Collaboration diagram for Time stepping:Variables | |
| integer(c_int), pointer, save | ischtp |
| time order of time stepping More... | |
| integer, save | istmpf |
| time order of the mass flux scheme The chosen value for istmpf will automatically determine the value given to the variable thetfl. More... | |
| integer(c_int), pointer, save | itpcol |
| Time scheme option: More... | |
| integer(c_int), pointer, save | nterup |
| number of iterations on the velocity-pressure coupling on Navier-Stokes (for the U/P inner iterations scheme) More... | |
| integer, save | isno2t |
| isno2t specifies the time scheme activated for the source terms of the momentum equation, apart from convection and diffusion (for instance: head loss, transposed gradient, ...). More... | |
| integer(c_int), pointer, save | isto2t |
| Time scheme for source terms of turbulence equations (see isto2t in cs_time_scheme_t). More... | |
| integer, dimension(nscamx), save | isso2t |
| for each scalar, isso2t specifies the time scheme activated for the source terms of the equation for the scalar, apart from convection and diffusion (for instance: variance production, user-specified terms, ...). More... | |
| integer, save | initvi |
| initvi : =1 if total viscosity read from checkpoint file More... | |
| integer, save | initro |
| initro : =1 if density read from checkpoint file More... | |
| integer, save | initcp |
| initcp : =1 if specific heat read from checkpoint file More... | |
| integer, dimension(nscamx), save | initvs |
| initvs : =1 if scalar diffusivity read from checkpoint file More... | |
| double precision, save | thetsn |
-scheme for the source terms in the Navier-Stokes equations when the source term extrapolation has been activated (see isno2t), following the formula .The value of = thetsn is deduced from the value chosen for isno2t. Generally only the value 0.5 is used. More... | |
| real(c_double), pointer, save | thetst |
The value of (see thetst in cs_time_scheme_t). More... | |
| double precision, dimension(nscamx), save | thetss |
-scheme for the extrapolation of the nonlinear explicit source term of the scalar transport equation when the source term extrapolation has been activated (see isso2t), following the formula .The value of = thetss is deduced from the value chosen for isso2t. Generally, only the value 0.5 is used. More... | |
| double precision, save | thetvi |
-scheme for the extrapolation of the physical property "total viscosity" when the extrapolation has been activated (see time_extrapolated key word), according to the formula .The value of = thetvi is deduced from the value chosen for time_extrapolated key word for the viscosity. Generally, only the value 0.5 is used. More... | |
| double precision, save | thetcp |
-scheme for the extrapolation of the physical property "specific heat" when the extrapolation has been activated (see time_extrapolated field key int), according to the formula .The value of = thetcp is deduced from the value chosen for the specific heat. Generally, only the value 0.5 is used. More... | |
| double precision, dimension(nscamx), save | thetvs |
-scheme for the extrapolation of the physical property "diffusivity" when the extrapolation has been activated (see time_extrapolated key word), according to the formula .The value of = thetvs is deduced from the value chosen for time_extrapolated key word. Generally, only the value 0.5 is used. More... | |
| real(c_double), pointer, save | epsup |
| relative precision for the convergence test of the iterative process on velocity-pressure coupling (inner iterations) More... | |
| real(c_double), pointer, save | xnrmu |
norm of the increment of the iterative process on velocity-pressure coupling (inner iterations) More... | |
| real(c_double), pointer, save | xnrmu0 |
norm of (used by velocity-pressure inner iterations) More... | |
| real(c_double), pointer, save epsup |
| integer, save initcp |
| integer, save initro |
| integer, save initvi |
| integer, dimension(nscamx), save initvs |
| integer(c_int), pointer, save ischtp |
| integer, save isno2t |
which are linear functions of the solved variable
are expressed as second-order terms by interpolation (according to the formula
being given by the value of thetav associated with the variable
); the other terms
are expressed as second-order terms by extrapolation (according to the formula
being given by the value of thetsn = 0.5).
are treated in the same way as when isno2t = 1; the other terms
are extrapolated according to the same formula as when isno2t = 1, but with
= thetsn = 1. By default, isno2t is initialised to 1 (second-order) when the selected time scheme is second-order (ischtp = 2), otherwise to 0. | integer, dimension(nscamx), save isso2t |
); the other terms
being given by the value of thetss (iscal) = 0.5)
are treated in the same way as when isso2t = 1; the other terms
are extrapolated according to the same formula as when isso2t = 1, but with
= thetss (iscal) = 1.| integer, save istmpf |
time step.| integer(c_int), pointer, save isto2t |
| integer(c_int), pointer, save itpcol |
Time scheme option:
| integer(c_int), pointer, save nterup |
| double precision, save thetcp |
The value of
| double precision, save thetsn |
The value of
| double precision, dimension(nscamx), save thetss |
The value of
| real(c_double), pointer, save thetst |
The value of
| double precision, save thetvi |
The value of
| double precision, dimension(nscamx), save thetvs |
The value of
| real(c_double), pointer, save xnrmu |
| real(c_double), pointer, save xnrmu0 |
norm of
