7.2
cs_fan.h
1 #ifndef __CS_FAN_H__
2 #define __CS_FAN_H__
5  * Fan modeling through velocity source terms.
35  * Local headers
38 #include "cs_base.h"
40 #include "cs_mesh.h"
41 #include "cs_mesh_quantities.h"
46
48  * Structure definition
50
51 typedef struct _cs_fan_t cs_fan_t;
52
54  * Public function prototypes for Fortran API
56
58  * Compute the flows through the fans
59  *
60  * Fortran interface:
61  *
62  * subroutine debvtl
63  * *****************
64  *
65  * double precision flumas(*) : <-- : interior faces mass flux
66  * double precision flumab(*) : <-- : boundary faces mass flux
67  * double precision rhofac(*) : <-- : density at cells
68  * double precision rhofab(*) : <-- : density at boundary faces
69  *----------------------------------------------------------------------------*/
70
71 void CS_PROCF (debvtl, DEBVTL)
72 (
73  cs_real_t flumas[],
74  cs_real_t flumab[],
75  cs_real_t rhofac[],
76  cs_real_t rhofab[]
77 );
78
79 /*----------------------------------------------------------------------------
80  * Compute the force induced by the fans (needs a previous calculation
81  * of the flows through each fan).
82  *
83  * The induced force is added to the array crvxep (which can have other
84  * contributions).
85  *
86  * Fortran interface:
87  *
88  * subroutine tsvvtl
89  * *****************
90  *
91  * parameters:
92  * crvexp <-> Explicit source term (velocity)
93  *----------------------------------------------------------------------------*/
94
95 void CS_PROCF (tsvvtl, TSVVTL)
96 (
97  cs_real_3_t crvexp[]
98 );
99
100 /*============================================================================
101  * Public function prototypes
102  *============================================================================*/
103
104 /*----------------------------------------------------------------------------
105  * Fan definition (added to the ones previously defined)
106  *
107  * Fans are handled as explicit momentum source terms at the given location,
108  * based on the fan's axis and diameter.
109  * The fan's pressure characteristic curve is defined by 3 coefficients,
110  * such that:
111  * delta P = C_0 + C_1.flow + C_2.flow^2
112  * An axial torque may also be defined for the 3D model.
113  *
114  * parameters:
115  * fan_dim <-- fan dimension:
116  * 2: pseudo-2D (extruded mesh)
117  * 3: 3D (standard)
118  * mode <-- mode:
119  * 0: fan
120  * 1: wind turbine
121  * inlet_axis_coords <-- intersection coords. of axis and inlet face
122  * outlet_axis_coords <-- intersection coords. od axis and outlet face
123  * fan_radius <-- fan radius
124  * blades_radius <-- blades radius
125  * hub_radius <-- hub radius
126  * curve_coeffs <-- coefficients of degre 0, 1 and 2 of
127  * the pressure drop/flow rate
128  * characteristic curve
129  * axial_torque <-- fan axial torque
130  *----------------------------------------------------------------------------*/
131
132 void
133 cs_fan_define(int fan_dim,
134  int mode,
135  const cs_real_t inlet_axis_coords[3],
136  const cs_real_t outlet_axis_coords[3],
137  cs_real_t fan_radius,
138  cs_real_t blades_radius,
139  cs_real_t hub_radius,
140  const cs_real_t curve_coeffs[3],
141  cs_real_t axial_torque);
142
143 /*----------------------------------------------------------------------------
144  * Destroy the structures associated with fans.
145  *----------------------------------------------------------------------------*/
146
147 void
148 cs_fan_destroy_all(void);
149
150 /*----------------------------------------------------------------------------
151  * Return number of fans.
152  *
153  * returns:
154  * number of defined fans
155  *----------------------------------------------------------------------------*/
156
157 int
158 cs_fan_n_fans(void);
159
160 /*----------------------------------------------------------------------------
161  * Log fans definition setup information.
162  *----------------------------------------------------------------------------*/
163
164 void
165 cs_fan_log_setup(void);
166
167 /*----------------------------------------------------------------------------
168  * Log fan information for a given iteration.
169  *----------------------------------------------------------------------------*/
170
171 void
173
174 /*----------------------------------------------------------------------------
175  * Define the cells belonging to the different fans.
176  *
177  * parameters:
178  * mesh <-- associated mesh structure
179  * mesh_quantities <-- mesh quantities
180  *----------------------------------------------------------------------------*/
181
182 void
184  const cs_mesh_quantities_t *mesh_quantities);
185
186 /*----------------------------------------------------------------------------
187  * Compute the flows through the fans.
188  *
189  * parameters:
190  * mesh <-- mesh structure
191  * mesh_quantities <-- mesh quantities
192  * i_mass_flux <-- interior faces mass flux
193  * b_mass_flux <-- boundary faces mass flux
194  * c_rho <-- density at cells
195  * b_rho <-- density at boundary faces
196  *----------------------------------------------------------------------------*/
197
198 void
200  const cs_mesh_quantities_t *mesh_quantities,
201  const cs_real_t i_mass_flux[],
202  const cs_real_t b_mass_flux[],
203  const cs_real_t c_rho[],
204  const cs_real_t b_rho[]);
205
206 /*----------------------------------------------------------------------------
207  * Compute the force induced by the fans (needs a previous calculation
208  * of the flows through each fan).
209  *
210  * The induced force is added to the array CRVXEP (which can have other
211  * other contributions).
212  *
213  * parameters:
214  * mesh_quantities <-- mesh quantities
215  * source_t <-> explicit source term for the velocity
216  *----------------------------------------------------------------------------*/
217
218 void
219 cs_fan_compute_force(const cs_mesh_quantities_t *mesh_quantities,
220  cs_real_3_t source_t[]);
221
222 /*----------------------------------------------------------------------------
223  * Flag the cells belonging to the different fans
224  * (by the fan id, -1 otherwise)
225  *
226  * parameters:
227  * mesh <-- associated mesh structure
228  * cell_fan_id --> indicator by cell
229  *----------------------------------------------------------------------------*/
230
231 void
233  int cell_fan_id[]);
234
235 /*----------------------------------------------------------------------------
236  * Selection function for cells belonging to fans.
237  *
238  * This function may be used for the definition of postprocessing meshes.
239  *
240  * param
241  * \param[in, out] input pointer to input (unused here)
242  * \param[out] n_cells number of selected cells
243  * \param[out] cell_ids array of selected cell ids (0 to n-1 numbering)
244  */
245 /*----------------------------------------------------------------------------*/
246
247 void
248 cs_fan_cells_select(void *input,
249  cs_lnum_t *n_cells,
250  cs_lnum_t **cell_ids);
251
253
255
256 #endif /* __CS_FAN_H__ */
void cs_fan_build_all(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
Definition: cs_fan.c:430
void cs_fan_log_setup(void)
Definition: cs_fan.c:348
Definition: cs_fan.h:51
int cs_fan_n_fans(void)
Definition: cs_fan.c:336
void cs_fan_log_iteration(void)
Definition: cs_fan.c:394
void debvtl(cs_real_t flumas[], cs_real_t flumab[], cs_real_t rhofac[], cs_real_t rhofab[])
Definition: cs_fan.c:157
Definition: cs_defs.h:322
void cs_fan_cells_select(void *input, cs_lnum_t *n_cells, cs_lnum_t **cell_ids)
Definition: cs_fan.c:966
Definition: cs_mesh.h:84
void cs_fan_define(int fan_dim, int mode, const cs_real_t inlet_axis_coords[3], const cs_real_t outlet_axis_coords[3], cs_real_t fan_radius, cs_real_t blades_radius, cs_real_t hub_radius, const cs_real_t curve_coeffs[3], cs_real_t axial_torque)
Definition: cs_fan.c:231
void cs_fan_compute_flows(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, const cs_real_t i_mass_flux[], const cs_real_t b_mass_flux[], const cs_real_t c_rho[], const cs_real_t b_rho[])
Definition: cs_fan.c:625
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
void tsvvtl(cs_real_3_t crvexp[])
Definition: cs_fan.c:189
Definition: cs_defs.h:316
void cs_fan_flag_cells(const cs_mesh_t *mesh, int cell_fan_id[])
Flag the cells belonging to the different fans (by the fan id, -1 otherwise)
Definition: cs_fan.c:918
#define CS_PROCF(x, y)
Definition: cs_defs.h:524
void cs_fan_destroy_all(void)
Definition: cs_fan.c:314
Definition: mesh.f90:26
void cs_fan_compute_force(const cs_mesh_quantities_t *mesh_quantities, cs_real_3_t source_t[])
Compute the force induced by the fans (needs a previous calculation of the flows through each fan)...
Definition: cs_fan.c:759
