User subroutines dedicated to the atmospheric model.
More...
| subroutine | usatdv (imode) |
| | Atmospheric module subroutine. More...
| subroutine | usatsoil (iappel) |
| | Data entry for the atmospheric ground model. Define the different values which can be taken by iappel. More...
| subroutine | cs_user_atmo_1d_rad_prf (preray, temray, romray, qvray, qlray, ncray, aeroso) |
| | Fill in vertical profiles of atmospheric properties prior to solve 1D radiative transfers. Altitudes (zvert array) are defined in usatd. More...
| subroutine | cs_user_atmo_soil (temp, qv, rom, dt, rcodcl) |
| | Compute ground level variables. More...
See Atmospheric model (cs_user_atmospheric_model.f90) for examples.
◆ cs_user_atmo_1d_rad_prf()
| subroutine cs_user_atmo_1d_rad_prf |
double precision, dimension(kmx) |
preray, |
temray, |
romray, |
qvray, |
qlray, |
ncray, |
aeroso |
- Parameters
| [in,out] | preray | pressure vertical profile |
| [in,out] | temray | real temperature vertical profile |
| [in,out] | romray | density vertical profile |
| [in,out] | qvray | water vapor content vertical profile |
| [in,out] | qlray | water liquid content vertical profile |
| [in,out] | ncray | droplets density vertical profile |
| [in,out] | aeroso | aerosol concentration vertical profile |
◆ cs_user_atmo_soil()
| subroutine cs_user_atmo_soil |
double precision, dimension(ncelet) |
temp, |
qv, |
rom, |
dt, |
double precision, dimension(nfabor,nvar,3) |
rcodcl |
- Parameters
◆ usatdv()
| subroutine usatdv |
integer |
imode | ) |
User definition of the vertical 1D arrays User initialization of corresponding 1D ground model
- Parameters
| [in] | imode | number of calls of usatdv |
◆ usatsoil()
| subroutine usatsoil |
integer |
iappel | ) |
- Parameters
| [in] | iappel | Computation of the cells number where we impose a ground Model if iappel=1. users may defined the ground face composition if iappel=2. Warning : be coherent with the dimension of the array pourcent_sol Warning: tt's also possible to modify the tab_sol array of the ground type constants |
