7.2
Data setting for drift scalars
Introduction
This page provides an example of code blocks that may be used to perform a calculation with drift scalars.
Physical properties
Local variables to be added
The following local variables and associated initializations need to be defined for the examples in this section:
cs_real_t *cpro_viscl = CS_F_(mu)->val;
/* Key id for drift scalar */
const int keydri = cs_field_key_id("drift_scalar_model");
/* Key id for diffusivity id */
const int kivisl = cs_field_key_id("diffusivity_id");
/* Number of fields */
const int nfld = cs_field_n_fields();
Body
This example sets the scalar laminar diffusivity (for Brownian motion) to take thermophoresis into account.
/* Loop over fields which are scalar with a drift */
for (int iflid = 0; iflid < nfld; iflid++) {
if (! (f->type & CS_FIELD_VARIABLE))
continue;
int drift_flag = cs_field_get_key_int(f, keydri);
if (drift_flag & CS_DRIFT_SCALAR_ADD_DRIFT_FLUX) {
/* Position of variables, coefficients
cs_real_t *cpro_taup = NULL, *cpro_taufpt = NULL, *cpro_viscls = NULL;
/* Scalar's diffusivity (Brownian motion) */
int ifcvsl = cs_field_get_key_int(f, kivisl);
if (ifcvsl > -1)
cpro_viscls = cs_field_by_id(ifcvsl)->val;
/* Coefficients of drift scalar CHOSEN BY THE USER
Values given here are fictitious */
const cs_real_t diamp = 1.e-4; /* particle diameter */
const cs_real_t cuning = 1.; /* Cuningham correction factor */
const cs_real_t rhop = 1.e4; /* particle density */
/* Get corresponding relaxation time (cpro_taup) */
char df_name[128]; df_name[127] = '\0';
snprintf(df_name, 127, "drift_tau_%s", f->name);
cpro_taup = cs_field_by_name(df_name)->val;
/* Corresponding interaction time particle--eddies */
if (drift_flag & CS_DRIFT_SCALAR_TURBOPHORESIS) {
snprintf(df_name, 127, "drift_turb_tau_%s", f->name);
cpro_taufpt = cs_field_by_name(df_name)->val;
/* Computation of the relaxation time of the particles
const cs_real_t diamp2 = cs_math_pow2(diamp);
if (diamp <= 1.e-6) {
/* Cuningham's correction for submicronic particules */
for (cs_lnum_t c_id = 0; c_id < n_cells; c_id++) {
cpro_taup[c_id] = cuning*diamp2*rhop / (18.*cpro_viscl[c_id]);
else {
cpro_taup[c_id] = diamp2*rhop / (18.*cpro_viscl[c_id]);
/* Compute the interaction time particle--eddies (tau_fpt)
const int ksigmas = cs_field_key_id("turbulent_schmidt");
/* k-epsilon or v2-f models */
if (t_mdl->itytur == 2 || t_mdl->itytur == 5) {
const cs_real_t *cvar_k = CS_F_(k)->val;
const cs_real_t *cvar_eps = CS_F_(eps)->val;
const cs_real_t turb_schmidt = cs_field_get_key_double(f, ksigmas);
cs_real_t xk = cvar_k[c_id];
cs_real_t xeps = cvar_eps[c_id];
cpro_taufpt[c_id] = (3./2.)*(cs_turb_cmu/turb_schmidt)*xk/xeps;
/* Rij-epsilon models */
else if (t_mdl->itytur == 3) {
const cs_real_6_t *cvar_rij = (const cs_real_6_t *)(CS_F_(rij)->val);
cs_real_t beta1 = 0.5 + 3.0/(4.*cs_turb_xkappa);
cs_real_t xk = 0.5 * ( cvar_rij[c_id][0]
+ cvar_rij[c_id][1]
+ cvar_rij[c_id][2]);
cpro_taufpt[c_id] = xk/xeps/beta1;
/* k-omega models */
if (t_mdl->itytur == 6) {
const cs_real_t *cvar_omg = CS_F_(omg)->val;
cs_real_t xomg = cvar_omg[c_id];
cpro_taufpt[c_id] = (3./2.)*(1./turb_schmidt)/xomg;
/* Brownian diffusion at cell centers
/* Stop if the diffusivity is not variable */
if (ifcvsl < 0)
bft_error(__FILE__, __LINE__, 0,
"The diffusivity is uniform while a variable diffusivity\n"
"is computed.");
/* Temperature and density */
if (CS_F_(t) == NULL)
"The temperature field on which physical properties depend\n"
"does not seem to be present.");
const cs_real_t *cvar_t = CS_F_(t)->val;
const cs_real_t *cpro_rom = CS_F_(rho)->val;
/* Homogeneous to a dynamic viscosity */
cs_real_t xvart = cvar_t[c_id];
cs_real_t rho = cpro_rom[c_id];
cs_real_t viscl = cpro_viscl[c_id];
cpro_viscls[c_id] = rho*cs_physical_constants_kb*xvart
* cuning/(3.*cs_math_pi*diamp*viscl);
} /* End of test on drift */
} /* End of loop on fields */
