7.2
cs_mesh_bad_cells.h
1 #ifndef __CS_MESH_BAD_CELLS_H__
2 #define __CS_MESH_BAD_CELLS_H__
5  * Detect bad cells within meshes.
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_mesh.h"
36 #include "cs_mesh_quantities.h"
43  * Macro definitions
45
46 /*
47  * Detection criteria type
48  */
49
50 #define CS_BAD_CELL_ORTHO_NORM (1 << 0)
51 #define CS_BAD_CELL_OFFSET (1 << 1)
52 #define CS_BAD_CELL_LSQ_GRAD (1 << 2)
53 #define CS_BAD_CELL_RATIO (1 << 3)
54 #define CS_BAD_CELL_GUILT (1 << 4)
55 #define CS_BAD_CELL_USER (1 << 5)
56 #define CS_BAD_CELL_TO_REGULARIZE (1 << 6)
57
58 /*=============================================================================
61
62 /*----------------------------------------------------------------------------
63  * Define which cell quality indicators are used and when.
64  *
65  * Note: we assume that if a given criterion is computed at each time
66  * step, it is also computed at initialization, but for visualization,
67  * it is either one or the other, as visualization formats and tools
68  * may not always accept both a fixed and time-varying instance of a
69  * given variable.
70  *
71  * parameters:
72  * type_flag_mask <-- criterion type mask (0 for all)
73  * compute <-- 0: never compute;
74  * 1: compute at initialization;
75  * 2: compute at each time step
76  * visualize <-- 0: never visualize
77  * 1: visualize at initialization;
78  * 2: visualize at each time step
79  *----------------------------------------------------------------------------*/
80
81 void
82 cs_mesh_bad_cells_set_options(int type_flag_mask,
83  int compute,
84  int visualize);
85
87  * Indicate which cell quality indicators are used and when.
88  *
89  * Each array is optional, and returns 2 flags; the first flag is used at
90  * initialization, the second one at each time step.
91  *
92  * A flag is a mask to be compared using an "and" (&) operation with a given
93  * criteria type mask (CS_BAD_CELL_ORTHO_NORM, CS_BAD_CELL_OFFSET, ...).
94  *
95  * parameters:
96  * compute --> computation mask (initialization, per time step), or NULL
97  * visualize --> visualization mask (initialization, per time step), or NULL
98  *----------------------------------------------------------------------------*/
99
100 void
101 cs_mesh_bad_cells_get_options(int compute[2],
102  int visualize[2]);
103
104 /*----------------------------------------------------------------------------
105  * Compute bad cell quality indicators.
106  *
107  * parameters:
108  * mesh <-- pointer to a mesh structure.
109  * mesh_quantities <-> pointer to a mesh quantities structures.
110  *----------------------------------------------------------------------------*/
111
112 void
114  cs_mesh_quantities_t *mesh_quantities);
115
116 /*----------------------------------------------------------------------------
117  * Post-process bad cell quality indicators.
118  *
119  * parameters:
120  * mesh <-- pointer to a mesh structure.
121  * mesh_quantities <-- pointer to a mesh quantities structures.
122  *----------------------------------------------------------------------------*/
123
124 void
126  const cs_mesh_quantities_t *mesh_quantities);
127
129
131
132 #endif /* __CS_MESH_BAD_CELLS_H__ */
void cs_mesh_bad_cells_set_options(int type_flag_mask, int compute, int visualize)
Definition: cs_mesh_bad_cells.c:746
Definition: cs_mesh.h:84
void cs_mesh_bad_cells_get_options(int compute[2], int visualize[2])
Definition: cs_mesh_bad_cells.c:798
void cs_mesh_bad_cells_detect(const cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
Definition: cs_mesh_bad_cells.c:826
void cs_mesh_bad_cells_postprocess(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
Post-process time-independent bad cell quality indicators.
Definition: cs_mesh_bad_cells.c:1126
Definition: mesh.f90:26
