Include dependency graph for cs_crystal_router.h:Go to the source code of this file.
Macros | |
| #define | CS_CRYSTAL_ROUTER_USE_DEST_ID (1 << 0) |
| #define | CS_CRYSTAL_ROUTER_ADD_SRC_ID (1 << 1) |
| #define | CS_CRYSTAL_ROUTER_ADD_SRC_RANK (1 << 2) |
| typedef struct _cs_crystal_router_t | cs_crystal_router_t |
| cs_crystal_router_t * | cs_crystal_router_create_s (size_t n_elts, int stride, cs_datatype_t datatype, int flags, const void *elt, const cs_lnum_t *src_id, const cs_lnum_t *dest_id, const int dest_rank[], MPI_Comm comm) |
| Create a Crystal Router for strided data. More... | |
| cs_crystal_router_t * | cs_crystal_router_create_i (size_t n_elts, cs_datatype_t datatype, int flags, const cs_lnum_t *eld_idx, const void *elt, const cs_lnum_t *src_id, const cs_lnum_t *dest_id, const int dest_rank[], MPI_Comm comm) |
| Create a Crystal Router for indexed data. More... | |
| void | cs_crystal_router_destroy (cs_crystal_router_t **cr) |
| Destroy a Crystal Router. More... | |
| void | cs_crystal_router_exchange (cs_crystal_router_t *cr) |
| Exchange data with a Crystal Router. More... | |
| cs_lnum_t | cs_crystal_router_n_elts (const cs_crystal_router_t *cr) |
| Get number of elements associated with Crystal Router. More... | |
| cs_lnum_t | cs_crystal_router_n_recv_elts (const cs_crystal_router_t *cr) |
| Get number of elements received with Crystal Router. More... | |
| void | cs_crystal_router_get_data (cs_crystal_router_t *cr, int **src_rank, cs_lnum_t **dest_id, cs_lnum_t **src_id, cs_lnum_t **data_index, void **data) |
| Get data elements associated with a Crystal Router. More... | |
| size_t | cs_crystal_router_get_max_sizes (cs_crystal_router_t *cr, size_t *max_sizes) |
| Query maximum buffer sizes reached by a Crystal Router. More... | |
| void | cs_crystal_router_log_finalize (void) |
| Log performance information relative to Crystal Router exchange. More... | |
| #define CS_CRYSTAL_ROUTER_ADD_SRC_ID (1 << 1) |
| #define CS_CRYSTAL_ROUTER_ADD_SRC_RANK (1 << 2) |
| #define CS_CRYSTAL_ROUTER_USE_DEST_ID (1 << 0) |
Crystal router ordering and metadata flags.
Opaque Crystal Router distribution structure
Flags are defined as a sum (bitwise or) of constants, which may include CS_CRYSTAL_ROUTER_USE_DEST_ID, CS_CRYSTAL_ROUTER_ADD_SRC_ID, and CS_CRYSTAL_ROUTER_ADD_SRC_RANK.
| cs_crystal_router_t* cs_crystal_router_create_i | ( | size_t | n_elts, |
| int | flags, | ||
| const cs_lnum_t * | elt_idx, | ||
| const void * | elt, | ||
| const cs_lnum_t * | src_id, | ||
| const cs_lnum_t * | dest_id, | ||
| const int | dest_rank[], | ||
| MPI_Comm | comm | ||
If the flags constant contains CS_CRYSTAL_ROUTER_USE_DEST_ID, data exchanged will be ordered by the array passed to the dest_id argument. For n total values received on a rank (as given by cs_crystal_router_n_elts), those destination ids must be in the range [0, n[.
If the flags bit mask matches CS_CRYSTAL_ROUTER_ADD_SRC_ID, source ids are added. If it matches CS_CRYSTAL_ROUTER_ADD_SRC_RANK, source rank metadata is added.
| [in] | datatype | type of data considered |
| [in] | flags | add destination id ? |
| [in] | elt_idx | element values start and past-the-last index |
| [in] | elt | element values |
| [in] | src_id | optional parent element id (indirection for elt and elt_idx arrays), or NULL |
| [in] | dest_id | element destination id, or NULL |
| [in] | dest_rank | destination rank for each element |
| [in] | comm | associated MPI communicator |
| cs_crystal_router_t* cs_crystal_router_create_s | ( | size_t | n_elts, |
| int | stride, | ||
| int | flags, | ||
| [in] | stride | number of values per entity (interlaced) |
| [in] | src_id | optional parent element id (indirection for elt array), or NULL |
| void cs_crystal_router_destroy | ( | cs_crystal_router_t ** | cr | ) |
| [in,out] | cr | pointer to associated Crystal Router |
| void cs_crystal_router_exchange | ( | cs_crystal_router_t * | cr | ) |
Order of data from a same source rank is preserved.
| void cs_crystal_router_get_data | ( | cs_crystal_router_t * | cr, |
| int ** | src_rank, | ||
| cs_lnum_t ** | dest_id, | ||
| cs_lnum_t ** | src_id, | ||
| cs_lnum_t ** | data_index, | ||
| void ** | data | ||
Depending on the creation options, some elements may be available or not.
For each element type, a pointer to a pointer to a buffer is provided. If the pointer to the buffer is non-null, the buffer must be of sufficient size for the number of elements returned by cs_crystal_router_n_elts.
Note also that if the destination id is provided in the Crystal Router, it will be applied automatically to the data and data_index arrays. The dest_id array itself is always in receive order. If the Crystal Router does not contain destination id info but the dest_id argument points to a non-NULL value, the provided id will be used to order extracted data. This allows saving the destination id on the receive side, and not re-sending it (saving bandwidth) for subsequent calls with a similar Crystal Router.
If all destination ids appear only once, or the CS_CRYSTAL_ROUTER_USE_DEST_ID is not set, dest_id is also applied to src_rank and src_id. Otherwise, those arrays are kept in buffer order. This can be checked by comparing the output of cs_crystal_router_n_elts and cs_crystal_router_n_recv_elts.
With this behavior, for reverse exchange, src_id and src_rank can be used as dest_id and dest_rank respectively in the call to cs_crystal_router_create_s, while NULL is passed to elt_id with single ids, and dest_id passed in case of duplicate ids.
| [in] | cr | pointer to associated Crystal Router |
| [out] | src_rank | pointer to (pointer to) source rank array, or NULL |
| [in,out] | dest_id | pointer to (pointer to) destination id array, or NULL |
| [out] | src_id | pointer to (pointer to) source id array, or NULL |
| [out] | data_index | pointer to (pointer to) destination index, or NULL |
| [out] | data | pointer to (pointer to) destination data, or NULL |
| size_t cs_crystal_router_get_max_sizes | ( | cs_crystal_router_t * | cr, |
| size_t * | max_sizes | ||
| [out] | max_sizes | pointer to maximum local/receive (max_sizes[0]) and send (max_sizes[1]) sizes, or NULL |
| void cs_crystal_router_log_finalize | ( | void | ) |
Call count is based on Crystal router creation calls, as the number of exchange and data access calls should be identical.
| cs_lnum_t cs_crystal_router_n_elts | ( | const cs_crystal_router_t * | cr | ) |
| cs_lnum_t cs_crystal_router_n_recv_elts | ( | const cs_crystal_router_t * | cr | ) |
The number of elements is the number of elements received in the exchange. In most cases this is the same as that returned using cs_crystal_router_n_elts, but may be larger when a destination id is used and multiple elements point to a same destination (for example when distributing from partitioned data with elements duplicated on partition boundaries to blocks with a single occurence of elements).
