Collaboration diagram for Transported scalars parameters:Macros | |
| #define | CS_ISOTROPIC_DIFFUSION (1 << 0) |
| #define | CS_ORTHOTROPIC_DIFFUSION (1 << 1) |
| #define | CS_ANISOTROPIC_LEFT_DIFFUSION (1 << 2) |
| #define | CS_ANISOTROPIC_RIGHT_DIFFUSION (1 << 3) |
| #define | CS_ANISOTROPIC_DIFFUSION ((1 << 2) + (1 << 3)) |
| integer, dimension(nscamx), save | iclvfl |
| iclvfl : 0 : clip variances to zero 1 : clip variances to zero and to f(1-f) 2 : clip variances to max(zero,scamin) and scamax for every scalar iscal representing the average of the square of the fluctuations of another scalar ii= iscavr (iscal) (noted $f$), indicator of the clipping method: More... | |
| integer, dimension(nscamx), save | iscasp |
| iscasp(ii) : index of the ii^th species (0 if not a species) More... | |
| double precision, dimension(nscamx), save | rvarfl |
When iscavr(iscal)>0, rvarfl is the coefficient in the dissipation term of the equation concerning the scalar, which represents the root mean square of the fluctuations of the scalar.Useful if and only if there is 1 iscal nscal such as iscavr(iscal)>0. More... | |
| double precision, dimension(nscamx), save | ctheta |
| ctheta : coefficient des modeles de flux turbulents GGDH et AFM More... | |
| integer | drift_scalar_add_drift_flux |
| flag for computing the drift mass flux: (for coal classes for instance, only the first scalar of a class compute the drift flux of the class and the other scalars use it without recomputing it) More... | |
| integer | drift_scalar_thermophoresis |
| flag for activating thermophoresis for drift scalars More... | |
| integer | drift_scalar_turbophoresis |
| flag for activating turbophoresis for drift scalars More... | |
| integer | drift_scalar_electrophoresis |
| integer | drift_scalar_centrifugalforce |
| flag for activating the centrifugal force for drift scalars More... | |
| integer | drift_scalar_imposed_mass_flux |
| flag for activating imposed mass flux More... | |
| integer | drift_scalar_zero_bndy_flux |
| flag for seting the mass flux to zero at all boundaries More... | |
| integer | drift_scalar_zero_bndy_flux_at_walls |
| flag for seting the mass flux to zero at walls only More... | |
| integer | isotropic_diffusion |
| flag for isotropic diffusion More... | |
| integer | orthotropic_diffusion |
| flag for orthotropic diffusion More... | |
| integer | anisotropic_left_diffusion |
| flag for diffusion by a left-multiplied symmetric 3x3 tensor More... | |
| integer | anisotropic_right_diffusion |
| integer | anisotropic_diffusion |
| flag for diffusion by a symmetric 3x3 tensor More... | |
| #define CS_ANISOTROPIC_DIFFUSION ((1 << 2) + (1 << 3)) |
| #define CS_ANISOTROPIC_LEFT_DIFFUSION (1 << 2) |
| #define CS_ANISOTROPIC_RIGHT_DIFFUSION (1 << 3) |
diffusion by a right-multiplied symmetric 3x3 tensor
| #define CS_ISOTROPIC_DIFFUSION (1 << 0) |
isotropic diffusion
| #define CS_ORTHOTROPIC_DIFFUSION (1 << 1) |
| integer anisotropic_diffusion |
| integer anisotropic_left_diffusion |
| integer anisotropic_right_diffusion |
| double precision, dimension(nscamx), save ctheta |
| integer drift_scalar_add_drift_flux |
| integer drift_scalar_centrifugalforce |
| integer drift_scalar_electrophoresis |
| integer drift_scalar_imposed_mass_flux |
| integer drift_scalar_thermophoresis |
| integer drift_scalar_turbophoresis |
| integer drift_scalar_zero_bndy_flux |
| integer drift_scalar_zero_bndy_flux_at_walls |
| integer, dimension(nscamx), save iclvfl |
for higher values, where
is the associated scalar,
and
its minimum and maximum values specified by the user (i.e. scamin (ii) and scamax (ii))| integer, dimension(nscamx), save iscasp |
| integer isotropic_diffusion |
| integer orthotropic_diffusion |
| double precision, dimension(nscamx), save rvarfl |
