7.2
cs_steady_laminar_flamelet_physical_prop.f90 File Reference
Specific physic subroutine: diffusion flame. More...
Functions/Subroutines
subroutine cs_steady_laminar_flamelet_physical_prop (mbrom, izfppp)
subroutine filtered_physical_prop (zm0, zvar0, kim0, xrm0, phim, rad_work, update_rad)
subroutine filtered_density (zm0, zvar0, kim0, xrm0, rhom)
subroutine filtered_physical_prop_progvar (zm0, zvar0, cm0, xrm0, phim, rad_work, update_rad)
subroutine filtered_density_progvar (zm0, zvar0, cm0, xrm0, rhom)
subroutine max_mid_min_progvar (zm0, cmax, cmid, cmin)
subroutine scalar_dissipation_rate ()
subroutine combustion_reconstruct_variance (iprev)
Calculation of mean thermophysic properties
Interpolation of mean thermophysic properties as a function of fm, fp2m, ki, xr
Interpolation of mean density as a function of fm, fp2m, ki, xr
Interpolation of mean thermophysic properties as a function of fm, fp2m, c, xr
Interpolation of mean density as a function of fm, fp2m, c, xr
Calculation of Min/Max of progress variable as a function of fm
Calculation of total scalar dissipation rate
Calculation of reconstructed variance of mixture fraction
◆ combustion_reconstruct_variance()
subroutine combustion_reconstruct_variance ( integer  iprev)
◆ cs_steady_laminar_flamelet_physical_prop()
subroutine cs_steady_laminar_flamelet_physical_prop ( integer  mbrom,
integer, dimension(nfabor)  izfppp
[in]mbromindicator of prescribed density at the boundary
[in]izfppparea number of the edge face for the specific physic module
◆ filtered_density()
subroutine filtered_density ( double precision  zm0,
double precision  zvar0,
double precision  kim0,
double precision  xrm0,
double precision  rhom
◆ filtered_density_progvar()
subroutine filtered_density_progvar ( double precision  zm0,
double precision  cm0,
◆ filtered_physical_prop()
subroutine filtered_physical_prop ( double precision  zm0,
double precision, dimension(nlibvar)  phim,
double precision, dimension(2, nwsgg)  rad_work,
logical  update_rad
◆ filtered_physical_prop_progvar()
subroutine filtered_physical_prop_progvar ( double precision  zm0,
logical  update_rad
◆ max_mid_min_progvar()
subroutine max_mid_min_progvar ( double precision  zm0,
double precision  cmax,
double precision  cmid,
double precision  cmin
◆ scalar_dissipation_rate()
subroutine scalar_dissipation_rate ( )
