308 const int *diffusion,
313 const int *unsaturated);
447 const char *property_name,
void uiphyv(const int *iviscv)
Definition: cs_gui.c:2369
void csidtv(void)
Definition: cs_gui.c:1661
const cs_gui_volume_meg_context_t * cs_gui_add_volume_meg_context(const cs_zone_t *zone, const cs_field_t *fields[], const int n_fields)
Add new volume MEG function context info.
Definition: cs_gui.c:5133
#define restrict
Definition: cs_defs.h:142
void csnum2(double *relaxp, int *imrgra)
Definition: cs_gui.c:1935
void cs_gui_user_variables(void)
Definition: cs_gui.c:4623
void cs_gui_head_losses(const cs_zone_t *zone, const cs_real_3_t *cvara_vel, cs_real_t cku[][6])
Compute GUI-defined head losses for a given volume zone.
Definition: cs_gui.c:2987
void cs_gui_fluid_properties_value(const char *param, double *value)
Definition: cs_gui.c:2963
void cs_gui_thermal_model(void)
Definition: cs_gui.c:4159
Definition: cs_field.h:125
void cscfgp(int *icfgrp)
Definition: cs_gui.c:1713
integer iesder
Error estimator for Navier-Stokes. iest = iesder: drift (default name: EsDer). The estimator is base...
Definition: paramx.f90:258
integer, save ntsuit
saving period of the restart files
Definition: entsor.f90:52
void cs_gui_physical_properties(void)
Definition: cs_gui.c:3828
void cs_gui_turbomachinery(void)
Definition: cs_gui.c:4340
void cs_gui_define_fans(void)
Definition: cs_gui.c:4929
void cs_gui_parallel_io(void)
Definition: cs_gui.c:3639
void cs_gui_user_arrays(void)
Definition: cs_gui.c:4683
integer idarcy
pointer to specify richards model
Definition: ppincl.f90:264
void cs_gui_turb_ref_values(void)
Definition: cs_gui.c:4556
Definition: cs_defs.h:322
void cs_gui_usage_log(void)
Definition: cs_gui.c:4595
void cs_gui_partition(void)
Definition: cs_gui.c:3706
void uiporo(void)
Definition: cs_gui.c:2028
void cs_gui_internal_coupling(void)
Definition: cs_gui.c:5054
void cs_gui_turbomachinery_rotor(void)
Definition: cs_gui.c:4355
void cscpva(void)
Definition: cs_gui.c:1541
integer(c_int), pointer, save iccvfg
Definition: optcal.f90:795
void uiexop(void)
Definition: cs_gui.c:2524
void csivis(void)
Definition: cs_gui.c:1588
void cs_gui_properties_value_by_fluid_id(const int fluid_id, const char *property_name, double *value)
Definition: cs_gui.c:4063
void cs_gui_zones(void)
Definition: cs_gui.c:4726
void uitssc(const int *idarcy, const int *f_id, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
Definition: cs_gui.c:2208
void cs_gui_scalar_model_settings(void)
Definition: cs_gui.c:4098
integer, save icfgrp
indicates if the boundary conditions should take into account (=1) or not (=0) the hydrostatic balanc...
Definition: ppincl.f90:713
int cs_gui_thermal_model_code(void)
Definition: cs_gui.c:4203
void cs_gui_mpi_algorithms(void)
Definition: cs_gui.c:3802
integer, dimension(nestmx), save iescal
iescal indicates the calculation mode for the error estimator iespre, iesder, iescor or iestot for th...
Definition: optcal.f90:917
void cs_gui_initial_conditions(void)
Apply initial conditions based on GUI-defined settings.
Definition: cs_gui.c:3058
void cs_gui_pressure_drop_by_zone(void)
Definition: cs_gui.c:4907
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
void cs_gui_error_estimator(int *iescal, int *iespre, int *iesder, int *iescor, int *iestot)
Definition: cs_gui.c:4995
double precision, dimension(nvarmx), save cdtvar
multiplicator coefficient for the time step of each variable
Definition: optcal.f90:433
void cs_gui_properties_value(const char *property_name, double *value)
Definition: cs_gui.c:4037
void uidapp(const int *permeability, const int *diffusion, const int *gravity, const cs_real_t *gravity_x, const cs_real_t *gravity_y, const cs_real_t *gravity_z, const int *unsaturated)
Definition: cs_gui.c:2546
void uitsth(const int *f_id, const cs_real_t *restrict pvar, cs_real_t *restrict tsexp, cs_real_t *restrict tsimp)
Definition: cs_gui.c:2293
void uieres(int *iescal, int *iespre, int *iesder, int *iescor, int *iestot)
Definition: cs_gui.c:2920
void cs_gui_finalize(void)
Definition: cs_gui.c:2942
void csisui(int *ntsuit, int *iccvfg)
Definition: cs_gui.c:1740
#define CS_PROCF(x, y)
Definition: cs_defs.h:524
void uitsnv(const cs_real_3_t *restrict vel, cs_real_3_t *restrict tsexp, cs_real_33_t *restrict tsimp)
Definition: cs_gui.c:2096
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:342
void csvvva(int *iviscv)
Definition: cs_gui.c:1566
const cs_zone_t * zone
Definition: cs_gui.h:50
void csiphy(void)
Definition: cs_gui.c:1685
void cstime(void)
Definition: cs_gui.c:1771
void cs_gui_turb_model(void)
Definition: cs_gui.c:4446
void cs_gui_time_moments(void)
Definition: cs_gui.c:4240
void cs_gui_porous_model(void)
Definition: cs_gui.c:4001
integer, save iviscv
additional property:
Definition: ppincl.f90:653
integer iestot
Error estimator for Navier-Stokes. iest = iestot: total, (default name: EsTot). The estimator ...
Definition: paramx.f90:308
integer iescor
Error estimator for Navier-Stokes. iest = iescor: correction, (default name: EsCor). The estimator comes directly from the mass flow calculated with the updated velocity field: .
Definition: paramx.f90:278
integer(c_int), pointer, save imrgra
type of gradient reconstruction
Definition: optcal.f90:260
const cs_field_t ** fields
Definition: cs_gui.h:51
void cs_gui_linear_solvers(void)
Definition: cs_gui.c:3491
void cs_gui_balance_by_zone(void)
Definition: cs_gui.c:4878
void uinum1(double *cdtvar)
Definition: cs_gui.c:1847
integer iespre
Error estimator for Navier-Stokes. iest = iespre: prediction, (default name: EsPre). After the velocity prediction step (yielding ), the estimator , local variable calculated at every cell , is created from , which represents the residual of the equation solved during this step: and : .
Definition: paramx.f90:242
