7.2
cs_turbulence_kw.h File Reference
+ Include dependency graph for cs_turbulence_kw.h:
void cs_turbulence_kw (cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t dt[], cs_real_t smacel[])
 Solve the k-omega equations. More...
void cs_turbulence_kw_mu_t (void)
 Calculation of turbulent viscosity for the $ k - \omega $ SST model. More...
◆ cs_turbulence_kw()
void cs_turbulence_kw ( cs_lnum_t  ncesmp,
cs_lnum_t  icetsm[],
int  itypsm[],
cs_real_t  smacel[]
Solve the $ k - \omega $ SST for incompressible flows or slightly compressible flows for one time step.
[in]ncesmpnumber of cells with mass source term
[in]icetsmindex of cells with mass source term
[in]itypsmmass source type for the variables size: [nvar][ncesmp]
[in]dttime step (per cell)
[in]smacelvalues of the variables associated to the mass source (for the pressure variable, smacel is the mass flux) size: [nvar][ncesmp]
◆ cs_turbulence_kw_mu_t()
void cs_turbulence_kw_mu_t ( void  )
\[ \mu_T = \rho A1 \dfrac{k}{\max(A1 \omega; \; S f_2)} \]
with
\[ S = \sqrt{ 2 S_{ij} S_{ij}} \]
\[ S_{ij} = \dfrac{\der{u_i}{x_j} + \der{u_j}{x_i}}{2}\]
and $ f_2 = \tanh(arg2^2) $
\[ arg2^2 = \max(2 \dfrac{\sqrt{k}}{C_\mu \omega y}; \; 500 \dfrac{\nu}{\omega y^2}) \]
where $ y $ is the distance to the wall.
$ \divs{\vect{u}} $ is calculated at the same time than $ S $ for use in cs_turbulence_kw. !
