7.2
cs_cdofb_ac.h
1 #ifndef __CS_CDOFB_AC_H__
2 #define __CS_CDOFB_AC_H__
5  * Build an algebraic CDO face-based system for the Navier-Stokes equations
6  * and solved it with an artificial compressibility algorithm
8
9 /*
10  This file is part of code_saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2022 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Standard C library headers
35  *----------------------------------------------------------------------------*/
36
37 /*----------------------------------------------------------------------------
38  * Local headers
39  *----------------------------------------------------------------------------*/
41 #include "cs_base.h"
42 #include "cs_cdo_connect.h"
43 #include "cs_cdo_quantities.h"
44 #include "cs_equation.h"
45 #include "cs_mesh.h"
46 #include "cs_navsto_coupling.h"
47 #include "cs_navsto_param.h"
48 #include "cs_source_term.h"
49 #include "cs_time_step.h"
50
51 /*----------------------------------------------------------------------------*/
52
54
55 /*============================================================================
56  * Macro definitions
58
59 /*============================================================================
60  * Type definitions
62
63 /*============================================================================
64  * Inline static function prototypes
65  *============================================================================*/
66
67 /*----------------------------------------------------------------------------*/
75 /*----------------------------------------------------------------------------*/
76
77 inline static cs_real_t *
79 {
81  previous);
82 }
83
84 /*============================================================================
85  * Public function prototypes
86  *============================================================================*/
87
88 /*----------------------------------------------------------------------------*/
96 /*----------------------------------------------------------------------------*/
97
98 void
100  const cs_cdo_connect_t *connect,
101  const cs_time_step_t *time_step);
102
103 /*----------------------------------------------------------------------------*/
116 /*----------------------------------------------------------------------------*/
117
118 void *
120  cs_adv_field_t *adv_field,
121  cs_real_t *mflux,
122  cs_real_t *mflux_pre,
123  cs_boundary_type_t *fb_type,
124  void *nsc_input);
125
126 /*----------------------------------------------------------------------------*/
135
136 void *
137 cs_cdofb_ac_free_scheme_context(void *scheme_context);
138
139 /*----------------------------------------------------------------------------*/
148 /*----------------------------------------------------------------------------*/
149
150 void
152  void *context);
153
154 /*----------------------------------------------------------------------------*/
164 /*----------------------------------------------------------------------------*/
165
166 void
168  const cs_navsto_param_t *nsp,
169  void *scheme_context);
170
171 /*----------------------------------------------------------------------------*/
182 /*----------------------------------------------------------------------------*/
183
184 void
186  const cs_navsto_param_t *nsp,
187  void *scheme_context);
188
189 /*----------------------------------------------------------------------------*/
190
192
193 #endif /* __CS_CDOFB_AC_H__ */
void cs_cdofb_ac_init_common(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Definition: cs_cdofb_ac.c:905
time step descriptor
Definition: cs_time_step.h:64
int cs_boundary_type_t
Definition: cs_boundary.h:69
Definition: cs_advection_field.h:150
void cs_cdofb_ac_set_sles(const cs_navsto_param_t *nsp, void *context)
Start setting-up the Navier-Stokes equations when an AC algorithm is used to couple the system...
Definition: cs_cdofb_ac.c:1101
static cs_real_t * cs_cdofb_ac_get_face_velocity(bool previous)
Retrieve the values of the velocity on the faces.
Definition: cs_cdofb_ac.h:78
Definition: cs_navsto_param.h:604
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
Definition: cs_mesh.h:84
void * cs_cdofb_ac_init_scheme_context(const cs_navsto_param_t *nsp, cs_adv_field_t *adv_field, cs_real_t *mflux, cs_real_t *mflux_pre, cs_boundary_type_t *fb_type, void *nsc_input)
Initialize a cs_cdofb_ac_t structure.
Definition: cs_cdofb_ac.c:932
void cs_cdofb_ac_compute_implicit_nl(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Solve the unsteady Navier-Stokes system with a CDO face-based scheme using a Artificial Compressibili...
Definition: cs_cdofb_ac.c:1325
cs_real_t * cs_equation_get_face_values(const cs_equation_t *eq, bool previous)
For a given equation, retrieve an array of values related to each face of the mesh for the unknowns...
Definition: cs_equation.c:2949
void cs_cdofb_ac_compute_implicit(const cs_mesh_t *mesh, const cs_navsto_param_t *nsp, void *scheme_context)
Definition: cs_cdofb_ac.c:1165
void * cs_cdofb_ac_free_scheme_context(void *scheme_context)
Destroy a cs_cdofb_ac_t structure.
Definition: cs_cdofb_ac.c:1064
Definition: mesh.f90:26
cs_equation_t * cs_equation_by_name(const char *eqname)
Find the cs_equation_t structure with name eqname Return NULL if not find.
Definition: cs_equation.c:474
