7.2
clptrg.f90 File Reference
Boundary conditions for rough walls (icodcl = 6). More...
Functions/Subroutines
subroutine clptrg (nscal, isvhb, icodcl, rcodcl, velipb, rijipb, visvdr, hbord, theipb)
subroutine clptrg_scalar (iscal, isvhb, icodcl, rcodcl, byplus, buk, buet, bcfnns, bdlmo, hbord, theipb, tetmax, tetmin, tplumx, tplumn)
The wall functions may change the value of the diffusive flux.
The values at a boundary face $ \fib $ stored in the face center $ \centf $ of the variable $ P $ and its diffusive flux $ Q $ are written as:
\[ P_\centf = A_P^g + B_P^g P_\centi \]
and
\[ Q_\centf = A_P^f + B_P^f P_\centi \]
where $ P_\centi $ is the value of the variable $ P $ at the neighboring cell.
Warning:
  • for a vector field such as the velocity $ \vect{u} $ the boundary conditions may read:
    \[ \vect{u}_\centf = \vect{A}_u^g + \tens{B}_u^g \vect{u}_\centi \]
    and
    \[ \vect{Q}_\centf = \vect{A}_u^f + \tens{B}_u^f \vect{u}_\centi \]
    where $ \tens{B}_u^g $ and $ \tens{B}_u^f $ are 3x3 tensor matrix which coupled veclocity components next to a boundary.
Please refer to the clptrg section of the theory guide for more informations.
◆ clptrg()
subroutine clptrg ( integer  nscal,
integer  isvhb,
integer, dimension(:,:), pointer  icodcl,
double precision, dimension(:,:,:), pointer  rcodcl,
double precision, dimension(:,:)  velipb,
double precision, dimension(:,:), pointer  rijipb,
double precision, dimension(:), pointer  visvdr,
double precision, dimension(:), pointer  hbord,
double precision, dimension(:), pointer  theipb
[in]nscaltotal number of scalars
[in]isvhbindicator to save exchange coeffient
[in,out]icodclface boundary condition code:
  • 1 Dirichlet
  • 3 Neumann
  • 4 sliding and $ \vect{u} \cdot \vect{n} = 0 $
  • 5 smooth wall and $ \vect{u} \cdot \vect{n} = 0 $
  • 6 rough wall and $ \vect{u} \cdot \vect{n} = 0 $
  • 9 free inlet/outlet (input mass flux blocked to 0)
[in,out]rcodclboundary condition values:
  • rcodcl(1) value of the Dirichlet
  • rcodcl(2) value of the exterior exchange coefficient (infinite if no exchange)
  • rcodcl(3) value flux density (negative if gain) in w/m2 or roughness in m if icodcl=6
    1. for the velocity $ (\mu+\mu_T) \gradv \vect{u} \cdot \vect{n} $
    2. for the pressure $ \Delta t \grad P \cdot \vect{n} $
    3. for a scalar $ cp \left( K + \dfrac{K_T}{\sigma_T} \right) \grad T \cdot \vect{n} $
[in]velipbvalue of the velocity at $ \centip $ of boundary cells
[in]rijipbvalue of $ R_{ij} $ at $ \centip $ of boundary cells
[out]visvdrviscosite dynamique ds les cellules de bord apres amortisst de v driest
[out]hbordcoefficients d'echange aux bords
[in]theipbboundary temperature in $ \centip $ (more exaclty the energetic variable)
◆ clptrg_scalar()
subroutine clptrg_scalar ( integer  iscal,
integer  isvhb,
double precision, dimension(:)  byplus,
double precision, dimension(:)  buk,
double precision, dimension(:)  buet,
double precision, dimension(:)  bcfnns,
double precision, dimension(:)  bdlmo,
double precision, dimension(:), pointer  theipb,
double precision  tetmax,
double precision  tetmin,
double precision  tplumx,
double precision  tplumn
[in]iscalscalar id
  • 1 Dirichlet
  • 3 Neumann
[in]byplusdimensionless distance to the wall
[in]bukdimensionless velocity
[in]buetboundary ustar value
[in]bcfnnsboundary correction factor
[in]bdlmoboundary Monin Obukhov length inverse
[in,out]hbordexchange coefficient at boundary
[out]tetmaxmaximum local ustar value
[out]tetminminimum local ustar value
[out]tplumxmaximum local tplus value
[out]tplumnminimum local tplus value
