integer, save | ifm |
| pointer to specify the mixing rate in isca(ifm) More...
integer, save | ifp2m |
| pointer to specify the variance of the mixing rate in isca(ifp2m) More...
integer, save | ifsqm |
| pointer to specify the second moment of the mixing rate in isca(ifsqm): More...
integer, save | ipvm |
| pointer to specify the transported progress variable ippmod(islfm) >= 2: More...
integer, save | iygfm |
| pointer to specify the fresh gas mass fraction in isca(iygfm) More...
integer, save | icm |
| the intersection computation mode. If its value is: More...
integer, save | icp2m |
| transported variable More...
integer, save | ifpcpm |
integer, save | iyfm |
integer, save | iyfp2m |
integer, save | icoyfp |
integer, dimension(ngazgm), save | iym |
| mass fractions : More...
integer, dimension(ngazgm), save | ibym |
integer, save | itemp |
| state variable (temperature) More...
integer, save | ifmin |
| state variable More...
integer, save | ifmax |
integer, save | irecvr |
| state variable: Pointer to the reconstructed variance in case of mode_fp2m = 1 More...
integer, save | itotki |
| state variable: Pointer to the total scalar dissipation rate More...
integer, save | ihrr |
| state variable: Pointer to volumetric heat release rate More...
integer, save | ixr |
| state variable: Pointer to enthalpy defect More...
integer, save | iomgc |
integer, save | ickabs |
| state variable: absorption coefficient, when the radiation modelling is activated More...
integer, save | it2m |
| state variable: term More...
integer, save | it3m |
| state variable: term, when the radiation modelling is activated More...
integer, save | it4m |
integer, save | itsc |
integer, save | inpm |
| pointer for soot precursor number in isca (isoot = 1) More...
integer, save | ifsm |
| pointer for soot mass fraction in isca (isoot = 1) More...
