Explicit sources terms from sources condensation computation.
More...
| subroutine | condensation_source_terms (ncelet, iscal, nfbpcd, ifbpcd, itypcd, ncmast, ltmast, itypst, spcondp, gam_s, svcondp, gam_ms, fluxv_ms, pvara, tsexp, tsimp) |
◆ condensation_source_terms()
| subroutine condensation_source_terms |
integer |
ncelet, |
integer |
iscal, |
integer |
nfbpcd, |
integer, dimension(nfbpcd) |
ifbpcd, |
itypcd, |
integer |
ncmast, |
integer, dimension(ncelet) |
ltmast, |
itypst, |
double precision, dimension(nfbpcd) |
spcondp, |
gam_s, |
double precision, dimension(ncelet) |
svcondp, |
gam_ms, |
fluxv_ms, |
double precision, dimension (ncelet) |
pvara, |
tsexp, |
tsimp |
- Parameters
| [in] | ncelet | number of extended (real + ghost) cells |
| [in] | iscal | scalar number |
| [in] | nfbpcd | number of faces with condensation source terms |
| [in] | ifbpcd | index of faces with condensation source terms |
| [in] | itypcd | type of condensation source terms for each ivar |
| [in] | ncmast | number of cells with metal mass condensation |
| [in] | ltmast | index of cells with metal mass condensation |
| [in] | itypst | type of metal mass condensation source terms |
| [in] | spcondp | value of the variable associated to surface condensation source term |
| [in] | gam_s | surface condensation flow rate value |
| [in] | svcondp | value of the variable associated to metal mass condensation source term |
| [in] | gam_ms | metal mass condensation flow rate value |
| [in] | fluxv_ms | metal mass condensation heat transfer flux |
| [in] | pvara | variable value at time step beginning |
| [in,out] | tsexp | explicit source term part linear in the variable |
| [in,out] | tsimp | associated value with tsexp to be stored in the matrix |
