7.2
cs_parall.c File Reference
#include <stdarg.h>
#include "cs_order.h"
+ Include dependency graph for cs_parall.c:
void cs_parall_max_loc_vals (int n, cs_real_t *max, cs_real_t max_loc_vals[])
 Maximum value of a real and the value of related array on all default communicator processes. More...
void cs_parall_min_loc_vals (int n, cs_real_t *min, cs_real_t min_loc_vals[])
 Minimum value of a real and the value of related array on all default communicator processes. More...
void cs_parall_min_id_rank_r (cs_lnum_t *elt_id, int *rank_id, cs_real_t val)
 Given an (id, rank, value) tuple, return the local id and rank corresponding to the global minimum value. More...
void cs_parall_allgather_r (int n_elts, int n_g_elts, cs_real_t array[], cs_real_t g_array[])
 Build a global array from each local array in each domain. More...
void cs_parall_allgather_ordered_r (int n_elts, int n_g_elts, int stride, cs_real_t o_key[], cs_real_t array[], cs_real_t g_array[])
 Build an ordered global array from each local array in each domain. More...
void cs_parall_gather_r (int root_rank, int n_elts, int n_g_elts, const cs_real_t array[], cs_real_t g_array[])
 Build a global array on the given root rank from all local arrays. More...
void cs_parall_gather_ordered_r (int root_rank, int n_elts, int n_g_elts, int stride, cs_real_t o_key[], cs_real_t array[], cs_real_t g_array[])
 Build an ordered global array on the given root rank from all local arrays. More...
void cs_parall_scatter_r (int root_rank, int n_elts, int n_g_elts, const cs_real_t g_array[], cs_real_t array[])
 Distribute a global array from a given root rank over all ranks. Each rank receive the part related to its local elements. More...
void cs_parall_gather_f (int root_rank, int n_elts, int n_g_elts, const float array[], float g_array[])
 Build a global array on the given root rank from all local arrays. Function dealing with single-precision arrays. More...
void cs_parall_scatter_f (int root_rank, int n_elts, int n_g_elts, const float g_array[], float array[])
 Distribute a global array from a given root rank over all ranks. Each rank receive the part related to its local elements. Function dealing with single-precision arrays. More...
size_t cs_parall_get_min_coll_buf_size (void)
 Return minimum recommended scatter or gather buffer size. More...
void cs_parall_set_min_coll_buf_size (size_t buffer_size)
 Define minimum recommended scatter or gather buffer size. More...
Utility functions dealing with parallelism.
◆ cs_parall_allgather_ordered_r()
void cs_parall_allgather_ordered_r ( int  n_elts,
int  n_g_elts,
int  stride,
cs_real_t  o_key[],
cs_real_t  array[],
cs_real_t  g_array[]
Local array elements are ordered based on a given key value (usually some form of coordinate, so the result should be independent of partitioning as long as the definition of the o_key array's defintion is itself independent of the partitioning.
Use of this function may be quite practical, but should be limited to user functions, as it may limit scalability (especially as regards memory usage).
[in]n_eltsnumber of local elements
[in]n_g_eltsnumber of global elements
[in]stridenumber of values per element
[in]o_keyordering key (coordinate) value per element
[in]arraylocal array (size: n_elts*stride)
[out]g_arrayglobal array (size: n_g_elts*stride)
◆ cs_parall_allgather_r()
void cs_parall_allgather_r ( int  n_elts,
int  n_g_elts,
cs_real_t  array[],
cs_real_t  g_array[]
Local arrays are appended in order of owning MPI rank. The size of each local array may be different.
[in]n_eltssize of the local array
[in]n_g_eltssize of the global array
[in]arraylocal array (size: n_elts)
[out]g_arrayglobal array (size: n_g_elts)
◆ cs_parall_gather_f()
void cs_parall_gather_f ( int  root_rank,
int  n_elts,
int  n_g_elts,
float  g_array[]
[in]root_rankrank which stores the global array
[out]g_arrayglobal array (size: n_g_elts) only usable by the root rank
◆ cs_parall_gather_ordered_r()
void cs_parall_gather_ordered_r ( int  root_rank,
int  n_elts,
int  n_g_elts,
int  stride,
cs_real_t  o_key[],
cs_real_t  array[],
cs_real_t  g_array[]
◆ cs_parall_gather_r()
void cs_parall_gather_r ( int  root_rank,
int  n_elts,
int  n_g_elts,
cs_real_t  g_array[]
◆ cs_parall_get_min_coll_buf_size()
size_t cs_parall_get_min_coll_buf_size ( void  )
This is used by some internal part to block or scatter/gather algorithms, so as to allow I/O buffer size tuning.
minimum recommended part to block or gather buffer size (in bytes)
◆ cs_parall_max_loc_vals()
void cs_parall_max_loc_vals ( int  n,
cs_real_t max,
[in]nsize of the related array
[in,out]maxlocal max in, global max out
[in,out]max_loc_valsarray values at location of local max in, and at location of global max out
◆ cs_parall_min_id_rank_r()
void cs_parall_min_id_rank_r ( cs_lnum_t elt_id,
int *  rank_id,
cs_real_t  val
[in,out]elt_idelement id for which the value is the smallest (local in, global out)
[in,out]rank_idrank id for which the value is the smallest (local in, global out)
[in]valassociated local minimum value
◆ cs_parall_min_loc_vals()
void cs_parall_min_loc_vals ( int  n,
cs_real_t min,
[in,out]minlocal min in, global min out
[in,out]min_loc_valsarray values at location of local min in, and at location of global min out
◆ cs_parall_scatter_f()
void cs_parall_scatter_f ( int  root_rank,
int  n_elts,
int  n_g_elts,
float  array[]
Use of this function may be quite practical, but should be limited to specific usage, as it may limit scalability (especially as regards memory usage).
[in]g_arrayglobal array (size: n_g_elts) only usable by the root rank
[out]arraylocal array (size: n_elts)
◆ cs_parall_scatter_r()
void cs_parall_scatter_r ( int  root_rank,
int  n_elts,
int  n_g_elts,
cs_real_t  array[]
◆ cs_parall_set_min_coll_buf_size()
void cs_parall_set_min_coll_buf_size ( size_t  buffer_size)
[in]buffer_sizeminimum recommended part to block or gather buffer size (in bytes)
