Include dependency graph for cs_measures_util.h:Go to the source code of this file.
| struct | cs_measures_set_t |
| struct | cs_interpol_grid_t |
| void | cs_interpol_field_on_grid (cs_interpol_grid_t *ig, const cs_real_t *values_to_interpol, cs_real_t *interpoled_values) |
| cs_interpol_grid_t * | cs_interpol_grid_create (const char *name) |
| void | cs_interpol_grid_init (cs_interpol_grid_t *ig, const cs_lnum_t nb_points, const cs_real_t *coords) |
| cs_measures_set_t * | cs_measures_set_create (const char *name, int type_flag, int dim, bool interleaved) |
| void | cs_measures_set_map_values (cs_measures_set_t *ms, const cs_lnum_t nb_measures, const int *is_cressman, const int *is_interpol, const cs_real_t *measures_coords, const cs_real_t *measures, const cs_real_t *influence_radius) |
| void | cs_measures_set_add_values (cs_measures_set_t *ms, const cs_lnum_t nb_measures, const int *is_cressman, const int *is_interpol, const cs_real_t *measures_coords, const cs_real_t *measures, const cs_real_t *influence_radius) |
| void | cs_cressman_interpol (cs_measures_set_t *ms, cs_real_t *interpolated_values, int id_type) |
| cs_measures_set_t * | cs_measures_set_by_id (int id) |
| cs_interpol_grid_t * | cs_interpol_grid_by_id (int id) |
| cs_measures_set_t * | cs_measures_set_by_name (const char *name) |
| cs_interpol_grid_t * | cs_interpol_grid_by_name (const char *name) |
| void | cs_measures_sets_destroy (void) |
| void | cs_interpol_grids_destroy (void) |
| void | mestcr (const char *name, const int *idim, const int *ilved, int *imeset) |
| void | gridcr (const char *name, int *igrid) |
| void | mesmap (const int *imeset, const int *inbmes, const cs_real_t *meset, const cs_real_t *coords, const int *cressm, const int *interp, const cs_real_t *infrad) |
| void | grimap (const int *igrid, const int *inpts, const cs_real_t *coords) |
| void | mesadd (const int *imeset, const int *inbmes, const cs_real_t *meset, const cs_real_t *coords, const int *cressm, const int *interp, const cs_real_t *infrad) |
| void | mscrss (const int *imeset, const int *type, cs_real_t *pldval) |
| void | gripol (const int *igrid, const cs_real_t *inval, cs_real_t *pldval) |
| void | mestde (void) |
| void | grides (void) |
| void cs_cressman_interpol | ( | cs_measures_set_t * | ms, |
| cs_real_t * | interpolated_values, | ||
| int | id_type | ||
| void cs_interpol_field_on_grid | ( | cs_interpol_grid_t * | ig, |
| const cs_real_t * | values_to_interpol, | ||
| cs_real_t * | interpoled_values | ||
| cs_interpol_grid_t* cs_interpol_grid_by_id | ( | int | id | ) |
| cs_interpol_grid_t* cs_interpol_grid_by_name | ( | const char * | name | ) |
| cs_interpol_grid_t* cs_interpol_grid_create | ( | const char * | name | ) |
| void cs_interpol_grid_init | ( | cs_interpol_grid_t * | ig, |
| const cs_lnum_t | nb_points, | ||
| const cs_real_t * | coords | ||
| void cs_interpol_grids_destroy | ( | void | ) |
| void cs_measures_set_add_values | ( | cs_measures_set_t * | ms, |
| const cs_lnum_t | nb_measures, | ||
| const int * | is_cressman, | ||
| const int * | is_interpol, | ||
| const cs_real_t * | measures_coords, | ||
| const cs_real_t * | measures, | ||
| const cs_real_t * | influence_radius | ||
| cs_measures_set_t* cs_measures_set_by_id | ( | int | id | ) |
| cs_measures_set_t* cs_measures_set_by_name | ( | const char * | name | ) |
| cs_measures_set_t* cs_measures_set_create | ( | const char * | name, |
| int | type_flag, | ||
| int | dim, | ||
| bool | interleaved | ||
| void cs_measures_set_map_values | ( | cs_measures_set_t * | ms, |
| void cs_measures_sets_destroy | ( | void | ) |
| void gridcr | ( | const char * | name, |
| int * | igrid | ||
| void grides | ( | void | ) |
| void grimap | ( | const int * | igrid, |
| const int * | inpts, | ||
| void mesadd | ( | const int * | imeset, |
| const int * | inbmes, | ||
| const cs_real_t * | meset, | ||
| const cs_real_t * | coords, | ||
| const int * | cressm, | ||
| const int * | interp, | ||
| const cs_real_t * | infrad | ||
| void mesmap | ( | const int * | imeset, |
| void mestcr | ( | const char * | name, |
| const int * | idim, | ||
| const int * | ilved, | ||
| int * | imeset | ||
| void mestde | ( | void | ) |
| void mscrss | ( | const int * | imeset, |
| const int * | type, | ||
| cs_real_t * | pldval | ||
