code / code - management of key parameters More...
integer, save | nbrcpl |
number of couplings code_saturne / code_saturne More... | |
integer, save | ifaccp |
indicator coupling face / face only More... | |
integer | nbcpmx |
maximum permissible number of coupling More... | |
integer, dimension(nbcpmx), save | iturcp |
turbulence model of the remote instance More... | |
integer, dimension(nbcpmx), save | imajcp |
indicator to update location of the coupling More... | |
integer, dimension(nbcpmx), save | icormx |
indicator of calulation in relative reference frame More... | |
integer, dimension(nbcpmx), save | nvarcp |
number of variables to send/receive More... | |
integer, dimension(nbcpmx), save | nvarto |
size of exchange tables More... | |
double precision, save | ttpmob |
Absolute time value after the mesh starts to rotate (if it does), for previous calculation. More... | |
double precision, save | ttcmob |
Current absolute time after the mesh starts to rotate (if it does). In case of restart, this is equal to ttpmob + additional computed time. More... | |
integer, dimension(nbcpmx), save icormx |
integer, save ifaccp |
integer, dimension(nbcpmx), save imajcp |
integer, dimension(nbcpmx), save iturcp |
integer nbcpmx |
integer, save nbrcpl |
integer, dimension(nbcpmx), save nvarcp |
integer, dimension(nbcpmx), save nvarto |
double precision, save ttcmob |
double precision, save ttpmob |
