given type flag. More... | |
| subroutine | volume_zone_select_type_cells (type_flag, cell_list) |
| Return the list of volume zone cells associated with a given type flag. More... | |
| subroutine | field_get_coupled_faces (f_id, cpl_faces) |
| Return pointer to coupling face indicator for a field. More... | |
| double precision function | notebook_parameter_value_by_name (name) |
| Return notebook parameter value. More... | |
| integer function | cell_is_active (iel) |
| Indicate of a cell is active fo the current variable. More... | |
| subroutine | atmo_set_meteo_file_name (name) |
| Sets the meteo file name. More... | |
| subroutine | atmo_set_chem_conc_file_name (name) |
| Sets the chemistry concentration file name. More... | |
| subroutine | atmo_set_aero_conc_file_name (name) |
| Sets the aerosol concentration file name. More... | |
| subroutine | atmo_chemistry_set_spack_file_name (name) |
| Sets the file name used to initialize SPACK. More... | |
| subroutine | atmo_chemistry_set_aerosol_file_name (name) |
| Sets the file name used to initialize the aerosol shared library. More... | |
| integer | mesh_location_none |
| integer | mesh_location_cells |
| integer | mesh_location_interior_faces |
| integer | mesh_location_boundary_faces |
| integer | mesh_location_vertices |
| integer | mesh_location_particles |
| integer | mesh_location_other |
| integer | restart_val_type_int_t |
| integer | restart_val_type_real_t |
| integer | restart_disabled |
| integer | restart_main |
| integer | restart_auxiliary |
| integer | restart_rad_transfer |
| integer | restart_lagr |
| integer | restart_lagr_stat |
| integer | restart_1d_wall_thermal |
| integer | restart_les_inflow |
| integer | volume_zone_initialization |
| integer | volume_zone_porosity |
| integer | volume_zone_head_loss |
| integer | volume_zone_source_term |
| integer | volume_zone_mass_source_term |
| subroutine cs_c_bindings::atmo_chemistry_set_aerosol_file_name | ( | character(len=*), intent(in) | name | ) |
| [in] | name | name of the file |
| subroutine cs_c_bindings::atmo_chemistry_set_spack_file_name | ( | character(len=*), intent(in) | name | ) |
| subroutine cs_c_bindings::atmo_set_aero_conc_file_name | ( | character(len=*), intent(in) | name | ) |
| subroutine cs_c_bindings::atmo_set_chem_conc_file_name | ( | character(len=*), intent(in) | name | ) |
| subroutine cs_c_bindings::atmo_set_meteo_file_name | ( | character(len=*), intent(in) | name | ) |
| subroutine cs_c_bindings::balance_by_zone | ( | character(len=*), intent(in) | sel_crit, |
| character(len=*), intent(in) | name | ||
param[in] sel_crit selection criteria of a volume zone param[in] name scalar name
| subroutine cs_c_bindings::boundary_conditions_error | ( | integer(c_int), dimension(*), intent(in) | bc_type | ) |
For each boundary face, bc_type defines the boundary condition type. As a convention here, zero values correspond to undefined types, positive values to defined types (with no error), and negative values to defined types with inconsistent or incompatible values, the absolute value indicating the original boundary condition type. param[in] bc_type array og BC type ids
| type(c_ptr) function cs_c_bindings::boundary_conditions_map | ( | integer, intent(in) | location_type, |
| integer, intent(in) | n_location_elts, | ||
| integer, intent(in) | n_faces, | ||
| integer, dimension(*), intent(in) | location_elts, | ||
| integer, dimension(*), intent(in) | faces, | ||
| real(kind=c_double), dimension(*) | coord_shift, | ||
| integer, intent(in) | coord_stride, | ||
| double precision, intent(in) | tolerance | ||
param[in] location_type matching values location (CS_MESH_LOCATION_CELLS or CS_MESH_LOCATION_BOUNDARY_FACES) param[in] n_location_elts number of selected location elements param[in] n_faces number of selected boundary faces param[in] location_elts list of selected location elements (1 to n), or NULL if no indirection is needed param[in] faces list of selected boundary faces (1 to n), or NULL if no indirection is needed param[in] coord_shift array of coordinates shift relative to selected boundary faces param[in] coord_stride access stride in coord_shift: 0 for uniform shift, 1 for "per face" shift. param[in] tolerance relative tolerance for point location. return associated locator structure
| integer function cs_c_bindings::cell_is_active | ( | integer | iel | ) |
| [in] | iel | cell number (cell_id + 1) |
| subroutine cs_c_bindings::field_get_coupled_faces | ( | integer, intent(in) | f_id, |
| logical(kind=c_bool), dimension(:), intent(inout), pointer | cpl_faces | ||
| [in] | f_id | id of given field |
| [out] | cpl_faces | pointer to coupling face indicator |
| subroutine cs_c_bindings::field_get_key_struct_gas_mix_species_prop | ( | integer, intent(in) | f_id, |
| type(gas_mix_species_prop), intent(inout), target | k_value | ||
If the field category is not compatible, a fatal error is provoked.
| [in] | f_id | field id |
| [out] | k_value | integer value associated with key id for this field |
| subroutine cs_c_bindings::field_get_key_struct_gwf_soilwater_partition | ( | integer, intent(in) | f_id, |
| type(gwf_soilwater_partition), intent(inout), target | k_value | ||
| subroutine cs_c_bindings::field_get_key_struct_solving_info | ( | integer, intent(in) | f_id, |
| type(solving_info), intent(inout), target | k_value | ||
| subroutine cs_c_bindings::field_get_key_struct_var_cal_opt | ( | integer, intent(in) | f_id, |
| type(var_cal_opt), intent(out), target | k_value | ||
| subroutine cs_c_bindings::field_set_key_struct_gas_mix_species_prop | ( | integer, intent(in) | f_id, |
| type(gas_mix_species_prop), intent(in), target | k_value | ||
| [in] | k_value | structure associated with key |
| subroutine cs_c_bindings::field_set_key_struct_gwf_soilwater_partition | ( | integer, intent(in) | f_id, |
| type(gwf_soilwater_partition), intent(in), target | k_value | ||
| subroutine cs_c_bindings::field_set_key_struct_solving_info | ( | integer, intent(in) | f_id, |
| type(solving_info), intent(in), target | k_value | ||
| subroutine cs_c_bindings::field_set_key_struct_var_cal_opt | ( | integer, intent(in) | f_id, |
| type(var_cal_opt), intent(in), target | k_value | ||
| subroutine cs_c_bindings::gradient_s | ( | integer, intent(in) | f_id, |
| integer, intent(in) | imrgra, | ||
| integer, intent(in) | inc, | ||
| integer, intent(in) | recompute_cocg, | ||
| integer, intent(in) | nswrgp, | ||
| integer, intent(in) | imligp, | ||
| integer, intent(in) | iwarnp, | ||
| double precision, intent(in) | epsrgp, | ||
| double precision, intent(in) | climgp, | ||
| real(kind=c_double), dimension(ncelet), intent(inout) | pvar, | ||
| real(kind=c_double), dimension(nfabor), intent(in) | coefap, | ||
| real(kind=c_double), dimension(nfabor), intent(in) | coefbp, | ||
| real(kind=c_double), dimension(3, ncelet), intent(out) | grad | ||
| [in] | f_id | field id, or -1 |
| [in] | imrgra | gradient computation mode |
| [in] | inc | 0: increment; 1: do not increment |
| [in] | recompute_cocg | 1 or 0: recompute COCG or not |
| [in] | nswrgp | number of sweeps for reconstruction |
| [in] | imligp | gradient limitation method: < 0 no limitation = 0 based on neighboring gradients = 1 based on mean gradient |
| [in] | iwarnp | verbosity |
| [in] | epsrgp | relative precision for reconstruction |
| [in] | climgp | limiter coefficient for imligp |
| [in,out] | pvar | cell values whose gradient is computed |
| [in] | coefap | boundary coefap coefficients |
| [in] | coefbp | boundary coefap coefficients |
| [out] | grad | resulting gradient |
| subroutine cs_c_bindings::gradient_weighted_s | ( | integer, intent(in) | f_id, |
| integer, intent(in) | hyd_p_flag, | ||
| real(kind=c_double), dimension(:,:), intent(in), pointer | f_ext, | ||
| real(kind=c_double), dimension(:), intent(inout) | c_weight, | ||
| [in,out] | c_weight | cell weighting coefficient |
| subroutine cs_c_bindings::intprf | ( | integer(c_int), intent(in), value | nprofz, |
| integer(c_int), intent(in), value | nproft, | ||
| real(kind=c_double), dimension(nprofz), intent(in) | profz, | ||
| real(kind=c_double), dimension(nproft), intent(in) | proft, | ||
| real(kind=c_double), dimension(nprofz, nproft), intent(in) | profv, | ||
| real(kind=c_double), intent(in), value | xz, | ||
| real(kind=c_double), intent(in), value | temps, | ||
| real(kind=c_double), intent(out) | var | ||
An optimized linear interpolation is used.
| subroutine cs_c_bindings::intprz | ( | integer(c_int), intent(in), value | nprofz, |
| real(kind=c_double), dimension(nprofz), intent(in) | profv, | ||
| integer(c_int), intent(out) | iz1, | ||
| integer(c_int), intent(out) | iz2, | ||
| subroutine cs_c_bindings::locator_destroy | ( | type(c_ptr) | this_locator | ) |
| [in,out] | this_locator |
| subroutine cs_c_bindings::log_iteration_add_array | ( | character(len=*), intent(in) | name, |
| character(len=*), intent(in) | category, | ||
| integer, intent(in) | location, | ||
| logical, intent(in) | is_intensive, | ||
| integer, intent(in) | dim, | ||
| real(kind=c_double), dimension(*) | val | ||
| [in] | name | array name |
| [in] | category | category name |
| [in] | location | associated mesh location |
| [in] | is_intensive | associated mesh location |
| [in] | dim | associated dimension (interleaved) |
| [in] | val | associated values |
| subroutine cs_c_bindings::log_iteration_clipping | ( | character(len=*), intent(in) | name, |
| integer, intent(in) | n_clip_min, | ||
| integer, intent(in) | n_clip_max, | ||
| real(kind=c_double), dimension(*) | min_pre_clip, | ||
| real(kind=c_double), dimension(*) | max_pre_clip | ||
| [in] | n_clip_min | local number of clipped to min values |
| [in] | n_clip_max | local number of clipped to max values |
| [in] | min_pre_clip | min local value prior to clip |
| [in] | max_pre_clip | max local value prior to clip |
| subroutine cs_c_bindings::log_iteration_clipping_field | ( | integer, intent(in) | f_id, |
| real(kind=c_double), dimension(*) | max_pre_clip, | ||
| integer(c_int), dimension(*), intent(in) | n_clip_min_comp, | ||
| integer(c_int), dimension(*), intent(in) | n_clip_max_comp | ||
| [in] | f_id | associated dimension (interleaved) |
| [in] | n_clip_min_comp | number of clip min by component |
| [in] | n_clip_max_comp | number of clip max by component |
| double precision function cs_c_bindings::notebook_parameter_value_by_name | ( | character(len=*), intent(in) | name | ) |
| [in] | name | name of the notebook parameter |
| subroutine cs_c_bindings::pressure_drop_by_zone | ( | character(len=*), intent(in) | sel_crit | ) |
| subroutine cs_c_bindings::promav | ( | integer, value | isym, |
| integer, value | ibsize, | ||
| integer, value | iesize, | ||
| integer, value | f_id, | ||
| real(kind=c_double), dimension(*), intent(in) | dam, | ||
| real(kind=c_double), dimension(*), intent(in) | xam, | ||
| real(kind=c_double), dimension(*), intent(in) | vx, | ||
| real(kind=c_double), dimension(*), intent(out) | vy | ||
| subroutine cs_c_bindings::restart_create | ( | character(len=*), intent(in) | name, |
| character(len=*), intent(in) | path, | ||
| integer, intent(in) | mode, | ||
| type(c_ptr), intent(out) | r | ||
| [in] | name | file name |
| [in] | path | optional directory name for output (automatically created if necessary) |
| [in] | mode | read (0) or write (1) |
| [out] | r | pointer to restart structure |
| subroutine cs_c_bindings::restart_read_field_vals | ( | type(c_ptr), intent(in) | r, |
| integer, intent(in) | f_id, | ||
| integer, intent(in) | t_id, | ||
| integer, intent(out) | ierror | ||
If the values are not found using the default rules based on the field's name, its name itself, or a "restart_rename" keyed string value, an old name may be used for compatibility with older files. For cell-based fields, the old name base is appended automatically with "_ce_phase01", except for scalars, where the name uses a different scheme, based on "scalaire_ce_%04" % s_num;
| [in] | r | pointer to restart structure |
| [in] | t_id | time id (0 for current, 1 for previous, ...) |
| [out] | ierror | return code |
| subroutine cs_c_bindings::restart_read_int_t_compat | ( | type(c_ptr), intent(in) | r, |
| character(len=*), intent(in) | sec_name, | ||
| character(len=*), intent(in) | old_name, | ||
| integer, intent(in) | location_id, | ||
| integer, intent(in) | n_loc_vals, | ||
| integer, dimension(*), target | val, | ||
| [in] | sec_name | name of section |
| [in] | old_name | old name of section |
| [in] | n_loc_vals | number of values per location |
| [out] | val | values array |
| [out] | ierror | 0: success, < 0: error code |
| subroutine cs_c_bindings::restart_read_linked_fields | ( | type(c_ptr), intent(in) | r, |
| type(c_ptr), intent(in) | old_field_map, | ||
| character(len=*), intent(in) | key, | ||
| integer, intent(out) | n_w | ||
| [in] | old_field_map | pointer to old field map |
| [in] | key | key for field association |
| [out] | n_w | number of fields read |
| subroutine cs_c_bindings::restart_read_real_3_t_compat | ( | type(c_ptr), intent(in) | r, |
| character(len=*), intent(in) | old_name_x, | ||
| character(len=*), intent(in) | old_name_y, | ||
| character(len=*), intent(in) | old_name_z, | ||
| real(kind=c_double), dimension(*) | val, | ||
| [in] | old_name_x | old name of component x of section |
| [in] | old_name_y | old name of component y of section |
| [in] | old_name_z | old name of component z of section |
| subroutine cs_c_bindings::restart_read_real_t_compat | ( | type(c_ptr), intent(in) | r, |
| real(kind=c_double), dimension(*), target | val, | ||
| subroutine cs_c_bindings::restart_read_section_int_t | ( | type(c_ptr), intent(in) | r, |
| subroutine cs_c_bindings::restart_read_section_real_t | ( | type(c_ptr), intent(in) | r, |
| subroutine cs_c_bindings::restart_read_variables | ( | type(c_ptr), intent(in) | r, |
| integer, intent(in) | t_id_flag | ||
| [in] | old_field_map | old field map pointer |
| [in] | t_id_flag | -1: all time values; 0: current values; > 0: previous values |
| subroutine cs_c_bindings::restart_write_field_vals | ( | type(c_ptr), intent(in) | r, |
| integer, intent(in) | t_id | ||
| subroutine cs_c_bindings::restart_write_linked_fields | ( | type(c_ptr), intent(in) | r, |
| [out] | n_w | number of fields written |
| subroutine cs_c_bindings::restart_write_section_int_t | ( | type(c_ptr), intent(in) | r, |
| integer, dimension(*), intent(in), target | val | ||
| [in] | val | values array |
| subroutine cs_c_bindings::restart_write_section_real_t | ( | type(c_ptr), intent(in) | r, |
| real(kind=c_double), dimension(*), intent(in), target | val | ||
| subroutine cs_c_bindings::restart_write_variables | ( | type(c_ptr), intent(in) | r, |
| subroutine cs_c_bindings::sles_free_native | ( | integer, intent(in) | f_id, |
param[in] f_id associated field id, or < 0 param[in] name associated name if f_id < 0, or ignored
| subroutine cs_c_bindings::sles_pop | ( | integer, intent(in) | f_id | ) |
| subroutine cs_c_bindings::sles_push | ( | integer, intent(in) | f_id, |
| subroutine cs_c_bindings::sles_solve_native | ( | integer, intent(in) | f_id, |
| character(len=*), intent(in) | name, | ||
| integer, intent(in) | isym, | ||
| integer, intent(in) | ibsize, | ||
| integer, intent(in) | iesize, | ||
| double precision, intent(in) | epsilp, | ||
| double precision, intent(in) | rnorm, | ||
| integer, intent(out) | niter, | ||
| double precision, intent(out) | residue, | ||
| real(kind=c_double), dimension(*), intent(in) | rhs, | ||
| real(kind=c_double), dimension(*), intent(inout) | vx | ||
param[in] f_id associated field id, or < 0 param[in] name associated name if f_id < 0, or ignored param[in] isym symmetry indicator: 1 symmetric, 2: not symmetric param[in] ibsize block sizes for diagonal param[in] iesize block sizes for extra diagonal param[in] dam matrix diagonal param[in] xam matrix extra-diagonal terms param[in] epsilp precision for iterative resolution param[in] rnorm residue normalization param[out] niter number of "equivalent" iterations param[out] residue residue param[in] rhs right hand side param[in, out] vx system solution
| subroutine cs_c_bindings::surface_balance | ( | character(len=*), intent(in) | sel_crit, |
| real(kind=c_double), dimension(3), intent(in) | normal | ||
| integer function cs_c_bindings::timer_stats_create | ( | character(len=*), intent(in) | parent_name, |
| character(len=*), intent(in) | label | ||
If no timer with the given name exists, -1 is returned.
| [in] | parent_name | name of parent statistic (may be empty) |
| [in] | name | associated canonical name |
| [in] | label | associated label (may be empty) |
| integer function cs_c_bindings::timer_stats_id_by_name | ( | character(len=*), intent(in) | name | ) |
| [in] | name | statistic name |
| subroutine cs_c_bindings::variable_cdo_field_create | ( | character(len=*), intent(in) | name, |
| character(len=*), intent(in) | label, | ||
| integer, intent(in) | has_previous, | ||
| integer, intent(out) | id | ||
| [in] | name | field name |
| [in] | label | field default label, or empty |
| [in] | location_id | field location type: 0: none 1: cells 2: interior faces 3: interior faces 4: vertices |
| [in] | dim | field dimension |
| [in] | has_previous | if greater than 1 then store previous state |
| [out] | id | id of defined field |
| subroutine cs_c_bindings::variable_field_create | ( | character(len=*), intent(in) | name, |
| integer function cs_c_bindings::volume_zone_n_type_cells | ( | integer | type_flag | ) |
| [in] | type_flag | type flag queried |
| integer function cs_c_bindings::volume_zone_n_type_zones | ( | integer | type_flag | ) |
| subroutine cs_c_bindings::volume_zone_select_type_cells | ( | integer | type_flag, |
| integer, dimension(*), intent(out), target | cell_list | ||
| [out] | cell_list | list of cells |
| integer mesh_location_boundary_faces |
| integer mesh_location_cells |
| integer mesh_location_interior_faces |
| integer mesh_location_none |
| integer mesh_location_other |
| integer mesh_location_particles |
| integer mesh_location_vertices |
| integer restart_1d_wall_thermal |
| integer restart_auxiliary |
| integer restart_disabled |
| integer restart_lagr |
| integer restart_lagr_stat |
| integer restart_les_inflow |
| integer restart_main |
| integer restart_rad_transfer |
| integer restart_val_type_int_t |
| integer restart_val_type_real_t |
| integer volume_zone_head_loss |
| integer volume_zone_initialization |
| integer volume_zone_mass_source_term |
| integer volume_zone_porosity |
| integer volume_zone_source_term |
